Question about Xerox Office Equipment & Supplies
My xerox 3030 is on however all it does is flash a green 6 in the quantity box. None of the numbers or buttons work. I've turned it off and on, I've unplugged it and still the same??????
    New Friend:
  • 51 Answers
Open the cotrol panal replace the 6 switch as it is permanently on
Posted on Dec 12, 2010
When I turn on the copier the screen says Xerox with a yellow line on the bottom and 1/6. it stays like that all day. none of the buttons work nor does the touch screen. it won't copy. I have pushed the...
Please once again shut it down. And re-install the cartridge. Also then reset it without cartridge. And if this does not work then simply its time to send it to company service station.
Thank you.
Oct 02, 2013 | Xerox Office Equipment & Supplies
My Xerox Workcentre-5020 machine showing U4 error. How can I solve this problem ?
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
Nov 07, 2010 | Cell Phones
I require a service manual for a xerox 3030 wide format photocopier so I can learn to install a new toner
Fuji-Xerox XP-11 (Xerox 3030) Toner / OPC
6R281/13R32, 20k Under switched off printer press and keep the button of the unset, residing near by cord of the feeding; include the printer.
Procedure alike for both cartridges
Sep 02, 2009 | Xerox Office Equipment & Supplies
I have a Xerox XD125F Workcentre. The J2 toner
1. turn off XD125f
2. Turn on
3. within 4 seconds press, clear, auto, clear, auto. LED Should go blank,
if not try again
4. use copy quantity keys to enter 24, then push start
5. Again use copy quantity keys to enter 7, then push start
6. turn off
when you restart the cartridge count will be set to zero
I have done this twice and never replaced the drum cartridge.
Jul 24, 2009 | Xerox Office Equipment & Supplies
Xerox Documate 252, just quit working
The flashing green light has the following meaning:
• Blinking green: indicates the scanner is waking up from power
saving and preparing to scan.
• Steady green: indicates the scanner is ready to scan.
How to Adjust the Power Save Settings for the DocuMate 252
1. Right-click on the One Touch icon and choose Show
Hardware from the pop-up menu.
You can also click the scanner icon at the top of the One Touch
Button Panel.
If the Hardware View of the panel is open you can also right-
click on the DM252 icon.
The Hardware Properties dialog box opens and shows
information about your Xerox DocuMate 252 scanner.
2. Click the Properties button.
Your scanner has a built-in power saving feature that is set to
power down after 15 minutes of idle time. You can change the
time before the scanner powers down, from 1 minute to a
maximum of 3 hours.
3. Click the arrows for the Lamp timeout setting and choose a
time setting.
To return the scanner to its factory settings, click Reset Device.
4. Click OK to save the changes and close the dialog box.
Let me know if this solves the problem and thank you, Binary Bob
Dec 09, 2008 | Xerox DocuMate 252 Path-Through Scanner
We have a xerox 2520, that has a J2 error code. We can't fix a service rep locally.
1. turn off XD125f
2. Turn on
if not try again
6. turn off
Sep 16, 2008 | Xerox Office Equipment & Supplies
PCD 3030
i have this camera but i need a memory card how much do they cost
May 18, 2008 | Polaroid PhotoMax PDC 3030 Digital Camera
Konica 4155 print shift
You need to enter a service mode. Holding down the "3" and "6" turn on .Enter "92" press copy button then press "P" when the copy quantity indicator flashes a number enter using the number keys a smaller or larger number.turn off then on.
Mar 17, 2008 | Office Equipment & Supplies
Printing on CD labels seem to ruin fuser in Phaser 7300
Probably the labels have a slight plastic fiber or coating in them and is getting a coating on the heat roller.
Here are part numbers of the correct CD labels you can run without a problem.
Xerox Matte Coated CD Labels, 6-Up, 11x17
Reorder 3R12373
75 sheets per box
spacer.gif Other items to consider: Return to Top spacer.gif Item Color Price/Unit Quantity Xerox Gloss Coated CD Labels, 6-Up, 11x17
Reorder 3R12372
75 sheets per box
Item Color Price/Unit Quantity Xerox CD-ROM Glossy Coated Labels, 4 x 7
Reorder 3R6322
50 CD-ROM Labels, 25 Sheets per carton
White - Glossy Coated 1-9 Box $17.44 10-49 Box $16.90 50-99 Box $15.65 100+ Box $14.89spacer.gif
Feb 22, 2008 | Xerox Phaser 7300DN Laser Printer
44 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
