Question about Sony FD Trinitron WEGA KV-36HS420 36" TV
COLOR PROBLEM The picture lost the green color. every thing thats supose to be green is like a brownish color.
  • hacsta Jun 13, 2008
    thanks i pulled the cables out and plugged them back in and everything is great.
    Novelist:
    Champion:
  • 203 Answers
First thing to check is if you are using component video input, try another set of cables. Sometimes the y or Pb or Pr connections not making a good connection will cause loss of a color. Try another input is another way to check this. On a few earlier models like this I have seen a weak crt cause this. In which case you can rejuvinate it or adjust the color drives and bias located in service menu, but don't change the values if you're not posative it is the right solution for your problem. Hope it's something simple on this one, Russmann.
Posted on Jun 13, 2008
My Hitachi 65F59 has a very low green level. If I set the tint all the way on Green, I see some small amounts of green spots on scenes, but scenes which should be completely green are mostly a beige ugly...
SUGGESTIONS TO RESOLVE WHERE THE PROBLEM IS:
1. GO TO A BLACK AND WHITE CHANNEL OR PROGRAM AND TURN THE COLOR IN THE CUSTOMER MENU ALL THE WAY DOWN.
IS THE PICTURE BLACK AND WHITE OR REDDISH ETC?
iF THIS IS THE CASE I CAN TELL YOU HOW TO ADJUST THE SET MANUALLY--NOT WITH THE REMOTE BUT IN A DIFFERENT WAY.
I am here to help people and if this helps you rate this solution as very helpful as I do this here for free.
Make the check to see if you have a BW picture or not, if not respond and I will tell you how to adjust---it will take about ten minutes to do it.
REGARDS, SD TECH
Aug 13, 2010 | Hitachi 65F59A Television
Hitachi Projection Color TV 43FWX20B - COLOR OFF
Check all cables,replaced all cables if more than couple years old.After that the same,ur tv have one dead color gun,require service.
Jan 01, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 61SBX59B 61 inch has brightness and color problems
I would say the crt's are at the end of their life.
Sep 09, 2009 | Televison & Video
My 48 inch jvc tv has a green color to it what can this be and how can i get it fixed
Okay so the green color that you see on the screen is because the coolant inside of the green picture tube is gone bad (it suppose to be cristal clear but now it is brownish and that makes the green color run all over the screen.) That just happens over time and I'm guessing the picture tubes have never been serviced. Now you got two choices
1- The easiest and fastest way would be to take it to a local repair shop and have them service the coolants of your picture tubes. I'm guessing it would run you about $165 or so to get them done (the three of them red,green and blue)
2-On the other hand you can do it yourself. It is not hard at all but it does require a lot of attention.
After the picture tubes have been serviced you'll notice the big difference.
You'll actually have a much brighter and sharper picture just like when it was new.
Let me know if you decide you want to do it yourself so i can post the instructions for you.
Jul 13, 2009 | JVC AV-48WP74 48" Rear Projection...
Canon i860 won't print deep colors
I had similar problem: everything muted and with brownish tint. Tried everything, finally discovered that I installed wrong cartridge: 6PC instead of 6C. The "photo" cartridges are pretty much the same, make sure you have the right ones: 6C, 6M, and 6Y.
Nov 17, 2008 | Canon i860 InkJet Photo Printer
White colors schemes seem off white color or brownish color and blue has green tint or baby blue color. .
Check the coolant in all three crt's as chances are it is contaminated (should be crystal clear). If brown (beer color), replace coolant in all three crt's and perform convergence adjust. Picture should be like new!!!
Good Luck!!!
Jul 20, 2008 | Akai PT5598HD 55" Rear Projection...
Red and green colors not coming through in picture
Bad crt
Sony Picture tube recall
http://esupport.sony.com/perl/news-item.pl?news_id=24
Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700
Feb 04, 2008 | Sony KP-51WS510 51" Rear Projection...
Tv has a brownish green tint to it
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Dec 03, 2007 | JVC AV-56WP30 56" Rear Projection...
Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Loss of color - all green
yes! the problem is in the CRT board the RGB colors! you have lost of blue and red! thats why your unit is green! and only green is worked the blue and red is not work! maybe you have lost contact of them! resolder all CRT board to comeback the normal picture!
Sep 28, 2007 | Panasonic PV-C2061 20 in. TV/VCR Combo
Sony FD Trinitron WEGA KV-36HS420 36" TV Logo
121 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
