Question about E-Machines T1090 PC Desktop
Do not know
Have a 1090 when i turn it on the screen says no signal have tried a new cable
  • 66 Answers
No signal usually means no connection from your video card, make sure you properly inserted the cable from the video card and to your monitor... and check you don't have bent pin on the cable that you use.
Posted on Jun 13, 2008
Sony vaio pcg 4a1l blank screen after replacing a new screen
Take it apart again, remove housings, disconnect cables, reconnect cables, and then power on. If that works then re-assemble
Oct 18, 2013 | Sony VAIO Computers & Internet
I am getting a no signal message on my screen, its a brand new computer
No signal? Are you trying to view this on an external monitor instead of the laptop screen? If so make sure your cables are connected tightly, and also you may have to press the Fn key + F4 to change the display output.
If it's a brand new laptop and the laptop screen itself is telling you no signal, you need to take it back immediately and let them know.
Jun 30, 2011 | Acer Aspire AS5530-5824 Laptop
The LED vizio comes on the front of the tv...........screen is blue with floating signal saying No Signal!.
Tries unplug the tv and the cable or satalite boxes too.Replug it all back like an hour later.The tv know will reset itself back to the factory setting.The cables or satalites boxes it upgrading it softwares.The tv should have incomming broadcasting signal and work now.Not,call the cables or satalites compannies to replaced those inputs boxes first,have the same problems with those new input cables or satalites boxes.Than the tv,the Tuner signal board have problems and the cause.That the board,where the incomming broadcasting signal cable plug into it.That the tv Tuner signal board.Tries websites Shopjimmy.com,Ebay.com to buy a whloe refurbish Tuner signal board for the replacement.
Nov 07, 2010 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Emachine T6410 turns on but the screen says ''No Signal''
This problem is very common when you have a bad ram/ memory module or it is not making sufficient contact. Remove them and clean with a piece of dry cloth and reseated properly. Try it again. If it is still not coming on, the ram may be bad. Get them tested and replaced.
Thanks,
Lolita
Jan 05, 2010 | Computers & Internet
My pillips lcd tv does not work on 75ohm cable inlet. signal is there because it works on my old tv
old tvs CRTs ( cathode ray tubes) pick up signal better than LCDs
So yes good quality satellite cable with better screening and low loss cable will be better, plus a new aeriel may do the trick.
Is your tuner in new LCD faulty though,? try it on your friends tv where you know the signal is fine.
Oct 04, 2009 | Philips Magnavox 27MS343S 27" TV
Monitor signal cable troubleshooting
hi, there is some loose contact in the connection. Take out the cable end from the VGA socket and check the pins inside the socket for any bend inside the socket. Reconnect it, tight the connector with the socket bolts. If not solved, try for any loose solder or wire breake.
Thank you
Jun 23, 2008 | IBM E74 17" CRT Monitor
GE 46
Just need the measurements from top to bottom and side to side I know where you can get a used screen assembly in perfect condition which includes instructions on how to remove your old and install the new. New screens are almost impossible to find and cost about 350.00 Used ones sell at our link for 135.00 and include free shipping.
Mar 30, 2008 | GE 46GW947 46" Rear Projection Television
Computer
Dewang LCD accessories This replaces the board is FP71G (motherboard connects above liquid crystal screen is a row of line, row of wide 30PIN, the white FFC line) The customer purchases this power panel not to have to look the machine model, needs to disassemble the machine to look the motherboard connects above the liquid crystal screen is several row of lines. A row: FP71G machine. Two rows: FP71G+. A line: M170EP01 This board until now had above a year from the sale. The board quality obtains the full affirmation and the customer approval. Until now has not had repairs a second time the board. Maintenance way: This board for brand-new replaces the time which the board, this company produces goods can test, tests OK on the packing to deliver goods, if the customer receives the board to appear cannot use or for one month has the damage, this company free maintenance. The maintenance period transport expense voluntarily undertake by the buyer. Commodity name: The bright base liquid-crystal display replaces the high clamp + power panel specification: Four lamps small mouths + power panel Supports bright base FP71G, FP71G+ FP71GX and so on, thoroughly processes the good bright base liquid-crystal display black screen breakdown, this board maintains for a month, brand-new board, FP71G FP71G+ FP71GX FP737S (screen model: M170EP01) Ming Jihen multi- liquid-crystal display power panel type, purchase time best please pat a picture we to look, in order to avoid makes a mistake the goods Note: This board is the bright base liquid-crystal display replaces the board, the non- original factory board, the bolt hole site is dissimilar, when the time comes asks customer to fix inside the machine, does not need the wiring, this company already completed the connection motherboard plug, the attention: Nearby the original installation power panel power source plug has a fixed Zhuang-zi to be able to short-circuit, please presses him evenly, other places cannot short-circuit. Installed may, brightness and the original factory board was nearly equally bright.
Asks front which the customer purchases to send the information to my mailbox: Indicates your board and the machine model, is best can pat a your bad board the picture. Thanks! Mailbox address: Dongwandewang@yahoo.cn Address: The Chinese Guangdong Province Dongguan city pond mansion town lotus lake district is bright and the computer market A2092 room telephone: 86-0769-82077079 8772017413728205959 contact people: Ancient gentleman
Вспомогательное оборудование Dewang lcd это заменяет ть доску будет FP71G (motherboard соединяется над жидкостным crystal экраном будет рядком линии, рядком широкие 30PIN, белой линией FFC) покупкы клиента эта панель силы, котор нужно посмотреть модель машины, потребности демонтировать машину для того чтобы посмотреть motherboard соединяется над жидкостным crystal экраном несколько рядок линий. Рядок: Машина FP71G. 2 рядка: FP71G+. Линия: M170EP01 Адрес: Китайское заречье озера лотоса городка хором пруда города Dongguan провинции Guangdong будет ярко и комнаты рынка компьютера A2092 телефон: 86-0769-82077079 8772017413728205959 свяжутся люди: Стародедовский джентльмен
Dec 17, 2007 | BenQ FP731 17" LCD Monitor
BENQ FP731s Monitor Problem white blank screen
You have a serious problem. ie. only the back light is working in your monitor. You might need to replace the TFT associate components.
May 06, 2007 | BenQ FP731 17" LCD Monitor
E-Machines T1090 PC Desktop Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
