Question about Dishwashers
Hi,i have a ariston ls 2020 dishwasher,it has started leaking water underneath,i have checked drainage and water fill but these are ok, it now trips out when you switch it on,could it be a seal
3 Suggested Answers
  • 883 Answers
SOURCE: my dishwasher trips out on certain cycles
sounds like faulty wiring inside unit. your circuit breaker is detecting an overload current condition...must look inside for wire touching frame. if none found, then wire fault may be inside of a device like motor or solenoid, so check these with ohmeter to ground-each wire (except chassis gnd) must be isolated from ground.
Posted on Jun 05, 2007
SOURCE: Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Posted on Apr 26, 2010
Ariston LS 2020 dishwasher is tripping mains switch at several points of washing cycles. What's wrong with it?
It probably uses more electrisity than there is avaliable at peak preformance. It is safer to contact an electrician to have him measure the use of electrisity and why there is this sudden use.
Jun 14, 2010 | Washing Machines
Apr 26, 2010 | Ariston Technologies Dishwashers
Zanussi dishwasher it starts filling with water and then trips the fuse board trip switch
Check the heating element for leak/short to ground. If trip happens as water goes above a point that is broken.
Sep 09, 2009 | Dishwashers
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Need to find parts dealer for Ariston dishwasher
Please let me know where I can order replacement part for LI 700-NA I need a water valve, serial number of that part 409245172. Thank you
Feb 02, 2009 | Ariston Technologies Dishwashers
Hi had trouble with water tap feeding dishwasher , was leaking
it trips the safety switch because the machine is unsafe
call an electrician to do an insulation check , wiring and component check
Nov 18, 2017 | Siemens 24 in. SE25A091 Hi-Line...
Favorit 44070Vi 3 short warning tones
It is most likely to be the wash pump leaking underneath, the float switch lies underneath the dishwasher, if you tip it back slightly you will probably find that water will leak out, that will prove that it is leaking and it will probably work a couple of times after this but it isn't the answer i'm afraid, a wash pump is not really the sort of thing you should tackle yourself.
Nov 26, 2007 | AEG 23 in. Favorit 44070Vi Built-in...
Ariston LS 620 A Dishwasher
Since, the pump doesn't stop working, it sound like a water level switch issue. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. Good luck !
Aug 13, 2007 | Ariston Technologies LL64WNA Built-in...
My dishwasher trips out on certain cycles
Jun 05, 2007 | Ariston Technologies L63SNA Stainless...
Ariston dishwasher LL64
usual place for a leak is thro the door main seal but it is possible to get a leak thro the dispensor. only way to check is split door, put it to work and see if it leaks in dispensor area
Mar 31, 2007 | Ariston Technologies LI640S Dishwasher
Dishwashers Logo
54 people viewed this question
Top Dishwashers Experts
Mike
Marvin
Marvin
