Question about Baumatic Ovens
Baumatic gas and electric oven bt2260ss grill still working oven gone off think it maybe element is it easy to solve .
5 Suggested Answers
SOURCE: baumatic 1870ss steel electric oven
sounds like your element is not wired in properly or its faulty get someone to look at it
Posted on Dec 13, 2007
SOURCE: replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
Posted on Jul 08, 2009
ginko
  • 19396 Answers
SOURCE: Oven has stopped heating up
Hi.
This oven should have two elements.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Posted on Mar 03, 2010
Testimonial: "Thankyou very much for your help.Im off to buy an element first thing in the morning. Thanks again"
SOURCE: baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Posted on Apr 02, 2010
Baumatic OSF60OVEN 60cm fan oven. Grill works, fan works, light works but oven is not heating up. Is it likely to be something I can fix myself?
You possibly have a blown heating coil, the most likely one is in the main oven, as this is the one that's used the most sometimes you can tell as the element shows signs of blowing other time it doesn't the only way to check this is to remove it and put a test lead to either end on connection clips to see if it's dead also on the element it's self to see if it's gone to earth, but must be removed or disconnected on the end terminals so you don't get a false reading. if you are a handy type person there is no reason wye you can't undertake this work just make sure the electricity is disconnected from the oven prior to any work being undertaken Good luck
Mar 02, 2015 | Baumatic Ovens
My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
Feb 21, 2010 | Baumatic B187 Electric Single Oven
Baumatic oven not heating up. Grill and fan fine.
[WHEN IT ARRIVES !]
Turn the power off.
(KEEP THESE TOO!)
Jan 27, 2010 | Baumatic B180 Electric Single Oven
Good evening i have a BT2431SS baumatic cooker,i have no heat in main oven yet i have the hob and the grill that work ok.
If it is a fan assisted electric oven, and the fan is wrking o/k, then it will probably be a faulty oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thanks.
Nov 24, 2009 | Baumatic Ovens
Baumatic BT187ss Oven All working EXCEPT fan assisted cooking
I have a similar problem with my Zanussi and discovered there is a seperate element arounfd the fan wihich I think may be burnt out. Could be a similar fault have you investigated behind the panels in side the oven?
Mar 08, 2009 | Baumatic B180 Electric Single Oven
Fan oven not heating up
If fan is working then the element has probably gone
Nov 29, 2008 | Baumatic B904SS Stainless Steel Electric...
Oven not heating up
Hi.
If the fan is working o/k, then in all probability the fan oven element has failed.
A common problem with fan assisted ovens.
It is a fairly easy job to replace same
Nov 13, 2008 | Baumatic B180 Electric Single Oven
Baumatic 1870ss steel electric oven
Aug 28, 2007 | Baumatic B187 Stainless Steel Electric...
Baumatic bt180 oven
assume a fan oven.does fan turn and oven light come on? if so problem is the circular element. if no fan and no oven light, then clock probably needs setting - this will be in instruction book. clocks sometimes go wrong but not often. if clock is faulty, a cheap repair is to bypass the clock so auto function no longer works
Apr 09, 2007 | Baumatic B180 Electric Single Oven
Ovens Logo
73 people viewed this question
Top Baumatic Ovens Experts
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
