I just bought a G4 router. I have yet to enable a password for it as I wanted to make sure everything works. My laptop from work is asking for the device ownership password. I cannot find this password referenced in any of my paperwork.
  • mhaley925 Nov 04, 2010
    Belkin Model #F5D7234-4. laptop is using XP pro. wireless utility is Intel Proset/wireless WiFi connection utility. when I try to sign on I get a screen asking for the "device ownership password" which I have not been able to identify. Thanks.
  • 1,675 Answers
Hi It is very simple! Just create a new Profile:
1. in System Tray click on WiFi icon,
2. select 'Configure WiFi'
3. open 'Profiles...'
4. choose 'Add...'
5. in 'Profile Name:' type anything (it can be the same name as SSID)
6. in 'WiFi Networks Name (SSID):' type a proper name of your WiFi SSID
7. choose 'Operating Mode:' you have 2 options, but I rather choose Network (Internet)
8. click 'Next'
9. leave selected 'Personal Security'
10. under 'Security Settings' choose WEP or wpa-psk encryption type that is enabled on ADSL router. On my router I have WPA-PSK, and I have chosen WPA-Personal (TKIP)as its the strongest encryption. careful in choosing the correct encryption type.
11. type Encryption key in field 'Password'
12. click OK
13. select this new profile and click 'Connect'
hope this helps
Posted on Nov 04, 2010
  • 1,472 Answers
Mhaley925
So I can help you address your issue I need to know the model number to your router and the version of Windows that you are running.
Issken
http://www.fixya.com/users/issken
Posted on Nov 03, 2010
  • Will Hartford
    Will Hartford Nov 06, 2010
    mhaley925
    I am still looking to see what the device ownership password is for your router. However from what I have found it sounds like the pins used on bluetooth devices.
    So I would like you to put in eight "0" to see if this works.
    Let me know how things go
    Issken
I bought a used apple powerbook G4,my wifi does not work without a password but I don't know that password, how do I find password
Lack of information , What is the model number of the wi-fi router. Once you know this google search for default ip address (with the router model number) then google search default password (with router model) then open a browser with p.c or laptop directly connected to the router via an ethernet patch cable. Type in ip address in browser. then log into router. And go to security and look what the encryption key is and make a note of it, if you have a working device already on the wi fi you may be able to log into the router. typical default router addresses are 192.168.0.1 ot 10.0.0.1 your may be different.
Dec 23, 2013 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
I have tried everything, and i can't get this router to connect wirelessly I do the step-by-step instructions, name my networks, set my passwords and everything. it says i completed the entire setup on...
During configuration, you must enable the router radio and SSID (Name) broadcast, so that the router would be visible to laptops and other wi-fi enable devices.
Select Wireless Settings under Advanced in the main menu of the WNDR3300 router.
Make sure the Enable Wireless Router Radio and Enable SSID Broadcast check boxes are selected.
Hope it helps!
CreativeTECH
Dec 03, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
CANNOT CONNECT TO WI-FI
First turn on the wifi in laptop then make sure your wifi network adapter tcp ip property that it get ip from router.
Aslo make sure router settings are perfect.
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 02, 2010 | Computers & Internet
No wireless signal, it's been working fine for 2 months, then all of a sudden no signal being put out. everything is lit up on the router except the wireless light.
You need to reset your router or first make sure in router settings that wireless is enable.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you need to RESET your router you have configure your router with above method.
You can RESET it with RESET button press it for 10 seconds it is in back side of router.
Apr 17, 2010 | Belkin (F5D7231-4) Wireless Router
My laptop is saying
This error comes when there is same ip address in 2 computers.
So make sure in networks there are not same ip address.
You can also solve this issue with DHCP .
Enable DHCP in router.
http://192.168.0.1
or
http://192.168.1.1
Then set "ip get automatic " in network adapter property.
Mar 11, 2010 | Linksys -Cisco Wireless-G VPN Broadband...
When I try to log into internet it says windows cannot figure this wireless connection. it was working before. i am afraid i have disabled something by accident.I am technically challenged.
The best thing you should do is remove the softwere of the wireless router then install it again using the CD provided with the wireless Router.
Feb 13, 2010 | Dell Latitude D600 Notebook
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
MacBook not connecting to DIR-655 Router
My solution was that I changed the wireless mode from "B,G and N" to just "B and G," and then it worked fine.
Nov 23, 2008 | D-Link Xtreme N DIR-655 Wireless Router
Can't connect home comp to laptop
how many wireless computers do you have?
is it a dekstop or laptop?
if desktop have you installed a wireless adapter? if laptop, is it using a built-in wireless adapter, have you enabled the wireless adapter or have you installed a wireless adapter?
please make sure first that the wireless adapters are installed properly or enabled on your computers, if everythings OK.
access the setup page of your router and change the wireless settings of it.
how to access the ui
- open the internet explorer
- on the address bar type in 192.168.1.1 hit enter
- enter admin under password, leave it empty for the username and click ok
- click the wireless tab
- set the wireless mode to mix, change the wireless network name or ssid with any preferred name you want to use, make sure to enabled the ssid broadcast and then click save settings.
- after that, under wireless tab, there are sub tabs, click wireless security
- set wireless security to WPA-PERSONAL, and under passphrase, enter your desired password for wireless connection, take note of it and please be reminded that its case sensitive.
- click save settings.
for your wireless computers, if adapters enabled and working fine, on the system tray you should have an icon for the wireless connection, doubles click on it and it will pop for the wireless connection window wherein you can see the name that you set on your router, all you have to do is select the name click on connect and it should ask you enter a password, enter the passphrase you set on the router and click connect. then check if you can go online, if yes do the same thing with other computers.
Have a great day ahead.
Sep 28, 2008 | Linksys WRT160N Wireless Router
Setting up a Wireless Connection
you might want to check the www.belkin.com site to see if that can support Mac Powerbook.
Mar 09, 2008 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
