Question about ASUS A8S-X Motherboard
ASUS A8S-X USB PROBLEM
Hope to help me...When i connect my wireless keybord and mouse adapter and press the button to start my pc then is starts the checking disk and after finishing it it starts again and again!after i remove this adapter it starts normally and if i plug the adapter after its ok.but when i connect the usb of my ADSL box after 5-6 minutes a blue screen apears and restarts automatically.WHY???
  • dodakos Jun 16, 2008
    Thanx man a lot!!!i will try it and i wil tell u the outcome!!!keep sending tips to other ppl there!!!
  • 4,472 Answers
My first solution to you would be to download and update your bios. If you do make sure to understand the instructions, because you can permanently destroy your pc if you do it wrong.
Good luck,
Lee
Posted on Jun 13, 2008
No power model A8S
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
  4. if still there no sign of life then send it to nearest service centre
Mar 12, 2014 | ASUS R500N Laptops AMD A8-4500M, 750GB,...
Wireless Optical Mouse Mi-4150K doesn't connect to pc
windows 7/vista :
-step 1 :Press the windows button (start button).
-step 2 : In the search bar type device manager.
-step 3 : Open the device manager.
windows xp/2000 :
-option 1 for opening the device manager :
-step 1 : Press the windows button (start button).
-step 2 : Open the control panel.
-step 3 : Open the "System properties".
-step 4 : Click on the hardware tab.
-step 5 : Click device manager.
-Option 2 for opening the device manager :
-step 1 : Press the windows button (start button). -step 2 : Select "Run"
-step 3 : Type the following into the text box "devmgmt.msc"
-using the device manager :
-step 1 : Once the device manager is open, click on "Mice and other pointing devices" or "other devices" (if prompt).
-step 2 : In the newly open menu, if there is a "?"right click on it and press update driver.
This should almost force the computer to recognize the hardware plugged into the USB port.
Hope this helped!
Nov 06, 2013 | Trust Wireless Optical Mouse Mi-4150K
Neither the Acer supplied wireless mouse or wireless keyboard work with my new Acer Aspire M3300 PC. I inserted the supplied batteries the correct way round and the blue led come on for a few seconds,...
make sure you have the right keyboard and mouse selected
this will depend on which operating system you have
click start control panel view devices and printers you should see your mouse and keyboard right click on either select properties then hardware make sure you have the correct one selected in W 7
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected
this will apply to keyboard to in XP
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port ((if applicable))
click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x
right click you will need to update the driver
hope this helps you
Aug 30, 2010 | Computers & Internet
I cant connect the wireless keyboard or mouse
chaque battery of wireless KB. ok than refix USB port if it blue light is blenk ok, than back Side of KEYBOARD & MOUSE u have found one blue botton this botton press Same time press keybord button it will conect ok. the blue botton press only 5 Second
Mar 17, 2010 | Computers & Internet
I want to install a Microsoft wireless optical mouse but not sure how to do it.
With the wireless mouse you also have a wireless adapter that is connected via usb to your computer. Insert the usb adapter in an available usb port on your computer. Wait for a few seconds until windows verfies and installs the new device. Then press the sync button located under the wireless adapter and at the same time press the sync button under your mouse.
The mouse will be ready to use.
Regards,
nicolasiac
Feb 09, 2010 | Microsoft Basic Optical Mouse PS 2/USB...
Microsoft Wireless Notebook Op. Mouse 3000 Dosent work.
try plugging the usb adapter into a different usb port of the computer and there must be a connect button on tat adapter..press the connect button on tat aadapter and then press the connect button on the mouse {after replacing the battery}.if it doesnt work on 1st go ,,try 2-3 times,,,and hey best of luck
Apr 14, 2009 | Microsoft Wireless Notebook Optical Mouse...
I have an Advent ADE-WLOI1 wireless mouse. Recently moved house and packed up my pc and mouse - now mouse won't work. Tried reset button - no go. My pc is virus infected and am trying to clean it - without...
This seems to be a generic mouse, usb / ps2 connectivity. User needs to press the connect / reset button on the receaver and on mouse. generally.. no drivers or cd required.
mouse has battery.
-check battery
-reconnect (receaver and mouse, if receaver doesn't have button, make sure its connected to pc and power is on, then reset.
try ps2 instead of usb or another usb port, might require adapter. (if im not mistaken it comes with the mouse)
-try another pc
= possibly faulty mouse if still not working? It should work with windows drivers, so no cd required.
Sep 23, 2008 | Computers & Internet
I've charged my Targus wireless mouse (PAKP003U) and plugged in the USB adapter thing, making sure the light is on. The mouse is on also, but it is still not working.
Your windows computer must install the drivers for the wireless adapter for your mouse when you plugged it in. Given that the light is on the adapter I'm assuming it works.
There should be a small button on the mouse and the adapter somewhere. Press the button with a paperclip or something small enough to get to it and the light should start flashing. Now press the button on the mouse. Both lights should be on solid.
This connects both the adapter and mouse on the same wireless channel to work together.
Good Luck!
Aug 21, 2008 | Computers & Internet
DX-MKB101
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Nov 19, 2007 | Dynex Multimedia Keyboard DX-MKB101
Logitech LX5 wireless mouse
Turn the mouse ON before starting the computer. Then if it doesn't connect, press the button on the USB receiver and then the mouse should work.
Jan 07, 2007 | Logitech LX5 Cordless Optical Mouse
ASUS A8S-X Motherboard Logo
81 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
