Question about Kirby Ultimate G Bagged Upright Vacuum
Re-attaching the vacuum
Hey there, I attached the hose and did some vacuuming and now wnat to re-attach the main vacuum head. This is the biggest pain, can you please explain exactly how to do it. I have followed the instructions to a tee and I still cannot get the roller portion to work, the green light will not come on and I cannot get the vacuum to work properly. Any suggestions
  • 357 Answers
    President:
  • 1,673 Answers
With the nozzle off, turn the big knob until it locks, (will only turn one way) also make sure the belt is in the center, then turn the knob, put the nozzle back on and lock it down. Then turn the knob again and then the belt will be put on the spindle. Next time, before removing the nozzle, turn thast knob until it locks, then remove it, then it will be ready when you want to put it back on.
Posted on Jun 17, 2008
My dyson cyclone isn't sucking with hose attachments
Check in your manual, or online copy for your machine. You probably need to cut suction to the floor head to use the hose attachments.
Dec 05, 2017 | Dyson Vacuums
G4. Why does it only seem to have suction with the hose detached?
Hey, this is Jeremy with Crucial Vacuum,
I am sorry to hear that you are having issues with your Kirby G4. It sounds like your problems might stem from one of two areas:
1) Your hose may not be attached properly and allowing for air to enter the hose at the point of attachment.
2) The vacuum bag may not be properly attached to the hose connector.
Below I have attached a link to the users manual for the Kirby G4. You should refer to page 9 and 20-21 to view the diagrams pertaining to my suggestions.
http://kirbywhq.powweb.com/manuals/G4/8D4538EC00E93846200D614F7C499B59/G4%20Manual.pdf
You can purchase replacement parts for Kirby direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/kirby.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 18, 2015 | Kirby Vacuums
No suction when using hose attachments - motor runs and under cupboard vent works - just not able to use just the hose with attachments
does the vacuum turn on when hose plugged into wall outlet assuming your using central vac. if it does not turn on then the metal band in the hose end is possibly cracked.
Jan 03, 2015 | Vacuums
How do i attach the hose to the vacuum so i can vacuum my vents?
Remove the vacuum head by tilting the front down slightly and pulling straight back. Attach the wand hose onto this opening by placing the small hooks of the hose on the bar beneath the opening and pushing the hose against the vacuum base. Lock the hose in place by turning the vacuum head lock from left to right so it catches the hose.
Read more: Kirby Ultimate G Instructions ' eHow.com http://www.ehow.com/how_7935766_kirby-ultimate-instructions.html#ixzz1VyB7yixm
Aug 24, 2011 | Kirby G6 Bagged Upright Vacuum
Kirby turns on with hose attachement but not with head attachment
Front of the unit, black switch that is pressed by this plastic protrusion from hose coupling has two parts. It is because ANY generation Kirby has speeds - HIGH for vacuuming with hose and LOW for using it with nozzle.
Looks like the switch went bad (Switch HERE)
We have instructions for replacing it too.
The "funny noise" with hose throws me off a bit though. Check if there is nothing in the hose (put a nickle through it).
Good Luck
May 29, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Floor attachment does not suction, no clog in the hose, hand held works when dettached from floor attachment
Have you checked the floor head? Use a pipe cleaner or twisted metal to carefully and gently see what's in there. It sounds like dirt or something has definately sealed up the main suction channel.
May 07, 2009 | Vacuums
How do I attach upholstery parts?
Remove the main head and put on the air guard.
Take of the bag assembly and attach the hose.
Mix up the solution in the "Suds o gun".
Attach this to the end of the hose.
When you switch on, foam will dispense from the gun.
Gently sponge this into the furniture.
Please leave feedback
Feb 14, 2009 | Kirby G4 Bagged Upright Vacuum
When hose is attached vacuum stops
there is a clog somewhere in your hose, wand or head
a plummer snake will get it or even a broom handle
Dec 28, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Kirby Ultimate G will not suck with main brush head attachment
You may need a new belt, it may have stretched enough so it isn't turning the brush roll anymore.
Mar 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
When attachment hose is on, it's extremely loud
That only happens to me if I leave the vacuum on the carpet and don't raise the head before 30 seconds...it is the rubber belt hanging on the metal thing that it sits on. Since the belt is not used with the hose attachment, I cannot imagine what is going on. Therefore, I've been no help at all! Just to let you know it happens to others - just slightly differently.
Aug 08, 2007 | Kirby G4 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
47 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
