Question about LG Washing Machines
My new LG washing machine WM2501HVA does not drain. What am I missing? Thanks?
SOURCE: washing machine not spinning or draining water
I have the same washer, WT-R801. Does the machine stop all together when the spin cycle arrives?, if so check the pump on the drain. Mine was burnt out. Its available for $61.00 delivered from Adelaide. Steve.
Posted on Mar 31, 2008
JULIANFIX
  • 975 Answers
SOURCE: Washing machine won't drain
i think you can fix it , does it stops when it reaches RINSE cycle ?? if yes , your gonna open the front panel or back panel so you can see inside machine . follow the DRAIN HOSE thats attached to SMALL DRAIN PUMP MOTOR , YOU NEED TO TAKE OUT and check for anything thats blocking the impellers and causing it to stop ( pins , buttons , etc ) let me know by your smile . . . . . .
Posted on Apr 22, 2008
  • 105 Answers
SOURCE: LG Washing Machine won't spin, signals that load isn't balanced
Check the drain clean out at the drain pump. If is cloggedm with debris, it will not spin and go off a a long drain error code.
Posted on Feb 06, 2010
Testimonial: "The comment was helpful because I was able to find a starting point where to look and eliminate that. Thanks"
  • 353 Answers
SOURCE: LG front load washing machine - need to replace drain hose
It's jusy one clip go in from the bottom
Posted on Mar 20, 2010
SOURCE: Where can I find the
An independent spin cycle can be run by pressing power button, spin button,
Posted on Jul 02, 2011
Lg washer will not drain
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Jan 10, 2014 | LG wm2501hva front load steam washer 4.2...
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
My LG Front Load model WM2501HVA will not turn on and on last cycle was making fast paced clicking noises during spin cycle, what could the problem be?
see the possibles causes:
see the diagrams. God bless you
No power
test the fuse blown + c.breaker trip
Lid switch
test the lid switch for continuity with VOM
spin: see the diagram
May 16, 2012 | LG WM2501H Front Load Stacked Washer/...
Lg washer wm2501HVA light stays on
why my lllLG washer WM2501hva light stay on ????
Jan 29, 2012 | Washing Machines
My LG Turbodrum DD will not drain
Get a new machine. LG washing machines are ****. I have the same model and it has broken down and made horrible noises for years. It finally just stopped working. RIP
Feb 11, 2010 | LG Washing Machines
Feb 06, 2010 | Washing Machines
Washing Machines Logo
150 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
jimorris77
Paul
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
