Question about Samsung Televison & Video
Our remote will not change channel and we can not change channel from the TV either. We have changed the battery and cleaned the front of the TV.
    Guru:
  • 2,178 Answers
The tuner in the TV is bad. Try connecting a regular decoder box and tune that instead. Make sure your source is selected for the box.
Posted on Nov 03, 2010
Tv remote wont work even though new batteries are put in.cannot change channels or volume or even turn the tv off or on
Try opening up the unit and cleaning the contacts and bottom of the buttons with a q-tip and a bit of rubbing alcohol. Over time the oil from your fingers gets inside and creates a film between the contacts and the button so the circuit will not complete and your buttons stop working.
Feb 17, 2015 | LG RU-42PX10 42 in. HD-Ready Plasma...
Dish network remote turns tv on but wont change channels
1) clean the contacts batteries.
2) change by new batteries
3) resolder wires connectors batteries
4) Open the remote control, and clean the keypads very well with special spray contact R. Shack
5) Otherwise you must go to the repair shop TV, FOR Fix it
GOd bless you
Jun 18, 2012 | DISH Network Televison & Video
My model p52960 will not hold a channel just keeps changing
Your TV is haunted !
j/k Perhaps your remote is all wet underneath the buttons, you can remove the batteries from the remote to remove this as a possibility, If the tv comes on still and changes channels still, then you know its not the remote. You may also have defective batteries leaking acid all over the place in there. If it is the remote, you can unscrew and open up your remote and clean the circuit board button landing pads with rubbing alcohol and clean the other side of the rubber conductive pads that touch the landing pad area from the back of the button itself.
Hope for the best and Good luck
Christopher
May 15, 2012 | RCA P52926 52" Rear Projection Television
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
Factory on screen at startup then goesto Fac and remains there
open ur backcover go to the front bottom ur remote controls panel take it apart clean it.
take ur remote control apart too change batteries,a good cleaning
Aug 15, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Durabrand DCF2003
try opening it up and clean the remote with alcohol and soft cloth.let it dry.while drying, check the rubber buttons for breakage.then assemble.be sure your batteries are ok.
May 28, 2009 | Durabrand DWT1905 TV
TV won't change channels or adjust volume
Do you have a universal remote? If the batteries are taken out for a little period of time, the remote will loose the codes and they will have to be reset. You can find the codes by google universal remote codes.
If you have a factory remote that came with the television, than it may be faulty or the sensor on remote or tv may need to be cleaned.
Mar 11, 2009 | Televison & Video
TV changing channels
check channel up & down buttom if stuck up. if not, replace eeprom as possible. good luck!
Nov 27, 2007 | Insignia NS- 27" TV27 TV
Remotes not working
well, sometimes the universal remote does not give you the whole functions, so it is better to work with the original one. you could fix it thought. here is how. most of the time, it just need cleaning. so get some denatured alcohol and clean the pc. do not apply any alcohol to the rubber button, that will ruin them. put it back together and give it a try again..good luck
Aug 01, 2006 | Orion STV2763 27" TV
Televison & Video Logo
115 people viewed this question
Jerry Greenberg
Jerry Greenberg
