Back to:
Tags:
Paradyne 6381 ADSL2+/ReachDSL Router
No status light
posted by NessaStatus on Jun 13, 2008
Hi, I have a paradyne wireless router model 6388-A1-200 and its been working fine until 2 days ago the status light just went off and now its not coming on at all. I only see the power light, the link light and the LAN light. I spoke to my ISP and they said that there is definitely a problem with the router so hopefully one of you guys could be of better help.
Comment by NessaStatus, posted on Jun 13, 2008
And for my connection I'm seeing limit or no connectivity
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 16, 2008
Helpful (85)
dofsqaa
Rank:Wiz Wiz
Rating: 82%, 54 votes
On your connection LAN icon that normally sits at the bottem right hand corner, Right Click on it and select "Repair"
That should do the trick.
Comment by dofsqaa, posted on Jun 16, 2008
Click on "start" then "run" type: net stop dhcp Click OK then do the same but type: net start dhcp
If all the above fails, power off the router and pc.
allow 5 minites, then turn on the router, allow a minute then switch on the PC.
If this fails. Try chaning the RJ45 ethernet cable (if your using on) or using a static IP address.
Google: Setting Up a Static IP Address in Windows XP
Basically you have a DHCP problem and that is why your connection is showing as limited.
Router as a service running called DHCP Server and your PC has a service called DHCP Client, one of these services has stopped working.
Rating Locked! (?) NessaStatus has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on No status light:
I don't want to Accept this solution
Can you Help with these Routers problems?
Paradyne 6381 ADSL2+/ReachDSL Router...
I have a 6381-A3-200 ADSL2+/R/Bridge/Router that is...
hello, i have 2 pcs that i use to connect to the internet,...
i have tried everything..even dmz and my ports arent open...
I have a paradyne 6381 dsl modem directly connected with...
hi i have a paradyne 6381-a3 the activity light is not on...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
