Looking for decent online tutorials about Macs. IT guy in mac environment - need to know more about servers, networks, how best to set up macs. English second language. Thanks
  • 39 Answers
Http://www.macinfo.com/
http://www.info-mac.org/
Posted on Jun 13, 2008
HP CP2025 Printer for Mac is Offline. How do I get it back Online? thx
How do I turn on the color for th cp2025. I have a mac with snow leopard
Dec 11, 2010 | HP Color LaserJet 2600n Printer
We have four computers, 3 Macs and a PC networked via an Apple Time Machine to a Hewlett-Packard HP Color LaserJet CM1312nfi MFP. All of the Macs display "Looking for Hewlett-Packard HP Color...
You should update your printers firmware and reload both Mac and windows drivers for the same printer. I look at this as more of a driver problem. Firmware and drivers can be located here. If problem persists, try to approach this instance by using the elimination method. remove pc from network, test with only macs connected. then remove macs and test with only PC connected. then finnaly, install this printer directly to pc and test the performance and then directly on one of the macs and test.
Regards
Nov 23, 2010 | HP Office Equipment & Supplies
Problems setting up new macs and a new wireless system with a PC
The MAC address of the network card on the PC is probably registered with Tiscali. The easiest thing to do is to Connect the Belkin router to the internet, then go into the config and clone the MAC address of the windows PC. Once this is done, then you can either plug in the airport express, or configure wifi for the Macs from the belkin.
Jul 23, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
I have Home Design for Mac in 9.2 classic. New Mac running 10.4 can't run it. Upgradeable?
If Abracadata is out of business, as it looks like they are, then probably not. Your best bet is to purchase a different software package designed for Mac OS X.
The Macintosh Classic environment will NOT run on Intel based macs. I am assuming your new mac is Intel. I actually keep a couple older macs around at work to run legacy software that isn't supported anymore, or is too expensive to upgrade.
Jul 16, 2009 | Abracadata Design Your Own Home...
Wont install on Mac i use leopard and it states it needs classic envinroment
"In any case, you will not be able to use the Classic Environment in any OS with your MacBook Pro. The Classic Environment functions only on PowerPC-based Macs, of which the MacBook Pro (and all other currently sold Macs) is not. Mac OS 9 was never designed for Intel Macs, and cannot run on them without full PowerPC hardware emulation."
Hope it helps
Jun 20, 2009 | Scholastic I Spy Collection for Windows,...
BizHub won't send scans to Macs
first, int the mac must have the "share for windows" checked, in the network settings.
second, you'll have to create a folder name SCAN into the 'home' folder onto your mac. then , you ll have to have your user and password of your mac.
then, you ll have to enter in the bizhub:
- Ip of your mac
- gateway of your mac
- mask of your network
on the copier
- in the utiliy/counter // register 1 touch, book adress, SMB (don t remeber exactly the path .. but just not so far of these paths), :
IP server: Ip mac
path : SCAN
user: user'sMAC
password: password of the user's mac (CAN NOT BE EMPTY)
and ormally, that's all folks :-)
Dec 03, 2008 | Konica Minolta bizhub C351 All-In-One...
HAVE A PROBLEM WITH SLOWWWWWW NETWORK SPEED ON IMAC INTEL
Sounds like you have a problem with the OS X software, try reinstalling the OS using the archive and install function
Oct 26, 2008 | Computers & Internet
Home Networking
Is the laptop an xp machine? If so:
In order to access shared files on a Windows XP computer (or any computer running Samba) from a Mac, the Mac will need to "connect" to the Windows XP computer and "mount" the shared files.
Instructions:
Start at the "Go" drop down menu at the top of your screen, then "Connect to server".
If the computer you wish to connect to is listed, just select it from the list.
If the computer is not listed, type into the "Server Address" field 'smb://' followed by the computer name or IP address of the computer to which you want to connect.
