Question about Honeywell Heating & Cooling
I opened the cover of the V8043E 1012 Powerhead, and I found white mineral deposit in the back of the motor and the springs are also affected. Is there a gasket that needs to be replaced, or do I have to replace the entire zone valve? The motor was replaced last year because I wasn't getting any heat on that zone. Thank you. Steve
  • 455 Answers
Hello,Steve they have replacement power head for that valve,but you can also change the guts without needing a torch also.
Posted on Nov 03, 2010
Unclog personal humidifier doesn't work
If this is an ultrasonic humidifier, in the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Feb 25, 2015 | Humidifiers
I cleaned my vicks 5100 series,but it still won't put out a vaper. the green light is on and there is air coming out but no vaper. i also changed the filter and waited still no vaper any hints to get...
In the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Feb 25, 2015 | Vicks Humidifiers
I have a Cool Mist Homedics Ultrasonic humidifier, Model UHE-OC1A that has stopped working...I have cleaned it, the small lights go on when turned on, but no mist is coming out ... ???
Feb 24, 2015 | Homedics Cool Mist Humidfier - Uhe-oc1 -
Slant fin doesnt turn on
Jun 23, 2014 | Slant Fin Humidifiers
White residue in tub
The white Residue may be mineral deposits, such as lime and /or calcium deposits. There are products on the market such as 'Lime Away' or ' CLR' that remove mineral deposits. They can be found in any supermarket in the cleaning/laundry isle
May 05, 2014 | Maytag Washing Machines
Descale bunn cdbcf15 water tank
Running white vinegar thru the line will never cause damage ......and actually should help remove mineral deposits clogging the line. If you want you can reuse the white vinegar and run it thru several times till it has completely removed mineral deposits. Once it is cleaned using distilled water will prevent build up.
Mar 24, 2014 | Bunn O-Matic 28800-0100 - CDBCF-15...
Leaving a white film on everything
Hi, what you are currently experiencing is as a result of dishwasher detergent, combined with mineral deposits from hard water, which in yurn can leave a white film on the inside of the dishwasher.
You have to clean the dishwasher by sprinkling baking soda onto a damp cloth. Scrub the inside of the dishwasher to remove soap scum, grime and mineral deposits.
Pour 2 cups white vinegar into the bottom of your dishwasher. Turn the dishwasher on and run it on a full cycle. Stop the dishwasher halfway through the wash cycle and allow the vinegar and steam to work on the remaining mineral deposits for 20 minutes before resuming the cycle.
Open the dishwasher and dry the interior with clean, dry cloths. Keep the door propped open for 20 to 30 minutes to allow the dishwasher to dry completely.
Hope it helps....
Jun 27, 2011 | Whirlpool Dishwashers
My indesit idl40 cleans everything, but leaves a film? does not seem to rinse?
Jun 26, 2011 | Indesit Dishwashers
Kenmore whispertone 100 model 116. powerhead no
  • The motor / cord compartment cover must be removed to access the cord reel. There are four screws that hold the cover to the chassis. Two of the screws are found under the cord-retractor-foot-pedal on the top back of the canister. To access these screws the pedal must be removed. To do this, press the pedal down and look (from the top) for the four plastic clips that attach/hold the pedal hinges to the cover. There are two at the end corners and two in the middle. Using a long, thin flat-head screw driver (or similar instrument) press each clip to unhook/popout the hinges. Note: the foot pedal spring will also come out when the pedal is removed.
    The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw
Jul 18, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
Craftsman 1/2 hp door opens only 8-10'' then stop
Check to see if a garage door spring has broken. Operate the door by hand. If everything seems ok then increase the strength of the "up" force. There is an adjustment on the powerhead to do this.
Nov 09, 2008 | Sears Craftsman LiftMaster Chamberlain...
Heating & Cooling Logo
116 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
