Question about Dryers
Dryer not heating up much ,thought it might be vent lenght/it go idrectly from dryer straight through wall outside .about one foot.
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 04, 2010
Kenmore dryer runs and heats for 15 minutes then shuts off
Hi, go around back of the dryere. The vent hose coming off dryer to wall outlet must not have any bad bends or kinks. It must run as straight as possible. Then go outside and check the vent for cleaning. If the dryer has run a long time like this you more than likely will need a control thermostat. If you'll send me the make and model number, I can get you the part number if you like. Hope this helps.
Jan 28, 2011 | Kenmore Dryers
Takes 4 or 5 cycles to dry clothes.
Most of the time this problem is attributed to a blocked or more precisely, a partially blocked dryer vent system. When a dryer vent is blocked it stops the air flow and the heat backs up into the dryer turning the heat sensors on and off prematurely taking longer for the clothes to dry. Over time this may cause the heat overload fuse to blow and you will have no heat at all.
First take a look at the dryers ducting between the dryer and the wall to make sure the vent duct (normally a flexible style) has not been crushed or kinked.
If the dryer duct to the wall is in good shape then in most cases there is a blockage some where between the wall where the ducting connects to the vent and where it exhausts outside.
The major cause of a blocked dryer duct occurs when the water in the clothes is heated to a high temperature and turned into steam, which is then exhausted out the back of the dryer to outside. As the steam cools on its journey and gets closer to the outside of the house, it tends to get cooler and turns back into water droplets. This is going to be the point where the dried lint, as it escapes past the lint filter, sticks to the newly formed water drops and starts a gradual chocking down of the 4" diameter vent to 3",2",1" and finally stops all flow of air.
Remember, the dryer is designed to exhaust so many cfm's and the more choked the vent the more heat is backed up into the dryer.
If you cannot access the dryer ducting, because it is in the wall or ceiling, to look for the obstruction, then look in the yellow pages or contact the local appliance repair service company and get the name for a good duct cleaning company.
Apr 08, 2010 | Dryers
Dryer vent filled with water. Large loads would not dry.
If the drying problem is caused by poor venting/air circulation, then things probably won't improve until that situation is remedied. Check out the link I am attaching. It contains dryer venting requirements. Hope this helped and I'm sorry for your trouble. Best wishes.
http://www.mediafire.com/?4yazrf2jz3d
Sep 07, 2009 | Dryers
Dryer is heating but taking twice as long to dry clothes as it should. What could be the problem. Clothes that should take no longer than an hour is taking two hours or more.
Since you know for sure the dryer is heating, the problem most likely is lint in the dryer tube. You will have to remove the back panel of the dryer, and then remove the dryer tube. (Not the vent hose, although you may want to make sure that it and the dryer vent itself is not clogged). Remove the dryer filter and normally the 2 screws that hold the vent tube in. Remove the screws from the vent tube and get the lint out of the tube. There may also be lint around the fan. Get it all out. Be careful though, all the edges are sharp and will cut you if you slide your hand along it while "sweeping" out the lint.
Aug 20, 2009 | Dryers
Low heat output
A clogged or partially clogged vent . Especially if vents up thru the wall . If it vents straight out , make sure you have good air flow to the outside . Make sure the vent hose has no sharp kinks also . Try drying a load with the vent hose disconnected from the dryer . If clothes dry fine , that tells you the problem is elsewhere . Normally , a dryer either heats or doesn't heat . A heat for a few minutes then stops heating but continues to run complaint ,would be bad coils on the gas valve .
Jul 19, 2009 | Dryers
Maytag Dryer Model DE210 is overheating
You really DO have an airflow restriction and it's most likely in the vent inside the wall leading outside. I know this because the dryer is trying to do its' job (and that the default "fail" mode on the t'stats is "open". That is to say... if a t'stat fails, the dryer won't heat).
The only other thing that causes an overheat condition is a failed blower assy. When these fail, though, the dryer makes an awful racket. And since you didn't mention an awful racket, I go with clogged vent pipes in the walls.
When my customers call who have the same symptoms as you, I don't even bother running the service call (costs me money, but I'm an honest guy). I recommend they call a dryer vent service or a chimney sweep service.
Hope this helped!
SG
Apr 05, 2009 | Maytag Dryers
The clothes dried on high or medium heat come out smelling like heated metal
hi .thanks for the question .yes i would check all venting from dryer to the outside . clogged venting, or dryer too close to the wall could cause this problem . thanks the appliance doc
Sep 30, 2008 | Kenmore Elite HE4 Electric Dryer
Venting a dryer outside
What do you need to reverse?
I understand that the wall kit is to blow the heated air from the dryer to outside therefore not humidifying the laundry.
Are you trying to draw air into the dryer from outside or blow the air outside?
Sep 14, 2008 | Fisher and Paykel DE06 Electric Dryer
Dryer venting
straight is always better, but if you have to have a 90 degree, it will be find as long as it is not kinked.
thanks
whites appliance repair
Apr 02, 2008 | Dryers
Dryers Logo
27 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
