Question about ViewSonic 17" CRT Monitor
Osd lock my osdlock is stuck, can,t changr it
  • 1 more comment
  • kranthicbz Jun 28, 2008
    my osd lock is struck ..and blicking can i stop it
  • dhanushgupta Jul 09, 2008
    on my view sonic monitor screen "osd lock" is blinking every time. pls say me how to get rid of this. if there is any solution plz email me to dhanushgupta@yahoo.com
  • satee553 Aug 16, 2008
    ON MY  MONITER SCREEN  OSDLOCK BLUE COLOUR BLINCKING EVERY TIME
Hold down key 1 for 10 seconds .. your osd lock will be unlocked
Posted on Sep 06, 2008
  • cool_IDZ Sep 27, 2010
    Thanks its working... I only press it. and it worked
HP2465 model: This is a part time fix and quite funny. After hours of trying things I found that if you tape the "input" button "on" (in) it worked for us. Then you put in the service call to replace the monitor if you are under contract or warranty. Your model may require other rube golberg temporaty fixes. Regards, Mr Fixit
Posted on Dec 16, 2008
  • 8 Answers
Hold the menu/ok button for ten seconds, to unlock the OSD.
If this doesn't solve the problem, then it's probably the button that got stuck.
There are two things you can do to repair it, but both require that you dismantle the casing, which voids any warranty.. so, if the monitor's still covered by the warranty, or if money is not an issue, have it repaired by professionals on an accredited brand shop (check your warranty details for more information on this subject).
If not, remove the casing, locate the menu button's contact switch on the circuit board, and try to release it using something thin like a screwdriver, x-acto knife, or set of plyers.
If this doesn't work, chances are the menu button is stuck on a loop, sending a continuous signal to the board (which keeps locking/unlocking the OSD).
If so, your only solution (other than take it to a repair shop) is to remove it, by prying it off with a screwdriver or set of plyers.
Of course, you'll lose access to the OSD features, but I guess this is better than to have a message stuck on front of your screen all the time..
This is a tried and working solution, since I had this problem myself (with a Philips 190B monitor), and solved it successfully, with this method.
Posted on Sep 25, 2008
    Problem Solver:
  • 11 Answers
1.bass pwb assy ic, some p.f problem
2.F.B.T ABL Cir. & ic hor. vritical place & sys ic p.f .def
Posted on Jun 13, 2008
Model no-l1506 when monitor power on then on monitor scren coming osdlocked
Hold down the Menu button for 10-20 seconds until you get a message saying "OSD Unlocked". And it will better to change all the switches.because some time may be any switch was dymaged.
It is my practical knoladge
Answered by Bijay ketan mallick (orissa,bbsr)
Sep 19, 2011 | HP L1506 15" LCD Monitor
My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
The following site has step by step instructions on steps you can try: http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Mar 01, 2011 | HP 1730 LCD Monitor
When i try to adjust the monitor controls message comes up OSD locked, how do I unlock it
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Oct 24, 2010 | Computers & Internet
OSD lock flashing on monitor
To remove the OSD lock, kindly use the steps as shown in the attached image:
Hope this solves your problem. Thanks for using FixYa.
Jun 14, 2010 | ViewSonic E70f (White) 17 in.CRT...
My monitor says the OSD is locked I can't unlock it
  • If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
  • If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD
Or else you can try this method also, Hold the menu/ok button for ten seconds, to unlock the OSD. If this doesn't solve the problem, then it's probably the button that got stuck. Remove the casing, locate the menu button's contact switch on the circuit board, and try to release it using something thin like a screwdriver, x-acto knife, or set of plyers.If this doesn't work, chances are the menu button is stuck on a loop, sending a continuous signal to the board (which keeps locking/unlocking the OSD).
If so, your only solution (other than take it to a repair shop) is to remove it, by prying it off with a screwdriver or set of plyers. Of course, you'll lose access to the OSD features, but I guess this is better than to have a message stuck on front of your screen all the time..
May 18, 2010 | LG 22" FLATRON LCD Monitor
Osd locked
Unplug the monitor from under the screen. Leave it off for a min. If OSD returns, it's a bad monitor. Maybe a button is stuck ?
Jun 13, 2009 | Gateway FPD2275W LCD Monitor
Osdlock on my computer desktop for 17'' monitor
You are having a problem with the OSD lock on your ViewSonic E70f Monitor. Is that correct?
If so, please follow these instructions to unlock or lock your monitor.
On some display devices, there is an OSD Lock that locks all current control settings and prevents access to the control menus until this mode is unlocked.
The method for unlocking the OSD is different for different monitors, but will be one of the 2 below. If the first method doesn't work, try the second.
Method 1: Press and hold both the [1] button on the front of the monitor and the down arrow button for 10 seconds.
Method 2: Press and hold both the [1] button on the front of the monitor and the up arrow button for 10 seconds.
Note: These same buttons, when pressed for another 10 seconds, will lock the OSD
Please let us know if you require any further help with this matter.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 31, 2009 | ViewSonic E70f 17" CRT Monitor
OSD lock out
I HAVE AN OSD LOCKOUT ON MY SCREEN WHICH BRINGS UP THE MAIN MENUE. THE MOUSE DOESNT WORK ON IT TO SWITCH IT OFF!!
Jun 22, 2008 | HP f2105 21" LCD Monitor
Problem in TFT
  • If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Jun 09, 2008 | LG L1915S 19" LCD Monitor
ViewSonic 17" CRT Monitor Logo
297 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
