Question about Microwave Ovens
Where can I get a waveguide cover for my Sharp R330EW microwave and about how much should I pay?
    Guru:
  • 1,524 Answers
Bi Coastal Appliance Parts 1-800-673-1262
Posted on Nov 03, 2010
  • barbara bingaman Nov 04, 2010
    Thank you. They had what I needed.
I have a Sharp Carousel Microwave R-1460A. The disk on the ceiling, opposite the warming plate and about the same size, has severe burn marks (probably from food splatters). Any idea what that part is
see this indication and fix it. God bless you
  1. Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  2. Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity pain
Nov 08, 2013 | Sharp R-1460 Microwave Oven
Is it dangerous to use the microwave without a duct cover
Yes, the waveguide (duct) cover protects the waveguide and the magnetron from damage caused by grease and food particles getting on them.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the area is charred or chipped, the area will first have to be sanded smooth and cleaned and dried thoroughly.
If the cavity metal of the oven is cracked or split, you can use a small amount of steel-based epoxy such as JB-WELD to patch the crack or hole.
Once that dries thoroughly, you can sand it very smooth.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
You can order a new waveguide cover form
Encompass here.
Jun 06, 2011 | Sharp R-216 800 Watts Microwave Oven
I have a 2004 Sharp R-1214 1100 Watt Microwave and the card like removable 3 x 4 inch plate broke (almost like cardboard) and it covered the vented opening. I don't have a users manual so I don't know the...
That's the waveguide cover you're talking about. It covers the opening in the side of the cooking cavity where the microwaves enter. The oven will work without it, but if you don't have the cover in place, food particles can get into the waveguide and cause problems. You can buy a replacement here.
Feb 07, 2011 | Sharp R-1210 Microwave Oven
I REQUIRE A WAVEGUIDE COVER REPLACEMENT SHARP
Here's a link to the parts listing at searspartsdirect.com:
http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R120DK/0958/0123245?searchedModel=r-120d&blt=
The list also includes helpful schematic diagrams that you can print for future troubleshooting.
if you need further assistance, please post back and let me know. I hope this helps you.
Nov 03, 2010 | Sharp R-120D Microwave Oven
How do I install a waveguide in a Sharp microwave oven? The old one burned through because of corrosion beneath it. I sanded it & repainted with rust preventative paint. I don't want to break it during...
If you mean the waveguide cover, those are almost always mica or plastic.
They would normally install by sliding them into slots in the cavity or ceiling, and sometimes they are held in pl;ace with a plastic rivet, too.
If a waveguide cover is damaged, it should be replaced with a new one, not repaired in any way.
Arcing will occur, which can damage your magnetron, waveguide, and / or chassis.
If you mean the waveguide itself, which channels the microwave energy from the magnetron to the cooking cavity, that cannot be removed or replaced. They are welded in place. If the waveguide is bad, the oven has to be replaced.
We have quite a few Sharp service manuals which cover disassembly and parts lists, etc. If we have it, I can point you to a link to download it free.
Feel free to contact me directly with your model number.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
May 25, 2010 | Sharp Microwave Ovens
Sharp R403 microwave internal electrical short/fire
This is a simple problem & solution.
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Since your waveguide cover is damaged, it will need to be replaced. It provides important protection for the magnetron.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Jun 03, 2009 | Sharp R-403HW Microwave Oven
Magnetron tube and mica waveguide cover
Unfortunatey unless the unit is a high end oven by the time you pay for the parts and labor you could probably get a new one. Don't forget if you have to replace these parts already who knows what else is about to happen. I hope this helps you out.
Nov 26, 2008 | Sharp Microwave Ovens
My sharp r-510hw flashing like crazy
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 22, 2008 | Sharp R-510HW Microwave Oven
Waveguide cover
If it's damaged and cleaning won't take care of it, you can buy a new waveguide cover from Tritronics at http://www.wehaveparts.com
We have the full service manual at our site for your convenience:
http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
Feb 03, 2008 | Sharp R-820B Convection/Microwave Oven
Microwave Ovens Logo
94 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
