Question about Gateway FPD1975W 19" LCD Monitor
My monitor will not come on. the powere botton is flashing blue
  • dr_morrison Mar 07, 2015
    The world would be a better place if more answers were as clear and easy to follow as yours.
    Novelist:
  • 159 Answers
Which model 900w or LE1936 ?
This info is usually on a sticker to the side of the stand.
If the 900w: You problem is probably that the capacitors on the power board have gone bad and need replacing. May also have transistor problems.
You would have to open it up to get a better idea.
I can probably tell from a picture.
If it is the LE1936: then it could be a similar capacitor problem, but it is rarer on this model than the 900w
Also on this model, there is a voltage regulator on the vga-dvi board that tends to go bad.
email bammbamm@ptd.net
Posted on Nov 03, 2010
  • WSSEARS Apr 20, 2011
    THIS WAS EXACTLY THE PROBLEM! VISUAL INSPECTION INDICATED THAT THE 1000UF/10V CAP WAS EXPANDED ON THE END, WITH A SMALL DARK STAIN.
My SyncMaster 940BW Samsung monitor does not respond to any Laptop/computer connection. The on/off blue botton is blinking. It worked well a while ago. ANy suggestions?
You can try to disconnect VGA cable to see will the notification "no VGA signal" appear on screen. If so the problem could be with PC graphics, else it is power board problem bad caps.Thanks
Sep 29, 2013 | Samsung Syncmaster 940BW LCD Monitor
Power blue light flashing when i turn the computer on
It depends on where the blue light is. Is the blue light on the monitor or on the computer tower? If it is on the monitor the monitor is having problems and needs to be serviced. If it is on the tower it could be an issue with the power supply.
Jan 17, 2013 | Gateway DX4720-03 PC Desktop
My FPD1976W start botton is blinking blue. Why?
It is either not getting the video signal from your PC, check all the pins at both ends of the VGA cable), or it is in shutdoen mode due to short circuits or failed power supply due to bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 02, 2010 | Gateway FPD1976W LCD Monitor
My HP vs17x monitor seems to be stuck on hibernate mode. The blue light on the power button is on, and is flashing. The scren is blank. I have tried pressing the button several times. PS- It has nothing to...
Have you tried to hard boot it ? That means takin the battery out for at least fifteen minutes this usually helps cause it gives the laptop time to reset to the default settings
Dec 13, 2009 | HP Pavilion dv9000z Notebook
The screen was unplugged and now when plugged in the blue light around the power buton just flashes
I tried the reset procedure, i've left it unplugged now for a week and upon ... Now the fifth died. This time, no illumination, just flashing blue light. ... The screen is completely black, the power button is dark blue and no amount of ... The monitor was gone for about 2 weeks (maybe 3) I left it plugged in and ...
deliverator.silverfir.net/?p=369
Dec 04, 2009 | Samsung SyncMaster 932B LCD Monitor
Hp pavilion f1703 blue monitor power button flashesw/ dark screen
Have you tried connecting this monitor to another computer, even a laptop. This would tell you whether the display is bad or the video card is the culprit. I suspect the monitor's power supply is dying. Taking it to a pro for repair should cost @55.00. Buying a new monitor @ $100 - $125.
Mar 26, 2009 | HP Pavilion F1703 17" LCD Monitor
Dell flat panel monitor -power button blinks green to amber - no
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 10, 2009 | Dell Dimension 2400 PC Desktop
Power light Flashes on and off stays blue
Hi...there,
It's seems you got a busted AD Board... your LCD bios had been damaged or erased.
Dec 01, 2008 | Computers & Internet
HP vs17 monitor power button flashes blue but screen stays black.
Try put off Monitor uplug power cord and the VGA cord for 1min and reinsert and restart your PC.
Nov 25, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Need help with Compaq MV5500 CRT 15 inch monitor
hi there, your switch botton is failling, manual buttons on the front to adjust controls, do some switch test, replace micro botton switch. ty
Dec 26, 2007 | Gateway FPD2275W LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
1,248 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
