Magnavox model 25TSC6 0101 able to get cable tv?
I am helping my sister get set up for cable on her tv above.
I would like to know if my Magnavox (Philips) tv will be able to be hooked up to cable tv (via cable wire) or would I need a cable converter box first?
Also I have an Insignia digital converter box bought already. If I do need a cable converter box, would the Insignia box allow me to get cable now?
Also, if we do need a regular cable converter box, can you please tell me where I might get one? P.S. I have only until Monday, June 16 to get an answer.
Thank you,
NM
  • csgjoint Aug 13, 2008
    will this exact model need a digital conversion box when all channels flip to digital in feb 09 or does this model have ATSC?
    thx!
  • 71 Answers
You should be able to connect the cable directly to the tv, do autoprogram from the setup/channel search menu.
Posted on Jun 14, 2008
Dvd/vcr recorder magnavox model mwr20v6, i got probelm hooking up my dvd/vcr recorder to my cable converterbox an tv , because i broke the antenne/ out socket on the back of the unit, how can i get it to...
Hi,If I understood correctly you broke antenna out socket of Cable box..ok no problem,your TV and cable box should have other jacs/socket for this connection as well..
Take the A/V output of your cable box into TV possibly with RCA cables..than you can select the channel thru Cable box on TV ..(AV mode needs to be selected on TV )
** in order to listen and watch your
magnavox DVD 's "2xRCA audio" and "1x RCA Video" cables "OUT" should go to Tv or Cable box "IN" connections separately ..("IN" goes to "OUT" of other ..pls remember,Always reverse connected ) (audio will come thru Receiver and TV.)
Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action if you wish to listen or RECORD a program on your TV on
magnavox
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV or Cable box .( every TV -cable box has different type of Audio out jacks )
** to "iRCA nput or "Optic Cable input"
of your
magnavox (whichever you want ,based on the necessary cables on your hand )
There you go..Tv/Cable box video and sound are both on the
magnavox for recording..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 15, 2011 | Televison & Video
CAN NOT GET CHANELLS ABOVE 13
Hi vince14,
Here is the adobe url for your users manual. I will be looking through it and get back with you momentarily to show you the procedure  for getting your tv to go to cable mode. Thank you very much for this opportunity to assist you.
http://www.p4c.philips.com/na4/2/27ms343s/27ms343s_dfu_aen.pdf
Oct 16, 2007 | Philips Magnavox 27MS343S 27" TV
I have the Phillips Magnavox 20MT133S and my cable TV provider is switching to an all digital format. Will I require the use of their converter box for analog TVs? In otherwords, is this TV a digital TV?
Hello David,
Unfortunately this is not a digital TV, so you will need a digital cable box in order to watch the digital format cable channels on this set.
Hope this helps. If you have any further questions, please let me know.
Regards,
BElectric
Feb 26, 2011 | Philips Magnavox 20MT133S 20" TV
I lost the manual to the magnavox dvd/vcr dual player so i dont know how to set it up. so i can watch dvds and vcr tapes.
The easiest way to hook up the combo is to use the cable in and out to tv connectors located in the rear. for this connection you will hgave to set the TV to Channel 3 or 4. You can usually download an owners manual from magnavox.com, you will need a model number.
Mar 19, 2010 | Philips Magnavox DVD/VCR Dual Player
I cant record tv through my vcr.
set the vcr up so that you change the chanels through the vcr,,,check the vcr setup menu
May 16, 2009 | Philips Televison & Video
Connecting
In general, you want to run red, yellow, white (composite or a/v) cables from the out of your sat box to the in of the Magnavox. Then run a 2nd set of r,y,w cables from the out of the Magnavox to the in of the TV (there may be one or several places to plug it into TV). If your sat box is an HD sat box, you probably won't get it to work with this Magnavox. This unit was jointly manufactured with Funai corp, so you will have to call 1-800-605-8610 for tech support.
Mar 26, 2008 | Philips Magnavox MWD7006 DVD Player
Magnavox TV
try retrevo.com they may have the User manual your looking for. Just enter the model number of your set.
Mar 19, 2008 | Televison & Video
Magnavox 20" tv with vcr and dvd, Model #CT202MW8
call comcast they should know the correct code its there unit.
Jan 17, 2008 | Philips Magnavox 20MC4304 20 in....
Smart lock access code on tv
A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number. If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental Access Code.
Sep 07, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Televison & Video Logo
147 people viewed this question
Top Televison & Video Experts
Electro Med Services...
