Question about Kenmore Elite 45986 Front Load Washer
All electrical is working it just will not start. Thinking maybe the door is not latching properly????
Dirt in the contacts
Posted on Nov 03, 2010
The start button on my washer doesn't work. The power supply is fine and the door is latched properly, all the other buttons work, but the start button does not work.
Sometimes start buttons seem to be working when, in fact, they have failed electrically. If door switch failure is not a problem, most likely the start switch will have to be replaced.
Aug 24, 2016 | Washing Machines
May tag Neptune 5500. The door locked light never comes on and door is not locked in any cycle. How do I test the switch/lock assembley? And is there a way to trick the machine into thinking that the door...
Grounding in a 120vac environment usually will cause a big spark and pop the circuit breaker. There is a possibility the latch is like a car door latch. If it somehow gets moved to the shut or latched position when the car door is open, it will never close and latch . The latch must be returned to it's normal door open position so that when closed it will latch securely.
Your machine's latch may be blocked by something acting like the car door latch described above. It may be the switch has broken and is the "culprit".
Mar 26, 2015 | Neptune Washing Machines
I have a 2004 sequoia, my passenger door sensor keeps thinking the door is becoming unlock or door opened when it's not. I lock the doors by remote and a little while later. My alarm goes off (no one...
Sounds like you have a latch switch that is not making proper contact. You can try soaking the latch with contact cleaner and then when the solvent flashes off, lubricate with some white lithium. If this doesn't work you will need to change out the latch with either a used part or purchase a new one from the dealer.
Jan 24, 2018 | 2004 Toyota Sequoia
Rear trunk door on '03 Audi A4 Avant does not properly secure.
the struts would have no effect on the catch at all. chances are the floor catch has moved inwards a little, re adjust to fit correctly/watertight.
Jul 11, 2010 | 2003 Audi A4 Cabriolet
My 1987 Dodge Ramcharger, 318 Auto, 2wd has a rear door issue. It won't shut and latch properly the owner before me installed additional locks on either side to secure the door but they are ugly. Any way...
take a look at the latches, make sure they are grease good and all working,sometimes one of the latches freezes up, so the door is not completely latched,also you can adjust the striker to lock tighter,this is located on the body, at the top and bottom of the left side door,take a look and see if all latches are latching, use a screw driver to push them locked and see if latec will stay latched in the lock postion. good luck.
Feb 27, 2010 | 1987 Dodge Ramcharger
Push start different sound water may start may not start pause
I would check to make sure the connectors to that door lock are all connected. If they are it's probably the lock/switch mechanism itself. Wow I just checked and they are about $120. The p/n is wh10x10006 You can google around for the best price. Good luck!
Mar 04, 2009 | General Electric WHDVH660H Front Load...
Dishwasher Frigidaire FDB2830CES does not start. All the leds of the pannel work fine but it does not want to start. Seems intermittent.
Check for continuity on both door latch switches (maybe only one on some models) make sure cabinets are not obstructing proper door closure which will prevent the latch switches from working.
Dec 27, 2008 | Frigidaire Dishwashers
My electric oven will not lock the door to have it self clean
The most likely problem is that the motor that drives the locking mechanism is defective.
Mar 30, 2017 | Ovens
Whirlpool Gold Range Model#GR773LXSS (WD Sensor Open)
hi thanks for the question. the sensor at fault is located in oven top left looks like a pen , replace the sensor thanks the appliance doc
Oct 04, 2008 | Whirlpool GR773LXSS - Stainless Steel...
Repare electric window tailgate 1990 fullsise blazer
latch the locks and trick the door in thinking it is shut. then once you are done pull the handle and relase the latches before you close the door.
there is a safty switch in the latches that keep the window from working unless the door is shut.
Jun 14, 2008 | 1990 Chevrolet S-10 Blazer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
