Question about D-Link DES 3226 (DES-3226) 24x10/100 Mbps Networking Switch
I have the username and pwd and can see the IP is set to 10.90.90.90 but it wont connect through internet exporer. What could the problem be?
  • 4,350 Answers
The address should be like 192.168.1.1 or 192.168.0.1. and this is in the address bar and NOT the search bar.
Posted on Nov 04, 2010
I would like to change my password on my router, how do i do this?
at the back of your router check the IP address, example 192.102.99.105 - Check your Manual
at the browser (Internet Exporer, Mozilla firefox) enter your IP and press Enter / Address Bar.
Log in. the default Username and Password is : admin
Now you can change settings and password to your router.
Jan 15, 2013 | Cell Phones
I am replacing a linksys which is still working and I am using now. I cannot get the D-Link to connect to my bellsouth DSL
Step 1: Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. Select Admin as the username and type in your password. Leave blank if you have not created or changed your password.
Note: The address 192.168.0.1 is NOT on the Internet. The web-based configuration is built-in to the router.
If the router is already online, you will be taken to the STATUS page after logging in. If this is the case, the router is connected and you do not need to continue with this FAQ.
Step 2: Click the Setup tab and then click Internet on the left side.
Step 3: Click on the Manual Configure button.
Step 4: Select PPPoE (username/password) from the My Internet Connection is drop down menu and enter the following settings:
-Address Mode: Select the Dynamic IP radio button, unless your ISP (Internet Service Provider) supplied you with a static IP address.
-Username and Password: Enter the username and password your ISP gave you. In most cases your username is the same as your email address provided by your internet provider (example: yourname@yourisp.com).
-Reconnect Mode:Should be set to On Demand
-MTU and Maximum Idle Time: Should be left at the defaults (MTU: 1492 / Maximum Idle Time: 20) unless specifically instructed otherwise by your ISP.
Step 5: Click on the Save Setting button to save the changes.
Step 6: Click on Status tab and Device Setting on the left side.
If you are connected to the Internet; your Cable Status and Network Status will say Connected,you will have an IP Address, Subnet mask, Default Gateway, Primary DNS Server and Secondary DNS Server. If you do not, click on the Renew Button.
May 14, 2011 | D-Link DIR-825 Wireless QuadBand Router
Where do I find my Pin # on my Linksys router?
access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.1.1).
Leave the user name blank and the password is admin (default), (unless you set a username and Pwd).
Click on the wireless tab, then the security tab. you will see your encryption key/ pin.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 08, 2011 | Linksys Wireless-G WRT54G Router
I can not access the setup of my camera trendnet TV-IP110W since Internet Exporer
  1. Please make sure if both the camera and computer is connected to your router's LAN port
  2. Open the IPSetup Software which came on the CD along with the product
  3. It will detect the camera's current IP address. You can change it to an IP address based on your network
  4. The double click on that IP address or type it on IE's address bar. Camera's Live view will be shown up
  5. Then you can match the wireless setting with your wireless router to view the camera wireless without being connected by a Ethernet cable
May 15, 2010 | Trendware TV-IP110W Network Camera
Networking
Your router internet settings should depend on your ISP connection type. If you are on DSL, either your setting is PPPoE or just obtain IP automatically. If you have a username and password from ISP, select PPPoE and specify your username and pw. Check on the internet/WAN status if it says "Connected" and if it has Internet IP address.
Your modem should be plugged in to the internet port of the router while both your computers should be on plugged in to the LAN ports (numbered ports).
You may contact your router manufacturer for step by step assistance on the router setup. They should be able to restore your connection.
Apr 09, 2009 | Edimax BR-6104K Router (br6104k)
Axcess issues
Now lemme explain it :
belkin has a feature in which it saves ur username and pwd from ur ISP ...if u dont know the pwd ..contact ur ISP ...then u need to login into the router and unblock the ports ...its a long process..call me on +919999722757...i will explain it to u
Apr 02, 2009 | Belkin (F5D5231-4) Router
Problem with philips voip841
Try retrieve the IP address of your VOIP841, on the handset press the “Menu” button, navigate to the “Settings” menu and choose the option “Network”, then "DHCP", it should give you an IP address, make a note of this. Open your Internet browser and type in the IP Address of the VOIP841 into the address bar. The Internet browser will show the internal Internet page of your device. Login with the following username and password:
Username: philips
Password: voip841
After logging in please navigate to the “Skype” menu option in the left side menu. On this page y ou can type your Skype username and password. Once they are filled in save your settings and test on the handset if everything is working.
Sep 25, 2008 | Philips VOIP8411B/37 IP Phone
Modem/router
You need to call your INTERNET SERVICE PROVIDER. You need a USERNAME and PASSWORD from your ISP when you set your modem to bridge. This username and password will serve as your connection authentication. Once the modem is already bridged you have to set the INTERNET CONNECTION TYPE on the router to PPPOe(that is where you type your USERNAME and PASSWORD). When you are already online, you might need to forward the port number for your ip camera for it to work.
Good Luck
Mar 11, 2008 | Computers & Internet
Wireleess router wont work PLEASE HELP!!!!!
You will need to logon the router via the computer, and create a PPPOE internet connection. The user manual that came with the router will show you how to do this. If you do not have the manual. Do the following: open internet explorer in the address window type the IP of the router "example" http://192.168.2.1 your router IP should be on the bottom of the router. If not click start/run, type ipconfig at the > the router ip is listed at "default gateway". once you get to the routers logon page enter one of the following: username "leave blank" - username " admin " -or- username "admin" - password 1234. once logged on the router go to internet connections and select PPPOE enter the username and password provided by your ISP save the settings and you should make the internet connection now. BPCS
Dec 30, 2007 | D-Link DI-634M Wireless Router (DI634M)
D-Link DES 3226 (DES-3226) 24x10/100 Mbps Networking Switch Logo
204 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
