Question about Fargo DTC510 Card Printer
Printing problem The screen says No Mag Encoder, what does that mean?
  • 3 Answers
No mag encoder means you're trying to send encoding data to the printer but the printer isn't configured with an encoder. A mag encoder writes data to the magnetic stripe you see on the back of some cards, like credit cards. Most likely, the printer doesn't have an encoder installed, but if it does, it may be turned off in the printer settings.
If you're sure that it does have an encoder, you can check/change the setting by going into the menu on the printer. Go to Menu -> Setup Printer -> Change Parameter -> Encoder Settings -> Mag. It will say none or installed. Note that this can be changed to one or the other whether or not the encoder is physically installed or not. This only turns it on if the encoder is there.
Hope this helps.
Posted on Jun 20, 2008
How do i change the DTC4500e from double sided to single sided
Go to your start menu - select "Printers and Faxes" or equivalent (depending on your version of windows). Right click the DTC4500 and select "Printing Preferences".
In the Preferences window, go to the "Device Options" tab. About halfway down you will see a section for "Dual Sided". Uncheck, "Print Both Sides". Click OK to save preferences. Sometimes you may have to restart the printer.
Sep 24, 2014 | Fargo DTC4500 Dual-Sided printer - USB,...
Ma printer is printing double images what could be problem?
The problem might be " horizontal measuring". It's controlled by linear encoder and linear encoder sensor. Usually, the linear encoder is dirty. Check it.
Jan 20, 2013 | Epson Stylus PX660 AIO /37ppm A4 Photo...
Phaser 8560 printing fuzzy. Machine menu screen illuminated but no display can not access onboard help due to screen failure
The cause of the blurry prints is that oil, from the maintenance kit, has leaked onto the drum encoder assembly. The drum encoder is responisble for position the Y-Axis or vertical direction of the print. The oil on the encoder is making the printer incorrectly position the drum as the pinthead is spray ink onto it, thus you get a blurry print. If you look closely, letters probably have a downward jag to them.
There are two ways to fix this. The cheapest and easiest method is to remove the right side cover, then the fan on the right. Behind that fan is the drum encoder wheel. Using a lint free cloth and isopropyl alchol (preferably 99%), clean all the oil off of the sensor disc. This method might work for a while, but the problem will ussually come back.
The second method would be to just replace the drum assembly. The drum assembly comes with a new encoder disc.
The display (menu screen) can easily be fixed by replacing the control panel (part# 848K06552). It's pretty simple to replace w/ no tools required. Here is video to show you how.
Aug 24, 2011 | Xerox Phaser 8560MFP Laser Printer
I recently changed from Preface to ID Works for printing my cards. At the same time I installed the Datacard printer driver ver 4.0 from CD. I have a SP 35 with and optional mag stripe kit installed. Now I...
Most likely your Mag-stripe info is missing from the card project in IDworks.
If you imported your projects from preface, its likly the box to include mag-stripe config was not transfer d.
enter idworks designer and click VIEW then field connections, there should be some info tied you mag-stripe field 1,2, or 3 of not there is the problem.
Next check printer plug ins in IDworks admin to make sure the mag-stripe plugin is installed. Also i would check Datacard.com Download section make sure you have newest and correct driver for your OS
if none of this works, uninstall everything (exporting projects) and reinstall.
Mag-strpe encoders can become defective, the encoder may need to be replaced.
Jan 02, 2010 | Datacard SP35 Printer
Mag lt982s no green light no power at all
try testing it in another outlet a known good outlet if it powers on then your outlets bad if it doesnt means a bad cord or bad monitor
Feb 10, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Phaser 8400 Printing Blurry
The Drum Encoder is behind the fan assembly.
When you take the encoder cover off be extremely careful.
Use a cotton swab on the disc only with just a light amount of alcohol on the encoder disc.
Dec 17, 2008 | Xerox Phaser 8400 Laser Printer
Fargo Pro-L error message Mag Jam.
iT MEANS MAGAZINE JAM AS IN "MAGAZINE FOR CARDS"
May 29, 2008 | Fargo Pro L ID Thermal Printer
Printing
This can be caused by an encoder strip that has become fogged with ink aerosol.
To clean the encoder strip follow the instructions here.
Pay careful attention to the cautions as the encoder strip is fragile and can be easily damaged if mishandled.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Mar 30, 2008 | HP DeskJet 6122 InkJet Printer
"Printing" but nothing comes out......
Hey dear you did not describe the full detail. Light is continuously blinking and nothing is coming out from the printer OR printer is not printing anything. If the printer is not printing anyting and light continuously blinking. It means printer is not properly getting the data. You have to change the 'encoder' (a transparent strip goes through the carriage) and you have to clear the round transparent encoder present left side in the mechanical with wet cotton. After this your printer will work smoothly.
Sep 15, 2007 | HP PSC 1610 All-In-One InkJet Printer
Fargo DTC510 Card Printer Logo
130 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
