Question about Bosch Vacuums
Drive belt on upright bagless cleaner
Where oes the replacement drivebelt go on my cleaner? I didnt take the broken one off and I cant find how to fit the new one!
If its like mine there is a rod that comes out f the moter usually on the upper left of the power head put t the belt around that and then slip the belt over the beater bar. Then replace the beater bar. You will have to pull a little to stretch the belt.
Posted on Jun 13, 2008
  • 328 Answers
Usually the drive belt can be put on by taking off the sole plate on the base of the vacuum. If you turn it around you may be able to find a series of screws which will help you. However Bosch bagless upright series is the same as the Vax VX-1 and you can download a manual here:
http://www.vax.co.uk/support/support.php?result=62
This model has a protected brush though so the belt on it may just have slipped off. Either that or the button to turn off the brush at the top of the handle has been switched off or may be broken.
Dont forget to rate!
No power to brushes no result when brush switch activated
If you hear the brush moter running then the belt driving the roller has probably broken. It can be easily replaced by removing the brush plate underneath and pulling the roller out. Replacement belts are available on-line or may be available in hardware stores.Fit the new belt over the steel motor spindle first, then place the belt over the roller and insert the roller.
The belt will break if the roller gets jammed, so buy 2 belts and keep one as a spare.
Mar 07, 2011 | Bissell 3750 Lift Off Bagless Upright...
What kind of belt do I need to fix my vacuum?
Healthy Home Bagless upright vacuum cleaner replacement belt. Genuine Bissell part number 203-1329 or 2031329. Fits All Bissell Healthy Home, and Heavy Duty models including; 5770, 5770-5, 5770-8, 5770-P, 5990, 6100, 6405, 50C9. Belt contains the following code MS 3M-243-12 written on the outside.
Feb 16, 2011 | Bissell Upright Vacuum - The Pet Hair...
Hopw to fit new belt
DC07s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, if your brush bar isn't turning then you have a faulty clutch. New clutches are available on eBay reasonably cheaply, but again good tools and DIY skills are required.
Have a look atwww.dysonmedic.com which has some excellent info on dismantling and repairing a DC 07.
Oct 26, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a dyson root cyclone. i dismantled it to replace the belt, it is not the belt which is on the roller brush, it is the belt which is from the motor, it was easy to take out as it was broken, i will...
The belt that fits on the motor is the same belt that drives the roller brush, all you need do to gain access is remove the sole plate, normally attached with 3 quarter turn connectors, use large flat screwdriver to turn them
Apr 15, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
How to replace belt on Hoover U6626-900 Wind Tunnel bagless.
Click this to go to a site that will show you (complete with illustrations) how to change belt.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
I hope this helps.
Jan 19, 2010 | Hoover U6630-900 WindTunnel Bagless...
Dyson upright vacuum cleaner makes horrendous noise
It might be a simple as changing the clutch belt and the drive belt and cleaning out the brush roll. You can get replacement belts here:
Dyson DC07 Belts
Dec 08, 2009 | Dyson DC07 All Floors Bagless Upright...
Broken electrical cord
The belt can e replaced but I recommend you should take it to your local vacuum cleaner service center. They may even be able to fit a new plug on the end for you if the damage is at the plug end.
Mar 20, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater bar belt broke. how do you replace it?
Remove the glide plate, take out the brush and broken belt.
Refit new belt and roller. re fit glide plate
away you go
Mar 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dirt Devil Featherlite Bagless Upright
Check the brush roll, are the bristles worn down? Check the belt also, if it is stretched, then it won't drive the brush roll like it should.
Oct 02, 2007 | Dirt Devil Featherlight Bagless Upright...
Vacuums Logo
224 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
 John
John
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
