Question about Panasonic Lumix DMC-FZ30 Digital Camera
MODE DIAL IS NOT IN PROPER POSITION
Not operating: Front dial Rare dial Power indicator Camera ON/OFF switch Single or Burst MOde Button
  • jk279 Jun 13, 2008
    "MODE DIAL IS NOT IN PROPER POSITION"
  • Anonymous Oct 15, 2008
    When I turn on my camera it says mode dial is not in the proper position, I have tried everything to correct the problem without success.
Try turning the mode dial again. It may not have been turned properly.
Posted on Jul 18, 2008
How do I set my Canon EOS Rebel T3i 18 MP CMOS Digital SLR to auto mode
If you mean the auto exposure mode, turn the mode dial on the top of the camera to the "A+" position, between the "P" and the lightning bolt.
If you mean autofocus, set the switch on the lens to the AF position if the lens has an autofocus switch. On the camera, press the AF button (cursor-right) then turn the command dial to select the desired mode.
If you mean the auto white balance, press the WB button (cursor-up) then turn the command dial to select the desired mode.
In the auto exposure mode the ISO mode is set to auto, and you can't change this.
If you need a manual, you may download a copy here.
Feb 02, 2012 | Canon Cameras
I have a Lumix DMC-LC50 When I turn it on it says: Mode dial is not in the proper position I tried everything
The mode dial is the knurled knob on the top of the camera - if you didn't already know. This same error message displayed when the knob is between selection. If you have moved the know to a valid position - where it stops in a detent, the message should clear from the display and be able to take pictures.
If moving the mode dial so that it rests in a detent and the message is still displayed, it indicates a problem with the switch inside the camera (that is operated when the mode dial is rotated). This is not a user serviceable part, and should be professionally repaired. I found United Camera to list a Mode Dial repair to be $42. there are plenty of others that can make this repair for you, too - this was simply the first I saw that had a price (I have never done business with nor am I affiliated with United Camera in any way).
I hope this is a good starting point for you & good luck. Please rate my reply - thanks.
Jun 10, 2011 | Panasonic Lumix DMC-FZ18 Digital Camera
Lumix camera says mode dial is not in proper position
Hi and welcome to FixYa!
Please try to remove the battery and let it sit for atleast 5mins. then reconnect it again. This should reset the system and can resolve the problem.
Hope this helps and thank you for using FixYa! Have a good one!
Dec 21, 2010 | Panasonic Lumix DMC-FZ8 Digital Camera
Language option
Selecting the desired language:
1. Set the mode dial to P and press the power to switch to turn on the camera to the ON position.
2. Press MENU button.
3. Press arrows dial buttons to select the MODE MENU.
4. Press arrow dial buttons to SET UP tab.
5. Press arrow dial buttons to select Language.
6. After selecting the language press OK dial button on the middle of the group buttons.
That is all. So you can change the language by this way.
Regards.
Apr 15, 2010 | Olympus Camedia C-755 Ultra Zoom Digital...
How do you find and use the self-timer setting?
Hello.
Turn the function dial to the drive mode position.
Press the function button in the center of the dial.
Turn the front control dial to select the self-timer drive mode.
Use the rear control dial to to switch between a ten-second and a two-second delay.
Press the shutter-release button partway down or press the function button to set the mode.
When you are ready to take the picture.
Press the shutter button partway down to set the focus and exposure.
Press the shutter button all the way down to start the timer.
Hope this helps.
Feb 16, 2010 | Konica Minolta DiMAGE A1 Digital Camera
When you turn it on the screen displays "mode dial in not in the proper position." Mode dial does not turn properly.
Something seems to be broken or off between the mode dial and the switch. It also may have broken internal parts.
I have had a camera with a similar problem. It was that the small switch inside was broken, and could not be repaired.
These mode switches can be changed, but will require a digital camera repairman to do such a job. It also could be sold for parts/repair on a site such as Ebay.
Aug 31, 2009 | Panasonic Lumix DMC-FX100 Digital Camera
Panasonic DMC-TZ1 operates in Playback mode only
The position from the dial wheel is not corresponding with the electrical position. If you can do it by yourself you can adjust it and tighten the midscrew from the dialwheel
Regards, Rob NL
Apr 20, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Can't adjust aperature in manual mode.
1. Check the power switch is pointing to the rear dial (not "ON") or you wont be able to set your aperture.
2. Try shooting one image for each position of the mode dial on the top. Then review each image to see what mode the camera indicates the image was taken.(Pressing info during playback will bring up detailed information to show this) If the recorded setting and actual setting dont match, this indicates a fault with the dial.
3. If the camera does not display an aperture, or shows "00" then there is a communication fault with the lens. Check the contacts are clean and sitting correctly. You can confirm this lens is at fault by trying another lens on your camera,I'm sure a photo store could help with this.
Apr 05, 2009 | Canon EOS-20D Digital Camera
how to take good pic beside use the iso mode
May 19, 2008 | Panasonic Lumix DMC-FX10 Digital Camera
Mode Dial and Lens Problems! Nikon Coolpix 4600
i had the same problem try this: tap the outside of the dial lightly while turning the camera on it should basically "pop" right out!!!!!!!!;)
May 04, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic Lumix DMC-FZ30 Digital Camera Logo
1,426 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
