Question about Xerox Phaser 8560MFP Laser Printer
Jam at exit path on xerox 8560MFP printer -- jam k2x -- however repeated checking shows no paper jam or paper bits causing jam.
checkitright
  • 1362 Answers
SOURCE: paper jam at "exit" - canon D660
open side door and front door, there should be foor screws holding the fuser.
remove screws and take out unit ( be careful, there is a wire connected to the machine, you do not nesscessarily have to disconnect it. ) take out paper and replace.
Posted on Nov 14, 2007
  • 2072 Answers
SOURCE: xerox phaser 6120 laser printer paper jam fuser
You can remove the imaging unit, then
Depending on the stock being used for the job, raise or lower the left and right colored Fuser separator levers. The levers will stay in the raised or lowered position on their own.
the levers are green. The fuser itself is not easy to remove.
Do you have any warranty left on the machine? Or a depot repair agreement?
Posted on May 20, 2008
SOURCE: Xerox Phaser 6250N Jam at Registration Roller
I use to have the same problem, but downloaded a fuser patch at the Xerox site:
http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi?new,kb=Phaser_6250,company=%7B5AC8CA72-62D5-4658-8D6F-D2F393C98A63%7D,ts=xo,ques=ref%28security_level%29:1,ques=ref%28Country%29:45,/,case=R1001052703
if that link doesn't work, go to the Xerox site and look in the area:
Home > Support & Drivers > Phaser 6250 > Knowledge Base
ID: R1001052703Phaser 6250 Support Knowledge Base Jam at Registration Roller (code Jam RR)
Follow the instructions and hopefully your printer problem will be resolved.
Posted on Oct 07, 2008
SOURCE: paper jam
I had the same problem kept getting an error something like Jam at Exit Door Open Door A. When I looked at the top of the where paper normally comes from and flipped it open I found a super crinkled piece of paper, which once removed cleared the jam.
Posted on Oct 23, 2008
SOURCE: Xerox 6250 - Jam at Registration Roller
Ik heb een deregelijk probleem gehad, ook bij merdere printers tegelijk. De oorzaak was achteraf logisch. We hadden een nieuwe zending briefpapier waar een bepaalde film op zat waar de printer niet tegen kan. Logisch, want het kan niet zijn dat alle 3 printeres tegelijk hetzelfde mankeren.
Ander papier erin. De eerste hoeveelheid zal nog problemen geveb tot der olletjes vrij zijn van de vettigheid.
groeten,
G.Eijken te Hoorn
Posted on Nov 15, 2008
My Xerox docucolour gets a paper jam at the exit
Power off and unplug device. Deattach finisher. Ensure paper path is clear at the exit (use a flashlight and magnifier). Reattach finisher - ensuring all connections are secure. Do you have an error code?
Mar 02, 2015 | Xerox Office Equipment & Supplies
Xerox 8560 duplex paper jam
your machine should show where the paper is jammed. Open that compartment and pull the paper out.
Jul 15, 2013 | Xerox Phaser 8560MFP Laser Printer
08.045.43.39496 I keep getting this error code and my machine goes into a cleaning mode daily wasting all my ink
8,045.43 The media path motor stalled while moving the cap/wipe DOWN.
Initial Actions
• Check for paper in the paper path.
• Check the condition of the Pick and ****** Rollers.
Aug 02, 2011 | Xerox Phaser 8560MFP Laser Printer
Xerox Workcentre 4150. Paper keeps jamming in print engine area. We clear the jam and it jams again.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Engine" or constantly jams as paper exits the machine you should check and possibly replace the fuser actuator (part# 120N00534) This is the most likely cause, if however this does not fix the printer the next step may be to replace the sensor or fuser.
Here is a video that shows you how to check and replace the actuator. ItemInc.com has this part in stock and ships same day. Good luck, and thanks for using FixYa!
Jun 23, 2011 | Xerox WorkCentre 4150 Black and White...
We had a paper jam in the print engine area. Once the paper path has been cleared we are still receiving clear misfed paper in print engine. I have fed paper through the path and cannot find any paper jam.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Area" you should check and possibly replace the fuser exit actuator (part# 120N00534). Iteminc.com has this part in stock and ships same day. Here is a video the shows you how to check and replace the fuser exit actuator. Good luck, and thanks for using FixYa!
Jun 17, 2011 | Xerox WorkCentre 4150 Black and White...
08,045.43:5458 power outage happened, when power
This error indicates that the paper path motor stalled. Clear the paper jam, power off the printer for 30 seconds and then turn it back on.
Here's how to clear a paper jam from Xerox website, depending on the location of the paper jam: http://www.support.xerox.com/support/phaser-8560mfp/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 19, 2011 | Xerox Phaser 8560MFP Laser Printer
Our xerox printer phaser 8560MFP does not work and shows a error message :-08,045.43:1177
This error code specifically means: "The media path motor stalled while moving the cap/wipe down."
In English, there is a component inside your machine that is either moving too slow or is obstructed by something.
This can either be very serious or can be surprisingly simple.
If I were you, this is what I would do:
1) Make sure the waste tray is empty.
2) Make sure there are no paper jams or paper scraps anywhere.
3) Check the preheater and make sure there are no obstructions.
4) Replace the mainten
ance kit. See link below.
*This ensures that the printhead is properly lubed and is not dragging behind or stalling
5) If it still does not work, bring it to your nearest Xerox Partner.
If the top suggestions did not work, the problem must be very serious. Your average person cannot fix the problem themselves with any motors or gear packs.
Good luck. Please rate my response or post a comment on your original question to allow me to further assist you.
Maint. Kit:
http://www.office.xerox.com/product-resources/108R00675/enus.html
Find a Partner:
http://www.office.xerox.com/cgi-bin/resloc.pl?what=Service
Aug 15, 2009 | Xerox Phaserâ„¢ 8560MFP Laser Printer
HOW DO I REMOVE JAMMED PAPER
Please turn the printer Off and then ON , till you see the error message of " Paper Jam" check all the flags on paper path, specially on Fuser Assembly.
Turn printer OFF, pull all trays out gently,
Disconnect cables to network or PC. turn printer ON,
check the message gets repeated - paper Jam,
Conclusion : There is some bit and piece of paper activating flags,
take all toners out gently and transfer Drum, look into printer, and
lift the paper path under the toners, push the door a little bit and unscrew the paper path and can see a piece of paper on right side..
Pull the paper out and screw bach. put every thing back in their original status.
Now the printer will work and there will not be any papers..
Jul 31, 2009 | HP Color LaserJet 2600n Printer
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
Can't Feed Envelopes
That machine should still be under warranty. Call xerox and have them check it out.
I looked and that machine has a one year warranty, that includes service.
Nov 09, 2007 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
361 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
