Question about Roland Spd-S Sampling Percussion Pad System
Display on Spd-S
My display was hit by a drum stick. It is not cracked but the graphite or ink inside that displays the setting is a blob. The pads work but finding the desired sound is time consuming.
Can you fix it and if so can you estimate the cost ?
Rob
  • Fourstrok Jun 13, 2008
    Thank You Sweet R.
    Do you have access to Roland parts and do you conduct the repair?
    Guru:
  • 1,894 Answers
This could be fixed at a cost of nearly 100$
Posted on Jun 13, 2008
  • dewan nafees ahmed Jun 13, 2008
    sorry sir./ madam. a small correction.
    it seems my rate was wrong. it may take til 200-250$ in ur place it seems.
    no sir/mam. we dont conduct repairs. we can give remote assistance.
    don't forget to accept the solution if u go by it.
    thank you sir/mam. .
The waste ink tank is near full
Hi
I found this in a forum you can try it see if it work for you.
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Also I found this.
First Clean and Dry the Print Head:
I used a cotton swab dipped in 70% isopropyl alcohol (rubbing alcohol). Do not use too much alcohol.
Then dry the heads, again using dry cotton swab. Be careful not leave any cotton threads on the print heads.
Then I padded dry the spongy Ink Absorbers (one for black ink and the other for color ink) using
Separate cotton swabs for each absorber. Do not displace the absorbers. Or you can replace the ink absorbers at this point if you do not want to pad them dry.
Then Proceed to the Waste Tank Reset procedure below:
1. Press the "menu": Key
2. Press "Copy" Key
3. Press "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading or select (-) as a short-
cut to the last setting.
4a. Press “Set” and the display shows:
Test Mode [1] – [8]
CF-FH3 :WLD-11-02
4b. Press “8” and the display changes to:
Test Mode [1] – [8]
Please wait
***note*** you have to wait until the display changes
Then the display changes to:
8: PRINTER TEST
[2]---[8]
5. Then Press the "3" button and the display shows:
8 – 3 : EEPROM Clear
*** the display scrolls to [0] : INK COUNT
[1] : 2PURGE FLAG
6. Press "0" button – for INK COUNT
7. Press the "Stop" button
8. Press Off then On to set new changes.
9. Printer feeds a blank page after it is turned on again.
This should Reset the printer and remove the WRONG CARTRIDGE error and save you a few dollars.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 05, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Asoon as i turn on my copier sereis it displays code p-96-569
This error code means either the print drum color information or ink category information is not input. Easy fix.
Make sure the drum in the machine has ink in it. It must be the correct ink for use in an EZ. Start into test mode by turning the machine on while holding down the left and right arrows for the print position. Hit the "C" key to clear out display. Should read 0000. Type in 590, then hit start. Type in 557, then hit start.
Machine will load information from the ink bottle into the machine and rotate a few times.
Once it stops, turn off and back on to get out of test mode. All set!
Jun 12, 2009 | Riso RZ220 Duplicator
System Error code 09 038 46 24363
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error.
Turn off the printer.
Turn on the printer.
As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
Release the buttons, it will now come up in the service mode.
Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok.
Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Jun 09, 2009 | Xerox Phaser 8560MFP Laser Printer
Paper jam canon mx850. I cant find the paper.
The error indicates a black ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
If you ever buy any Xerox ink and you get a cracked ink stick call Xerox cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif800-835-6100cb_transparent_r.gif and they will replace it free of charge. Otherwise you risk this problem.
Hope this helps.
May 30, 2009 | Canon PIXMA MX850 Multifunction Printer
Hope this helps.
May 30, 2009 | Xerox Phaser 8560N Laser Printer
Error 09,036.44:41689
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
May 01, 2009 | Xerox Phaser 8560MFP Laser Printer
ERROR PROBLEM
Do not use the ink sticks if they have a hairline crack in them. They eventually crack and jam the printer. So far I've only noticed this with the black ink sticks. 5a7294b.jpg
Jan 21, 2009 | Xerox Phaser 8500/DN Printer
Roland Spd-s pad #1 change to different patches when hit
I think there is an option in the setup menu that makes the pad do this.... i remember reading it in the manual. sorry cant help more than that...
Aug 08, 2008 | Roland Spd-S Sampling Percussion Pad...
Roland Spd-S Sampling Percussion Pad System Logo
132 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Greg Cann
Greg Cann
Vito Vacirca Jr.
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
