Question about RCA P52960 52" Rear Projection Television
I have model RCS P52731wk. No power when i puch the power button on the front. Is there an internal fuse?
    Top Expert:
  • RCA Master
  • 14,553 Answers
THERE IS A FUSE, it is located inside where the power cord connects.
Let me ask does power light come on for just a moment at all?
SD TECH
Posted on Nov 03, 2010
What does the ADR button on the RCS-4VPIS4U do?
Address Switching by the Google of it. Full make and model are useful in such questions.
Sanyo CH2442 Installation Instructions Manual Page 54
https://www.plessers.com/photos/p/00017/170661.pdf
Not a lot of help with just that model number. Google is your friend in such questions. Google knows everything. In the 20,129 questions I have answered, only 1 turned up a 'Googlewhack', nothing at all, No Results.
RCS 4VPIS4U Google Search
Jun 13, 2018 | Televison & Video
The fan that controls the A/C and heater is stuck in the on position & running full blast. Puching the off button or manually puching the fan buttons does not do anything. The fan continues to run full...
Sounds like a problem with the fan switch. If you can find the fuse for the blower motor, you could pull the fuse to stop the fan until you can get the problem fixed.
May 09, 2011 | Infiniti QX4 Cars & Trucks
When i puched the power button turned red so i turned it on and off it was working fine i was playing then it froze i puched off on it showed the problem note
Hi
please tell us the make model and operating system that you have please
and what you were doing at the time that it froze
also is it a recent problem or a lingering problem
many thanks
Mar 06, 2011 | Computers & Internet
Is there a reset button for rca tv model p52731wk
You can try a hard reset with this model. It requires unplugging it and leaving it unplugged for at least four hours. There are numerous set codes for this model, but it all depends upon the problem you are experiencing. There is no singular "reset button," though, as the system was simply too complex in its day to warrant one.
May 09, 2010 | Televison & Video
Frigidaire model # FDE336RES2 Wont turn on.
The fuse is located on the rear wall upper right hand corner. To get to it you must bust dat dryer down. HERES HOW
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 11, 2009 | Frigidaire FGR341AC Electric Dryer
Commercial dryer model #MDE26CSACW won't start
near fan blower ,had a fuse white by pass than try if work change it than clean the vent
Nov 13, 2017 | Maytag Neptune MDE5500AY Electric Dryer
Possible fuse -- no power
Replacing a fuse Locate your fuse. Most microwave fuses look like the one pictured to the left. They are usually an inch or two long. Each end is metallic and the center is either ceramic or glass.
To get to the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board.
Decide if your fuse is blown. A blown glass fuse will produce flash burn marks on nearby surfaces, or it will be completely black on the inside. The internal fuse wire (filament) will be melted and blackened. Ceramic fuses give no outward signs of having blown. To determine if a ceramic fuse is blown, test it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is fine. A reading of infinite ohms means your fuse is blown.
Replace the blown fuse. Pop it out of its holder and snap in a new one. You can squeeze the fuse clips together with your fingers in order to tighten their grip. Replace the unit's outer cabinet, plug it back in, and test to see if it is running properly. DO NOT run the microwave with nothing in it.
NOTE: Fuses do not usually blow on their own. A fuse may blow because of problems with the interlock switches or with high voltage circuitry. It is also possible, though rare, that a power surge will cause a fuse to blow.
Jun 05, 2008 | Amana RCS 10D 1000 Watts Microwave Oven
RCS 14F512T 14" TV
possibly one of the switches behind the front buttons is shorted;
could one of the front buttons be pushed in and not releasing-maybe the power button?
Apr 29, 2008 | RCA 14F512T 14" TV
RCA P52960 52" Rear Projection Television Logo
145 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
