Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
34700 unit when in the vacuum mode it sends R134 into the oil recovery bottle tank
    President:
  • 180 Answers
Please check oil drain sensor(switch) or oil drain solenoid for any debris. If both are check OK, then check Vacuum,Recycle and charge solenoid for any debris or damage. Replace/rebuild as needed. Hope this will help you
Posted on Nov 05, 2010
How much Freon and oil to put in a new used compressor
These dont use Freon. Freon is R22
These use R134 -46oz and 13oz of oil. You need to pump down the system though once the oil is added and let it sit with the vacuum pump to remove any moisture. Any moisture left in the system will ruin your expansion valve and compressor quickly. Then add one can of R134 and run the system for a minute to distribute the oil. then add more R134 until the gauges show it at the right pressure for your ambient air .
Sep 02, 2015 | 1998 Dodge Ram 1500 4WD
Need to change coolant recovery tank can a anyone do it
Yes you can do it yourself
Degas Bottle Removal
  1. Drain radiator (8005) until engine coolant is out of degas bottle. Disconnect radiator overflow hose (8075) and engine coolant vent hose at degas bottle.
  1. Remove power steering oil reservoir retaining screws and position power steering oil reservoir (3A697) out of the way.
  1. Remove degas bottle return hose and clamp. Remove degas bottle retainers and remove degas bottle.
Installation
  1. Position degas bottle in vehicle and install retaining screw and nut. Tighten retaining bolt and nut to 9-12 Nm (80-106 lb-in).
  1. Connect degas bottle hose and clamp to degas bottle.
  1. Position power steering oil reservoir onto degas bottle and install retaining screws securely.
  1. Connect radiator overflow hose and engine coolant vent hose to degas bottle.
  1. Fill and bleed engine cooling system as described. Check for coolant leaks and proper engine coolant level after engine reaches normal operating temperature.
    Item Part Number Description 1 8100 Radiator Cap 2 - Nut (1 Req'd) 3 - Bolt and Retainer (1 Req'd) 4 - Nut (1 Req'd) 5 - Bolt (1 Req'd) 6 - Coolant Recovery Hose 7 - Coolant Return Hose 8 - Coolant Recovery Hose 9 8A808 Degas Bottle A - Tighten to 9-12 Nm (80-106 Lb-In)
Hope this helps.
Zeppelinx12
Mar 08, 2011 | 1999 Ford Taurus
FHow much solution goes in first?
The tank is labeled. Take the clean/solution tank off the vacuum by lifting it straight up. Unscrew the black cap on the bottom of the tank and remove the bottle insert. Add 8 oz of the Little Green formula (this gets you up to the Formula fill line). Then add hot water to the water fill line. Replace the bottle insert and tighten the black cap. Then replace the clean/solution tank by lining the indentations up with the vertical guides on the left side of the unit and sliding it straight down. Please note that the bottles of the formula come in 32 oz or 64 oz bottles. So you can expect one of the smaller bottles to last 4 fill cycles.
I hope this helps.
Oct 07, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
Goodman CLJ36-1A with bad Copeland Compressor CR30K6-PFV. Any suggestions where to get a replacement compressor?
Not a DIY project. You'll need refrigerant recovery equipment, vacuum pump, manometer, refrigerant scall, refrigerant disposal bottles, high pressure nitrogen tanks and regulators, acetelyn tanks with regulators and torch tips not to mention EPA license. Call a reputable service company. In South Central PA, fair price range is $1,500 - 2,000. If the unit is more than 10 years ole, replace the condenser (if they can get one for your refrigerant) for about $1000 more.
Jul 18, 2010 | Goodman CLJ36AR42 Air Conditioner
Robinair 34700 recovery problem
It sound like one of the pressure trunsducer is not working or disconnected from the manifold assy.or from ISV tank.Please check Low,High and ISV tank pressure transducer
Jul 08, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a Robinair 34700, during vacuuming and recycling I lose about 200 g refrigerant gas.
Don't worry this is normal.Because while machine is running for vacuum or recycle mode,automatic air purge device will active for some time & it will purge air from ISV.
May 28, 2010 | Robinair Cool Tech 34700Z Recovery,...
Refigerant in oil recovery bottle
You have to change/rebuild oil drain solenoid & check oil drain check valve.
Sep 08, 2009 | Robinair Cool Tech 34700Z Recovery,...
Model Robinair 34700 Series 21699 Date 09/97 very slow when recharging system? Same problem on any vehicle. Tried closing off high side and running the vehicle ac n/g Any Help Thanks Tony
Please do the following 1# Check your machine ISV tank liquid line quick connector.it's seems to be very tight,open little & try to charging.2# Rebuild charging solenoid.
Jun 23, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
439 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Sheldon Dedek
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
