Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
TV comes on for 3-4 seconds and then turns off. The power light then blinks 3 times and then pauses, then 3 more blinks ans pauses.
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
3 blinks is short protection and 98% chance one of the resistors in the convergence circuit is gone.
I can tell you what to look for and if confirmed how to fix set. If the usual problem total parts cost on EBAY will be well under 25 dollars.
If one of the resistors is bad, I have step by step start to finish instructions I can provide for this repair, for most it is a do it yourself job.
If you have questions let me know.
Regards, SD TECH
Posted on Nov 03, 2010
  • 7 more comments
  • skoppes9osu Nov 03, 2010
    Thank you for your help. What are the parts I would need and how much of a hassle is it to fix this issue? Also, I have read some other posts and they said when they changes the convergence parts they still had issues. I am just wondering if the hassle is going to be worth it.
  • SD Tech
    SD Tech Nov 03, 2010
    I have a suggestion, do you have Yahoo IM?
    No sorry. I have gmail chat.
  • SD Tech
    Let me make this simple.
    With set unplugged and back off locate the two chips (I will attach photo) and in front of them are a number of light blue resistors. A visual look will tell if any are bad, they will be white in the middle or discolored. Follow me?
    The repair consists of getting at them, there is right and wrong way to do this if you have minimal skills and can take instructions you can fix it yourself.
    Confirm first if discolored resistors. Repair is going to take you about one hour and I know best place to get the parts. If want give me email and we exchange information.
    SD TECH
    THE TWO CHIPS IN YOUR SET WILL LOOK LIKE THIS BUT HAVE stk-392-110 NUMBER ON FRONT.
    SIDE BY SIDE ON METAL PLATES WITH FINS. THE RESISTORS WILL BE IN FRONT AND AROUND THEM AND MOST WILL HAVE 2.2 PRINTED ON THEM (2.2 OHMS)
    Ok, I see the resisters. I'm not sure how to tell if they're bad or not. They all look identical and are a white-ish color.
  • SD Tech
    listen carefully, they are light blue in color, powder blue----a bad one will be discolored in the middle, white in middle.
    I think I found the one's that are bad. Would they be hot to touch after trying to turn the TV on? If so, I found two that are bad. Also, I found a convergence repair kit at www.tvrepairworld.com for $55. Is this what I want?
  • SD Tech
    forget the kit, it is a ripoff.
    On ebay you can get the two chips and resistors for well under 20 dollars.
    I make suggestion, provide me a email and I send the instructions to you for free, you read and decide if you can do. I not allowed give my email here but nothing to stop you.
    Those kits contain parts you will never need, a waste of money.
    SD TECH
    skoppes9osu@gmail.com
The power light is blinking red and the V will not turn on.
Power light blinking red indicates tv got internal problem and went on protection mode.
Please count how many times red light blinks after 3 seconds long pause as it is an error code that has info about defective section in tv and will help me to suggest any solution to fix the issue.
Thanks.
Oct 31, 2010 | Sony KDS-60A2000 60" HDTV
When the tv plugged up the power led blinks 3 times. When the power button is pressed the tv comes on for three seconds and turns back off. What could be the problem? Could this be a convergence problem?
Do the self check when power light goes out:
ON front of set (not remote) press and hold both the Menu and Input (Device) buttons at same time for 5 seconds or longer and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know code.
SD TECH
Sep 24, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Tv turns on then turns off and the standby led starts blinking
Standby light blinking is sign or internal problem in tv and how many times it blinks is error code that will show what section of tv got problem. Count light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 13, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Screen went black no sound no picture when i turn the power on power light comes on green i hear a click and then it goes blinking red
How many times red light blinks? It is error code of problem in TV.
There would be pause of 3 seconds between blinks so count from pause to pause and let me know to find out solution.
Aug 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Panasonic PT-53TW53G
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Aug 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
