Question about LG LSC26905TT Side by Side Refrigerator
Need to replace 2 shelfs in the side door of the fridge One is the smaller shelf just below the dairy section and the other is the larger shelf at the bottom of the door. Could you kindly tell me who i can contact to purchase these items Regards, Rhonda
    Guru:
  • 1,524 Answers
Bi Coastal Appliance Parts 1-800-673-1262
Posted on Nov 03, 2010
My Samsung Refrigerator side by side door ,,Model,,SRS583DHD,, left hand side door ice maker increases temp and not producing ice,,;-(,,Bot
Your description sounds like a loss of air flow problem. Check for overloading your freezer and fresh food side. In order for the freezer and fresh food side to work properly, the air vents need adequate room for air to circulate. I had a customer who completey filled the middle shelf with cardboard boxes and completely blocked air flow on the middle shelf The lower level near the evaporator was extremely cold and the upper area was room temperature in the freezer. Each shelf needs about an inch of room at the back and room between packaging to allow air to circulate.
Hope this helps
Dec 13, 2014 | Refrigerators
Fridge door shelf
Look up Sanyo Appliances on the internet. When you get to the Sanyo Appliance section, type in you product by name and number. When the item is found, look for replacement parts. Once you find the part you need, simply go from there.
Dec 19, 2013 | Sanyo Refrigerators
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
Fresh food door will not close/seal
Check to see if one of your door shelves is bigger (sticks out more into the fridge) than the other ones. If it is, theses shelves can cause door closing problems. Try removing the shelf from the door and closing it again. If this shelf is the problem, call subzero at 1800 222 7820 and give them your model and serial number, and they will send you a new standard depth shelf to replace the deeper shelf at no charge, these shelves caused a lot of door closing problems when they came out. Hope this helps!
Sep 07, 2013 | Sub-Zero 690 Side by Side Refrigerator
Westinghouse fridge freezer model RS6437*4 FRIDGE SIDE KEEPS FREEZING UP
Could you please check that model number again? The number you posted came up as a range. The model number should be listed in the refrigerator section.
Oct 17, 2012 | White-Westinghouse White Westinghouse...
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
I have a GE side by side refrigerator GSS22JEMB BB. The defroster heater was replaced. How do I know if the defroster is working properly. Can I manually manually make the fridge go into defrost mode? Also...
To go into defrost manually : Remove the 10"X13" panel from the back of the fridge . You will see a plug with 3 larger wires going to it . Unplug this plug ( UNPLUG THE REFRIGERATOR FIRST ) . The blue receptical will look like this wire#1,wire#2, space , wire#3 . Use an insulated jumper inserted into the receptical to wire #2 and #3 . Plug refrigerator back in . You will be able to see the glow from the defrost heater if the freezer is cold enough and the bimetal is good .
Some models , when the freezer door opens , the fan will keep running and others , the fan will stop , until the door is closed .
There will be a slight stream of cold air at the top of refrigerator section due to the fact , that if it was a larger stream , food would freeze on the top shelf of the refrigerator section .
Aug 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Tenants have broken every door shelf rack
For the GE refridgerator, the model GTS22 is an incomplete model number. That is actually the series number. Your actual model should be followed by 5-7 more letters, as in GTS22FBPBRWW. The full model number denotes dates, dimension, color, etc. You can find the full model number in one of two places:
A) Upper front left corner of the food compartment
B) Left side of the crisper pan on the food liner (with storage drawer open).
Once you find the correct model number, it is important to decide exactly which parts you need. Each door shelf comes in 3 pieces. You have two end caps (left and right) and then the front piece. For the bottom shelf, the end caps are different than the caps for the top and middle shelf. Also, do you need the dairy door and the butter dish? A schematic drawing can be most helpful.
When you know which parts you need, you can go online to www.partstore.com or call toll-free 866-925-PART (7278).
Apr 07, 2009 | GE GTS22 21.8 Cu. Ft. Top-Freezer...
Replacement glass shelf required
Not too sure what your glass shelf looks like, but if you can't find replacements it might be easier to just get a sheet of plexiglass and glass cutting tool from a home depo (or the like) and cut it to the correct measurements. That's what I did for mine.
Nov 28, 2008 | Zanussi ZTX520W Top Freezer Refrigerator
Liebherr fridge parts? The plastic on the glass shelf has cracked and I need to replace the shelf but I don't know where I can do this... I'm also not sure what model the Liebherr fridge is either...
There should be a tag with model # on it somewhere on unit. Usually in inside side wall of fridge section. Or maybe on back of unit. Definitely need model # to order part.
Sep 08, 2017 | Refrigerators
LG LSC26905TT Side by Side Refrigerator Logo
59 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
