Question about Electronics - Others
3.15amp fuse blows - Electronics - Others
    Guru:
  • 2,178 Answers
Your power supply has a shorted component.
Posted on Nov 03, 2010
  • patdalmaney Nov 03, 2010
    cheers, I suspect a shorted diode in my rectifier bridge but I haven't measured it yet. just maybe it was a commonly known issue.
A 2004 Dodge Stratus blew the door lock fuse (15amp). Replaced it with another 15amp and it blew again. Replaced it with a 25amp and it works fine. What should be replaced so the 15amp will work again
Why would you replace a fuse with a larger one ?
Trying to burn the car down ?
Need to test the door lock solenoid inside the door,
to see if that is the reason the fuse blows
If your putting in larger fuses, you surely should not
be working on vehicles or anything with electrical current
Oct 22, 2014 | Cars & Trucks
Solution to efi fuse blowing repeatedly
wiring problem.
try to increase the fuse
for example: from 15amp to 20 amp
Oct 04, 2014 | 2005 Toyota Corolla
2002 tracker,keeps blowing 15 amp fuse that runs heatr fan and lets car shift out of park
I looked at the wiring diagrams and those two circuits should be on two different fuses.
The shift lock solenoid is powered by the 10amp turn signal fuse and the 15amp stop light fuse. If the fuse blows when you put it in park, I would say the shift lock solenoid is the problem and the stop light fuse is the one that is blowing.
The heater fan and relay are powered by a 60amp fuse and a 15amp fuse but not the stop light fuse.
Its possible there is a short some where that has connected these two circuits.
You could disconnect the shift lock solenoid to see if the fuse still blows.
Jan 21, 2013 | 2002 Chevrolet Tracker
Why does my honda shadow 1100 american classic keep blowing 10 amp ignition fuse
DOES YOUR BIKE HAVE CORRECT IGNITION COIL IF IT TOO HIGHLY RATED I.E A SPORTS COIL YOU WILL PUT EXCESSIVE CURRENT THROUGH FUSE CAUSING IT TO BLOW. IS THE FUSE HOLDER SECURED DOWN VIBRATION CAN MAKE FUSES BLOW LIKE BULB FILAMENTS {TRY A 15AMP FUSE] IF THAT BLOWS DEFINATE OVER RATED COIL
Aug 12, 2011 | Honda VT 1100 C Shadow Motorcycles
99 vw jettal 2.0 gas fuse 29 15amp fuse keeps blowing-no spark unpluged coil and fuse keeps blowing. help please
Thats the fuse for the ECU, engine control module, and is a 15amp for gas 2.0. i would locate the ECU which is under the center of the plenum in the engine compartment and disconnect the long plug. Check for green discoloration on the multipin connector. Sometimes moisture will get in there and short some of the pins together. Leave ECU unplugged and replace the fuse. If it still blows cause is between the fuse and the ECU.
Dec 27, 2010 | 1999 Volkswagen Jetta
I have a BMW F650 Gs 2003 model. Problem.... Resent 40k service done and now it keep blowing 15amp fuses. They ( the service people) have checked everything. can't find the short. It only blows fuses when...
Which 15Amp fuse blows?? Sounds like a pinched wire in the area of the headlight/instrument cluster. Remove the faux gas tank cover center section and maybe also remove battery. check in front of battery compartment for pinched wires etc.
I can offer more help if you post which fuse blows. I can look on wiring diagrams and tell you which items are powered from the fuse in question.
Sep 21, 2010 | BMW F 650 GS Motorcycles
How do i know the fuse watss if thse fuse is loss
Just install a 15amp and if it blows replace it with a 20amp and so on. 15amp is the average.
Jun 28, 2010 | 2000 Ford Excursion
1988 toyota cressida.is blowing a 15amp EFI fuse in the hood.
check wiring harness for injectors,and the injectors Short to ground in harness or shorted injector. common problem with injectors are shorts to ground.
Aug 24, 2009 | 1988 Toyota Cressida
Blows 15amp ecm fuse
replace ignition switch
May 29, 2009 | 2005 Toyota Corolla
Upon replacing my fuel pump fuse (15amp)and
Pretty sure you need a new fuel pump, it may be shorting out inside or seizing up drawing too much current blowing your fuse. There easy to change, if you need info on R & R a fuel pump get back to me.
Mar 18, 2009 | 1988 Volkswagen Cabriolet
Electronics - Others Logo
Top Electronics - Others Experts
ray gallant
Bill Boyd
Are you an Electronics - Other Expert? Answer questions, earn points and help others
