It's a clear and fully detailed guide on how to unlock a BlackBerry 9780 :
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Device
5. Select Advanced System Settings
6. Select SIM Card
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE : BLACKBERRYMEP.COM
Just received the code and it works, thank you !
Hi
To unlock your phone you must provide not only the IMEI but also the Mep.
If you don't have, this is a small tutorial on [URL="http://www.unlockingcellphones.net/2012/03/how-to-get-your-blackberry-imei-mep.html"]how to get your BLACKBERRY imei & MEP[/URL].
After that use the [URL="http://www.unlockingcellphones.net/2012/03/how-to-unlock-blackberry.html"]blackberry code calculator[/URL] to generate the code.
Good luck.
Thank you very much.
http://blackberrymep.com is reliable.
Its not possible that you can get code here free which is generate from server based on your IMEI
http://blackberryunlock.mobi/
Hello
you can get Blackberry 9780 MEP unlock code from this Blackberry MEP unlock code provider to use your Blackberry with any GSM SIM card around the globe,
i hope this provider will help you for unlocking Blackberry device,
thanks
You can Unlock your Blackberry with imei unlock code. it is very simple and eaisiat way to unlock your Blackberry . get your Blackberry Imei Unlock Code . and use any gsm sim card.
i hope this will help you .
Blackberry can be unlock eaisly with remote unlocking codes. you can get this Blackberry imei unlock code from your network provider or get from third party,
both are safe way to Unlock your BlackBerry 9780.when you go to online you can find so many sites of Blackberry imei Unlock Code. they will charge little amount for your Blackberry Unlocking Codes. i hope this will help you:)
Best of Luck.
You have to unlock you blackberry 9780 from any mobile shop or websites which provide blackberry 9780 unlock code. Once you unlocked it with unlock code you can use it with any GSM network in the whole world. Through website you can get unlock code within few minutes from the comfort of your home & also at cheap rates compare with other ways (THAT IS GET UNLOCK CODE FROM A MOBILE SHOP). All you need to do is go to any website which offering the blackberry 9780 unlock code & order your unlock code by entering your imei number & network which your blackberry 9780 locked to. You`ll get your unlock code through e-mail with in you few minutes with instructions of entering the unlock code of blackberry 9780. That`s it your blackberry 9780 has unlocked & then you can use it with any GSM Sim card around the globe. This the best way among me to unlock your blackberry 9780.
You can unlock blackberry 9780 from your current network with blackberry unlock code. This code will reset your phone network configuration to default factory setting and you can purchase that code at third party sites on internet.
The best way to unlock your Blackberry is to buy unlock codes from a trusted vendor.
Search internet for mobile phone unlocking websites. You will come
across a thousand websites who can do this. Choose which ever you like.
Do look for price comparisons and the unlocking instructions.
Recheck the Model number- Network to which your phone is locked to and
the IMEI number before placing an order. If you made any mistakes in
these details these people will never give you a refund!!
One more thing, before placing an order ask them about the conditions
for getting a full refund in the case of a code failure! Think and make a
wise decision.
I have personally bought the code for my Blackberry 9780 bold from unlockgenie.com.
It is because they have good reviews on most of the mobile phone
forums. I got my phone unlocked successfully from that website. Try the link http://unlockgenie.com/
ryan, nice comment. the webaite is very good. The code did work.
No one can give you unlock code for free. and dont try to enter unlock code. because it will block your blackberry. if you want to unlock your blackberry only use trusted sites. order your Blackberry 8520 curve unlock code herehttp://blackberrymep.com/unlock-blackber... this site charge very reasonable price.
