Question about Philips Dynamic Edge 4.1 PSC604 Sound Card
Sound only in 1 Speaker Instead of Two
Hello.
I am having a big trouble with this sound card. I m not sure If I am doing something wrong, but I really don't think so. After I disabled the sound of my previous sound card, following all the instructions, and installing the card I set in the Philips sound card setup my sistem as a two-speaker set. Well I only got sound in one speaker. I tested the sound also with my headphones and got the same. There's an option in the Phillips setup to test your speaker and I got not response for the right front speaker.
I also tried to plug my speakers to the rear out connection,.and setting as a 4 speaker system, I got response in the Philips testing panel of both speakers, but I cannot hear any sound in windows( I ve heard its because its only for sorround sound) but, there is a way to make work both speakers when listen music on windows?
  • 326 Answers
Not sure if this will help, go to your control panel and then to your sound and audio devices, on the volume tab check to see if both speakers are set to high on the speaker volume option
hope it helps
Posted on Jun 13, 2008
  • mark hudson Jun 13, 2008
    well i did say not sure if it would help, wont be offering you any more suggestions!!!
I have sylvania shtib1044p-l the big speaker lights up but no sound comes out of it, or is it that only the little speakers are the only ones that suppose to get sound n the big one is just like a desing?...
The big speaker is a subwoofer. Sound should be coming out of the subwoofer that is very low in frequency from a bass guitar or drum beats. Pop music usually has both those instruments pretty prominently. If no sound is coming out then something is wrong. It is more than just a cool design feature.
Oct 11, 2012 | Audio Players & Recorders
I can't seed to get my speakers to work. I have UBL pro speakers.
1. Check the Audio icon on the task bar if muted. If yes Unmute Go to start > control panel > sound. and make sure that nothing is muted.
2. Sound Diagnosis refer this photo
3. Re install the audio drivers. LINK
4. If steps 1-3 don't work, then take your speaker to your friend's computer and see if it works there? if yes then something is wrong in your computer system, if no, then something is wrong in those devices.
Refer to this image below. From your speaker the 3.5mm jack should be plugged at back of I/O ports LINE OUT.
Thank you for posting hope this helps..
Jul 06, 2011 | Computers & Internet
No sound on new acer desktop x3200
Do you have a speaker to connected to the computer? You need to isolate the problem, follow the instructions below:
1. Connect the speaker into different computer to make sure that the speaker is working.
2. Check the volume settings by double-clicking the speaker icon on the System Tray (down by the clock) and make sure that the Mute box is not checked.
3. Check the sound properties of the problem computer:
* Go to the Control Panel > click on "Sounds" or "Sounds and Audio Devices"
* Go to Audio tab and check the sound recording and play-back
* Make sure that those two field are configured properly.
If the speaker worked on other computer and the sound properties is configured properly, then there could be a problem with the sound card that you have in your computer. Maybe updating or re-installing the sound card driver will do.
Hope these helps and have a great day!
Jul 26, 2009 | Acer (54.AA806.001) Sound Card
There's no sound from my computer
It can be a defective speaker or there is no sound card, It can also be that there is no a driver for the sound card.
Jun 14, 2009 | Computers & Internet
Sound drivers
hello, this link should get you what you need for that motherboard. also consider a add on sound card, if the one you have is trouble. alslo make sure the built in sound is enabled in the system bios. (should be by default) http://www.intel.com/support/motherboards/desktop/d845gvsr/index.htm#anchor2 good luck! please rate this solution. thanks. if you need further assistance,reply
Apr 12, 2009 | Intel D845GVSR Motherboard
Hi I Have a V2 Premier Computer And We Just Recently Got it Fixed But We've Lost our sound. Each time i try and acess our Sound thing It Says no Audio! I Highly doubt our computer is on mute! May I please...
I am guessing "Sound thing" is the volume control in the system tray (lower right corner).
If it is saying "No audio mixer" or "No audio device selected" then either one or two possibilities come to mind.
1. The shop that fixed your computer did not install the sound card properly (or left it out).
2. The sound drivers have not been installed or got corrupted.
To see if it is the first one or the second one, we need to get to Device Manager.
For XP, right click My Computer and select properties and click the hardware tab.
For Vista go to Control panel and click the System icon.
Click the button called Device Manager and see if there is anything with a yellow highlighted exclamation point. It likely will say something about unknown hardware or device. There might even be a name on the device that is a clue that it is a sound card.
If you do not see anything like that and there is no device in the category for Sound Video and Game controllers, option one is your choice. Take it back to the shop.
If you do see something that indicates it needs a driver visit the support webpage for your computer. Here is the URL: http://www.v2premier.com/techsupport/downloads.shtml
Select your model and choose sound to search for the driver.
Once you have a speaker icon in the system tray, if you still have sound problems trouble shoot the speakers.
Make sure the speakers have electric power connected and the power light is on for at least
one speaker. Make sure the volume on the speaker control is at least half way up.
Make sure your volume in Windows is at least halfway up and not muted.
Unplug the speaker jack and re-plug it firmly into the hole you just removed it from. Test
for sound.
If no sound, unplug and try another hole of the same size on the back of the computer and
test for sound. Continue testing until you have tried every hole the jack will fit into. One of
them will very likely work.
Jan 13, 2009 | Computers & Internet
Hey, i dont know what sound card i have, theres somthing wrong though.. plz help
assume "something wrong" means "there's no sound" coming out of the speakers. A few things to check first:
1) Make sure your cable to your speakers is plugged in, and plugged into the right jack. It should be the green one on the back of your PC.
2) Click on the "speaker" icon down on your task bar (right-hand side), and that will open up your sound settings. Make sure it isn't a) muted, or b) turned way down low.
3) If you have powered speakers (plugged into the wall), make sure they are getting power to them.
After you've done all that, figure out what model computer you have, and based on that I can probably tell what kind of sound card you have (most these days are built onto the motherboard).
Cheers
Nick
Nov 15, 2008 | Computers & Internet
Whats wrong
get a new driver for the sound card.its probably corrupted or uninstalled.
Oct 31, 2007 | Toshiba (4CH-VOUT) Sound Card
No sound fron our speakers
Call a pro in to access your problem as you didnt leave enough info.. model and make of all you have and how is it all connected?
Sep 09, 2006 | Philips TV Tuner Video Capture PCI Card -...
Philips Dynamic Edge 4.1 PSC604 Sound Card Logo
175 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
