Question about Dryers
I have a gle02152es0 figidaire dryer. As soon as I turn on the dryer with heat it goes off and gives me the error code PF. I can select no heat and everything else runs fine. The control board in it is new ( just replaced it ). Any suggestions or do you have a wiring schematic for it?
  • 1 more comment
  • eddiea1953 Nov 03, 2010
    Pulled Thermistor and it reads 50k exactly...
  • eddiea1953 Nov 04, 2010
    Found the thermal limitor was open...ordered new one... will let you know if that fixes the problem.
  • eddiea1953 Nov 09, 2010
    I got my thermal limiter in and replaced it... the dryer still does the same thing ( runs for about a second and the turns off and says PF ). If I run it through the troubledhooting program , it gives me an error code of E9E. But I don't see that code listed.
    Thanks
    Eddie
  • Dryers Master
  • 8,220 Answers
Check your thermister. It should be 50k ohms no more no less.
Late model Frigidaire service manual: Good and better models page 57
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 03, 2010
  • Dan Webster
    Dan Webster Nov 03, 2010
    I would start hunting for open components. If the control is new then one of the safety's are open or you have a bad/shorted heater element.
  • Dan Webster
    Does your dryer feature electronic sensing? Their could be junk on the sensor strips preventing the control from sensing moisture. It might think the clothes are dry. Clean the sensor strips with windex and retry.
My whirpool dryer panel comes on but when you push the start button!, it clicks off and then displays the pf code.
PF is a Power Failure error meaning electricity has been interrupted to the machine.
Any electrical interruption to the machine such as a circuit breaker being reset or weather related power outage can cause a PF error code.
To remedy;
Press the Pause/Cancel/Stop button twice to clear the PF in the display.
Try to start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button.
If you continue to receive the PF error code, the control board may need to be replaced
Apr 23, 2015 | Dryers
Tip
PF Error Code for Appliances
<p><br /> <p>There is one<b> <i>Error Code that is almost universal to most any appliance</i></b>. The<b> PF or Power Failure code</b> is usually the same no matter what <b>type of appliance</b> or <b>brand</b> you are working with. Even with the fact that this <b>error code is so common</b>, I still see many questions on <b><i>www.Fixya.com</i></b> that are asking <b>what the PF Error Code means</b>.<br /> <p><br /> <p>So now the next question is this.<br /> <p><br /> <p>What causes the <b>appliance to give you the PF error code</b> in the first place?<br /> <p><br /> <p>The most common cause of your <b>appliance giving you the PF error code</b> is a problem with the <b>power coming in from your utility company</b>. Of course if there is an <b>interruption of power</b>, and then the power comes back on you will get the<b> PF code</b>.<br /> <p><br /> <p>Some <b>appliances will give you the PF code also if the power voltage goes low</b>, or goes into a <b>brownout</b> condition. Depending on the sensitivity of the <b>appliance control</b> you may also get the PF code for other reasons such as <b>frequency problems</b> or <b>voltage fluctuations</b> or <b>power spikes</b>.<br /> <p><br /> <p>The other <b>problems that can cause the PF error code</b> can be internal to the appliance.<br /> <p><br /> <p><b>Loose wires going to the circuit board</b> or the control can also be a <b>cause of the error code</b>. If a <b>wire terminal end</b> happens to get <b>corroded</b> or loose, the <b>vibration from the machine</b> can cause slight power problems and this can <b>cause the PF code to be displayed</b>. Finding the cause of this type of problem is like finding a needle in a haystack. Sometimes you can cause it to be displayed by <b>banging on the side of the appliance</b> or <b>slightly moving the wiring harness</b>, to see if you can get the error code to display.<br /> <p><br /> <p>The bottom line about this <b>power failure error code,</b> is that it is <b>power related</b>. Finding the exact cause can be difficult. If you are continually having to <b>reset the appliance</b> then check to see if all of your appliances are giving the same code. This will indicate <b>utility power problems</b>. If only <b>one appliance is giving the PF code</b> then it is probably internal to the appliance.<br /> <p><br /> <p>
on Mar 06, 2011 | Refrigerators
What is wrong if my Frigidaire front load dryer
Thank you for your inquiry, friend!
I understand that your Frigidaire dryer has been providing you with an error code "PF". Typically "PF" stands for power failure this can happen if power is shut off during a cycle or the dryer receives insufficient power, which could be an issue with your power cord or control panel. Let's perform a reset on your dryer and you can do this by unplugging the power cord for ten minutes. If you need any additional assistance please feel free to reconnect. -Matt
Oct 14, 2014 | Dryers
My Maytag Neptune Dryer stopped running & is
as per heatman The most common cause of your appliance giving you the PF error code is a problem with the power coming in from your utility company. Of course if there is an interruption of power, and then the power comes back on you will get the PF code Loose wires going to the circuit board or the control can also be a cause of the error code. If a wire terminal end happens to get corroded or loose, the vibration from the machine can cause slight power problems and this can cause the PF code to be displayed. Finding the cause of this type of problem is like finding a needle in a haystack. Sometimes you can cause it to be displayed by banging on the side of the appliance or slightly moving the wiring harness, to see if you can get the error code to display.
The bottom line about this power failure error code, is that it is power related. Finding the exact cause can be difficult. If you are continually having to reset the appliance then check to see if all of your appliances are giving the same code. This will indicate utility power problems. If only one appliance is giving the PF code then it is probably internal to the appliance.
Jul 12, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a Kenmore Electric Dryer Model 110.60072990. When I press the touch pad on the Select Cycle to select the temperature nothing lights up on the selection or the timer. When I flip the house breaker...
From what you mention, my take on the issue is that a Fuse or board will either work or not work.My guess is a loose connection or damaged cord somewhere. Assuming you are not electrician , what I would suggest is just to check the cord from the wall outlet to dryer and look for any bends, or damage to the cable, WARNING do not touch it while still connected to outlet if there is any sign of damage. Also use a hair dryer as an example , and just plug it into the outlet to check if the electricity outlet itself, has not perhaps failed.Failing this, a loose earth connection, or wire to unit might have failed and best bet here is to have an appliance person check it over, good luck
Feb 02, 2018 | Dryers
Pf code..no heat
Here is a tips that I wrote that will help to explain why you get the PF Error Code
heatman101
Feb 23, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
PF Code as soon as try to start dryer, you get the code when select the time
heatman101
p[[p
Mar 14, 2010 | Whirlpool WED6200S Electric Dryer
Neptune Dryer PF Error Code
PF is a 'Power Failure' code meaning the dryer power may be interrupted. The plug receptacle may be bad. Check the plug for proper tension. If feels loose, have the receptacle replaced. Inspect the plug for discoloration. (a sign of a bad receptacle). If all looks OK, Check the power connections at the dryer. If looks OK the electronic control may be defective.
May 31, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
100 people viewed this question
Top Dryers Experts
