Question about Daewoo F227B Monitor
My Daytek 905DF monitor only displays the lower 2/3 of the screen. The top part is not displayed althought the computer responds to the mouse if it is in that section if you can click on the right part of the screen. Any ideas?
Using the splitter i can not get windows 7 to recognize the other monitor and enable multiple monitors
Hello there,
As you've said you're using a display splitter, the result will be identical screen on both monitors. splitters main function is to split VGA signals into N of outputs. where N=number of outputs. no matter how many monitors you attach to your splitter, the windows only recognize monitors attached directly to your video card. Windows requires a video card that has two or more output VGA or DVI outputs to get second extended monitor or display link device.
If you're video card has two outputs follow the instruction below.
1. plug the VGA or DVI other cable on the unused port. 2. power on the second monitor. 3. right click on the desktop, click screen resolution.
4. click the display in gray, Multiple Displays: it depends on the user.
5. I selected extended display. 6. apply and ok.
This spreads your desktop over both monitors and lets you drag items between the two screens. This is how most people use two monitors, and it's the default setting for desktop computers. you can use your mouse to grab the title bar (the top portion) of a window and drag it to your new display.
Hopefully this information is helpful. Thank you for using FixYa..
Jul 17, 2011 | Computers & Internet
I have prolem in samsung LED that no display shown when i turn on....can you please advice. thanks....Peter
send me detail on jogindersingh47@yahoo.com 1) if yours LED power on and display of window not giving then problem from cpu. a. first replace yours RAM and check display. b. then display cable and check display. c. Install new Display card and check display, if not giving display it means motherboard have a problem 2) LED not giving power on then problem from monitor a. replace monitor power cable and check display b. monitor logic card have aproblem
Mar 16, 2011 | MPC Computers AOC 7F 17" CRT Monitor
How can I fix an "Out of Range" display?
It means that your display card settings are too high for your monitor. Boot your system into safe mode (press F9 as it boots up) and set the display settings lower. Right mouse button click on an empty space on your desktop and go to properties. Then settings->advanced->Monitor and you should be able to adjust the vertical frequency down to 60hz or 72hz. If you get the out of range message on boot up then you will need to try out a different screen on your system, boot into Windows, change the settings and then plug in your original monitor.
Feb 09, 2011 | Westinghouse L1975NW Monitor
When I connect my Advent laptop running windows 7 to my panasonic viera tv via hdmi via a vga to hdmi converter I just get a blank screen, are there laptop or tv settings that I need to change? Chris.
Yes there are a couple of settings which you must change in order for your computer to register your external monitor. on the desktop right click with your mouse and go to personalize, once that opens on the lower left corner click on display, now on the top left corner about the (5) fifth option it should say change display settings, click there. If you do not see two monitors displayed, click on detect, and once you see two monitors click on apply. Now if you want to extend your desktop to the second monitor simply go to the multiple monitor drop down menu and click on extend these displays, and viola there you have it. Be aware these settings are only meant for Windows 7.
Feb 02, 2011 | Computers & Internet
When i mouse over the top left of the screen.. about a line of pixels go into a crazy assortment of colors in a line at the top of the screen. It only does it in the top left corner... I just opened...
try to adjust your computer's display setting, sometimes improper display settings causes that.
Another area to look is to see if you have any "Hot Keys" setup for that corner. Sometimes those corners are setup as shortcut key for doing something. You might have it set without actually knowing.
Aug 23, 2010 | HP Computers & Internet
Trying to run monitor from my lap top and goes in to autoconfig and I see my desktop, when autoconfig is complete, I get blank screen.
In general more info is required, but most likely this is an issue with your display settings. Try the following:
1) Try pressing the Fn and Display buttons (at the same time) on your laptop. Try it once, twice, and then a 3rd time.
Chances are that your laptop is displaying in a resolution that is not completely compatible with your monitor, so when the display settings are switched from laptop LCD and montor, to monitor only, the resolution should adjust automatically.
2) If that doesn't help you, try lowering or adjusting the resolution on your laptop. If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust it. If in Vista/7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Good luck. Let us know what happens!
Feb 16, 2010 | Acer AL1912 19" LCD Monitor
Star logis 15 inch monitor
Try connecting the monitor to another computer and see if it has the same problem. If so, sounds like part of the display has gone bad. If it is still under warranty, try to get it repaired/replaced. If it's not under warranty, you might be better off getting a new monitor rather than trying to get it fixed, but it doesn't hurt to ask.
Apr 04, 2008 | Star Logic (11004998) (Black) 15 inch LCD...
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
Daewoo F227B Monitor Logo
Top Daewoo Computers & Internet Experts
Paul Bade
JonSnell Electronic
JonSnell Electronic
pucraja
pucraja
Level 1 Expert
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