Click the "Connect" button in the bottom right corner of the window. See more at the link below:
http://www.mac-connect.com/win_from_mac.php
Jul 08, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Macintoshes and Print Servers, the PS110 in Particular
Topic 1. What do I need to connect a Macintosh to the PS110 Print Server? A PostScript printer with a parallel interface, a Mac running MacOS 8.6, 9.x, or 10.x. (NETGEAR products are not supported for earlier versions.), and Ethernet cables to connect the Print Server to the printer, and the Print Server to your Macs, and to a router. NETGEAR's RP614 router is known to work connecting the PS110 to the Internet with Macs. Topic 2. How do I avoid losing my network configuration when restarting my Mac? When changing theMacOS configuration it is best to use Configurations (MacOS 8.x or 9.x) or Network Location (MacOS 10.x) settings instead of changing settings for each category (TCP/IP, AppleTalk, AirPort, etc.). That way you can be sure the changes will not be lost after rebooting. To Create a Configuration in MacOS 8.x or 9.x 1. Open AppleTalk (or TCP/IP) from the Apple Menu in the upper left-hand corner of the screen. 2. Select File > Configurations > New Configuration. 3 . Type a meaningful name for your new configuration (e.g., NETGEAR Wireless Router). 4 . Make your changes to the AppleTalk or TCP/IP settings. 5 . When closing AppleTalk or TCP/IP choose Save Changes. Whenever making Configuration changes for settings in MacOS 8.x or 9.x, open File > Configurations or press Command-K. Changes in Configurations are saved after rebooting. To Create a Network Location in MacOS 10.x 1. Open the Apple Menu by clicking the Apple icon in the upper left of the screen. 2. Select System Preferences. The System Preferences window displays. 3. Click Internet & Network > Network. The Network Settings window displays. 4. If the window is locked, click the Lock icon in the lower left to unlock the Network window. (You may be asked for a username and password.) 5. Click the pull down menu next to Location at the top of the Network window. 6. Select New Location. 7. Type a name for your new location and click OK. 8. Make your changes to the TCP/IP, AppleTalk, and AirPort settings. 9. Click the Lock icon in the lower left to prevent further changes. The Apply configuration changes window displays. 10. Click Apply to keep the configuration changes for the newly-created location. 11. Close the Network window. Topic 3. How do I connect a Mac to the PS110 Print Server? For MacOS 8.6 and 9.x 1. Follow the instructions in the NETGEAR PS110 Installation Guide coming with the Print Server. (The CD is not needed unless you need the Reference Guide.) 2. Connect the PS110 Print Server to the PostScript printer with a parallel interface. (You cannot use non-PostScript printers with Macs on the PS110 Print Server.) 3. Connect the Print Server to the Mac. 4. Install the Printer Driver for the printer to be used with the PS110 Print Server on your Mac. 5. Open Chooser from Apple Menu. 6. Select LaserWriter 8. 7. Select the PostScript Printer to use. (This is probably the description for the PS110 Print Server and may have a name like ?PSD90335?. This name may be different on your computer.) 8. Click Setup. 9. Click Select PPD. 10. Select your printer from the Printer Descriptions list. 11. Close the Chooser. 12. Click OK. A message displays: ?You have changed your Desktop Printer.? You can now connect to the RP614 Router Gateway, and to the Internet. For MacOS 10.x 1. Follow the instructions in the printed NETGEAR PS110 Installation Guide coming with the Print Server. (The CD is not needed unless you need the Reference Guide.) 2. Connect the PS110 Print Server to the PostScript printer with a parallel interface. (You cannot use non-Post Script printers with the Mac and the PS110.) 3. Connect the Print Server to the Mac. 4. Install the Printer Driver for the printer you will be using with the PS110 Print Server on your Mac. 5. Open Utilities > Print Center in the MacOS 10.2 Applications folder. The Printer List appears. 6. Click Add. The Printer Selection window appears. 7. From the top of the Printer Selection window, select AppleTalk from the first pull down menu. 8. Select Local AppleTalk Zone from the second pull down menu below. 9. Click the Print Server from the list in the window. PSD90335 ? PostScript Printer in the case of this test. 10. Click the pull down Printer Model, and select the model of printer connected to your Print Server. A list of printers displays. 11. From the scrolling list select the Model Name of the printer connected to your Print Server. 12. Click Add. 13. Printer List displays with the list of printers and print servers connected to your Mac. Select the name of the Print Server from the Printer List. 14. Click Make Default. 15. Close the Printer List. 16. Open a file and try printing it. You can now connect to the RP614 Router Gateway, and to the Internet.
Feb 19, 2006 | NetGear RP614 Router
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
