Question about Philips Televison & Video
Its a 52 in phillops it wants to shut off by its self and dosnt want to turn back on
    Master:
  • 788 Answers
When a TV shuts off it usually means one of two things.
1) It's circuitry is protecting itself from heat, in this case it could be something as simple as opening up the TV and blowing out the dust.
2) It's circuitry is not receiving enough power to start the TV. This could be more difficult to diagnose. You could start by examining the circuits to look for any obvious burnt out or broken components. If you do find something of the sorts then you could try to source out a replacement for that specific board. If nothing obvious is wrong then some testing of individual components is required. Often it's a diode that is faulty, you can test these by using a multimeter, there should be very little resistance in one direction and very high resistance in the other direction. Use your multimeter to test this resistance than switch the probes to test the diode in the other direction. If you find a diode that has the same resistance in both direction replace it with a part from an electronics supply store. Diodes are usually marked by D and a number on the silk screening of the PCBs, for examble D10.
It would help if you could provide the correct model number of your TV and a description of the sounds the TV makes when you try to start it and the status of the LEDs on the TV as it tries to turn on then shuts off. You should also try a different electrical outlet and eliminate any power bars or UPS's you have the TV plugged into to make sure they are not causing your problems.
Posted on Jun 13, 2008
    Genius:
  • 2,785 Answers
Its may be due to problem of the powersupply unit of your board plz check it with some professional
  • 796 Answers
Check your thermal fuse...
it may be causing your tv to get it turned off by its own wish.
    Genius:
  • 3,422 Answers
HI,
Did you try a hard reset by unpluging all the cords from back for 4 hrs?
    Guru:
  • 1,894 Answers
Did u try a hard reset?
  • dewan nafees ahmed Jun 13, 2008
    may be it is shutting off to protect itself from any kind of short circuits.
    this can be due to some kind of short in your power board which makes the relay trip and shut off the unit.
    thank you
My 2008 Samsung 52 inch keeps turning off and on. sometimes it won't restart
U have power supply issues. That accounts for set shutting off. Or you could have an issue somewhere else in set and it is programmed to shut off rather than self destruct. Would check out the PS first though.
Jun 22, 2015 | Samsung Televison & Video
Ford focus 52 plate The front headlights don't
Switch will have to be replaced,
Nov 10, 2012 | Cars & Trucks
The t.v shuts its self off
How long does it take to switch off,and is there sound when switching off
Nov 13, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv works for about 10 mins then shuts its self off, if let to sit for a while can turn back on and works for about 10 more mins then turns its self off again, is it over heatings? or are the capasitors...
Hello
You mostly see this when the bulb is bad. I dont remember the tech answer however changing the bulb fixes 95 percent of them. It is possible your power supply is going bad as well, but you would probably see problems trying to get the tv to come on.
Good Luck
Nov 24, 2010 | RCA HD52W56 52" Rear Projection HDTV
I turn on my TV and 10 minutes later it turns off by itself. What is the problem
generally this model shut it self down if anything major. possible reason for a delayed shutdown is bad capacitors. or loose connections. does the picture display any abnormalites before shutdown. does it come right back on when you push power button. any sounds or smells? how long has this been doing this?
Oct 13, 2010 | RCA HD52W56 52" Rear Projection HDTV
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
Tv will not stay on
there is nothing you can do but get rid of it
Dec 26, 2008 | RCA P52920BL 52" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
