Standard Belkin Keyboard. How can I reprogram F12 so that pressing Cntrl + F12 mutes all audio. Thank you John Dix jwkm509@gmail.com
  • John Dix Nov 03, 2010
    Thank you. I can see how to change from WinKey to Ctrl but not how to change to F12.
    John Dix
  • John Dix Nov 04, 2010
    Many thanks
  • 13,433 Answers
Hello
If your using windows you can use HotKeyBind to create such a hotkey to mute your sounds.
http://sourceforge.net/projects/hotkeybind/
the program is available at the above link and comes in a zip archive, right click on the file and select extract all, then run the program and by default it puts the mute on Windowskey + 0 you can change that to CTRL+F12
let me know if you need anything else.
Posted on Nov 03, 2010
  • Ekse Nov 03, 2010
    you go to "Edit keys" and then on the window click the box on ctrl and then just press the f12 key alone.
I need a keyboard manual for an Aires K3 seven colour keyboard
Function Keys(for Aires 3 colour keyboard , so i'm guessing will be the same)
Fn + Esc:4 levels backlit brightness adjustable,suitable for use days & nights
High light - Medium light - Respiration light - Extinguish (High brightness by default when starting up).
7 Multimedia Shortcut Keys: Stop, Fast forward, Rewind, Play/Pause, Volume-, Volume+, Mute
3 levels keyboard speed adjustable:
Fn+F1 : 21 byte per sec(80/S)
Fn+F2 : 30 byte per sec(60/S)
Fn+F3 : 63 byte per sec(40/S)
Fn Multimedia Combination Keys:
Fn + F4 Mute
Fn + F11 Lock/Unlock all keys
Fn + F12 Lock/Unlock Windows Key
FN + W : Switch WASD keys and Arrow keys.
Fn + Tab:3 colors adjustable backlit
Jan 28, 2017 | Audio Players & Recorders
I have Philips Flat Tv model # 42pf7320a/37 ..I have a clear picture but no audio, just white noise and static.
Clear picture but white noise and static?!!!!!. What do you say?. Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Jul 23, 2015 | Philips 42PF9630A 42 in. Plasma Television
How to light up the keyboard on the lenovo yoga
Dear Costmer,
Please Followup,
Press Fn Key+ F11 (-), F12(+)
amit.mishra.lenovoservice@gmail.com
Jul 18, 2014 | Lenovo Yoga IdeaPad Ultrabook 13.3"...
FUCTION BOTTON STUCK, HAVE TO PRESS FN BUTTON TO TYPE
press the Fn F12 and NumLk keys at the same time and it should turn it off
Feb 01, 2009 | IBM ThinkPad R40 2722 Notebook
Keybrd locked
press shift key 5 times message will be come go to setting and uncheck all 4 option and apply problem will be solved. pleaseee rate this solution thank you.
Dec 20, 2008 | Logitech Cordless Desktop MX3200 Laser...
Wierd synbuls
You may have activated a shortcut key on your keyboard such as the Fn (function) key. It looks like this
Fn and usually situated on the bottom left hand side of your keyboard near the left hand cntrl button.
Some function keys when pressed once remain on. Once they are on they can cause different symbols to appear in place of the normal keyboard ones. If you press your Fn key again and then try typing on the keyboard once again it may help fix your problem.
I hope this helps
Cheers
john
Nov 16, 2008 | Compaq Keyboard
When ever i press certain symbel keys its wierd
I hope this helps
Cheers
john
MX 3200 cordless keyboard
Looks like a problem with the secure mode. Please try the following steps to resolve th is:
a) Press Ctrl + Alt + F12.
b) Press connect button on the receiver.
c) Press connect button on the keyboard.
d) Press escape key.
Mar 23, 2008 | Logitech Cordless Desktop MX 3000...
S510 Keyboard Problem, Keys Dont Work, Everything Else Works,Ect-Mute
I had the same the problem. The cause was a corrupted encryption code. That is why only worked the keys that don't require encryption.
1) Install the Logitech software and restart.
2) The software will tell you to press CTRL-ALT-F12. This procedure resets the keyboard encryption and tells you to enter a new code.
3) If you already had the software installed simply press CTRL-ALT-F12 and follow the above procedure.
Mar 15, 2008 | Logitech Cordless Desktop S 510
Logitech s510 keyboard
I had this problem for a very long time as well. Turns out this is an encryption issue. It's off-balance. You need to reset the encryption, and here's how:
On the LEFT side of your wireless keyboard press and hold Ctrl+Alt, and press F12, then release all three buttons. Now push the Connect button on your Wireless Receiver, then the connect button on your wireless keyboard. Now press Esc. Try it. See if it works. It did for me.
Nov 09, 2007 | Logitech Wireless Access Duo Optical...
Computers & Internet Logo
110 people viewed this question
Alun Cox
David Payne
David Payne
