I need to find a diagram of aluminum electron
    Sergeant:
    Champion:
  • 390 Answers
i need to find a - witmoz.pngHere is the pic you need.
Posted on Nov 04, 2010
What is E6 error in videocon ac and how to solve this problem plz ans me
Ok, so the e6 error generally occurs due to the lack of refrigerant. There are a few steps using which you can fix the problem that you are facing:
1. Look for the gas leak and fix that. Generally, the leaks happen from the coils which are mostly made out of copper or aluminum. Videocon mostly uses aluminum which is cheap but doesn't last long.
2. Get the refrigerant refilled.
3. Reset the control board in the indoor unit after fixing the issues with the outdoor unit and you're good to go.
You should consult a technician if things don't work out even after following these steps. In case you are looking for news ACs and other large electronics, visit GrabOn and get amazing deals on quality electronic items. Electronics Coupons Offers on Laptops TVs Tablets
May 26, 2015 | Computers & Internet
Hds 10 gen 2 having trouble picking up location takes 20 to 30 minute to locate.
Aluminum will block a GPS signal, but the aluminum needs to be above the antenna and within approximately 12 inches or less.
the other major source of interference is the electromagnetic field of other electronics in close proximity to your GPS antenna. Typically within about 24"-30" or less in distance from the antenna. The internal antenna of the HD 10 is top dead center of the unit.
Turn the "WAAS" off on your unit and see if that improves reception.
Hope this info helps.
May 11, 2015 | Lowrance Hds-10 Gen 2 Combo
Need a diagram for electronic ignition for a 1980 harley sportster to convert to points
Hi Steve, for a free wiring diagram please visit the website below and good luck. Harley Davidson Wiring Diagrams and Schematics
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 29, 2012 | Harley Davidson XLH 1000 Sportster...
A/C not cooling, need a diagram for the high and low sides of the system and does it use r12 or 134a freon
Low pressure side port is in the aluminum tube going to the accumulator ( an aluminum cannister about the size of a soda can or somewhat larger) Will have a plastic cap on it you unscrew to access the port valve.Your system takes R134a, it is the only commercially available refrigerant for automobile use.
Jun 15, 2011 | Ford E-150 Cars & Trucks
I have a GE TrueTemp XL44 oven. All four of the burners are not working. The electronic ignition clicks and the gas is on (because I can smell it) but no flame is created. Any ideas? The oven itself on the...
Hi, To complete the circuit for the electronic ignition the 3 screwheads under the aluminum burner need to be really clean. The same goes for the 3 posts on the bottom of the aluminum burner. They touch to apply grounding for the ignition spark. GL!
Dec 19, 2010 | Kitchen Ranges
Where is the top oil pan located in the 2003 nissan altima 3.5? Need a diagram. This car has 2 oil pans.
Aluminum (upper) oil pan bolt loosening sequence—3.5L engine
Position a suitable jack under the transaxle.
  • Crankshaft Position (CKP) sensors (REFERENCE and POSITION) from the oil pan
  • Front and rear engine mounting nuts and bolts
  • Center crossmember assembly
  • Engine drive belts
  • A/C compressor and mounting bracket
  • Rear cover plate and the lower transaxle bolts
  • Aluminum (upper) oil pan bolts in the reverse of the installation sequence
May 23, 2010 | 2003 Nissan Altima
Not sure how to connect the magnum sg spool gun
Needs to be in dcep, or reverse polarity to weld aluminum
Apr 08, 2009 | Welding Tools
Diagram of 36 volt hookup for trolling motor, i have a factory 24 volt wiring in my boat and I need to turn it into a 36 volt please help thank you
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
budman772357@embarqmail.com
Mar 01, 2009 | Minn Kota Boating
Computers & Internet Logo
41 people viewed this question
Alun Cox
k24674
