Question about IBM 6400 Model i10 Matrix Printer
IBM 6400 printer - error: "089 ribbon stall?"
5 Suggested Answers
yooperbud
  • 8637 Answers
SOURCE: Error 058 Shuttle Jam on an IBM 6400 Matrix printer
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 25, 2009
SOURCE: p62 error code
The IBM 6400 printer uses internal programming software that is specific to the printer based on installed interfaces and graphics options. This software resides in flash memory and when the printer is first powered on the software is executed. During this process it initializes the various processors on the controller board, initializes the optional interface cards, and then loads the necessary operating settings into dram. If the programming software becomes corrupt it will fail during startup, giving you the DC Program not valid error or a number of other error messages. The solution to this is a reflash of the printer. Unfortunately, the flash software is proprietary to IBM and they will not distribute it to anybody. The only way to get the printer reflashed is by calling IBM and having one of their engineers reflash the printer.
Posted on Jan 30, 2009
pawandahake
SOURCE: 089 Ribbon Stall Check Ribbon
Your Ribbon HUB is Broken. Replace it.
Problem will be Solved.
Regards,
Pawan Dahake
( IPS, Nagpur )
INDIA.
Posted on Mar 04, 2009
SOURCE: Ribbon Stall
Printer errors are various messages displayed on the LED display of printers. ... We also carry a lot Lexmark Toner & Ribbons for your one stop shopping experience. ... ERROR 54 - Duplex Feed Error (IID/IIID) or Main Motor Stall 2686 A/D ..... Sharp Printer Supplies, TallyGenicom Printer Supplies, Texas Instruments ...
www.printersupplies.com/errors.html
Posted on Dec 03, 2009
INK IS RUNNING OFF OF THE RIBBON AND DRIPPING TO THE BOTTOM OF UNIT. RIBBON NUMBER IS DKF-9000 WE WENT THRU 3 RIBBONS IN 1 MONTH. I THINK ITS SOMETHING IN THE RIBBON TENSION.
The Problem you are having is due to re-inked or remain ribbons. You need to use OEM Printronix Ribbons, I have new in stock if needed part# 107675-001 they come in a 6 pack. 708-597-4222 Rory
Aug 04, 2011 | IBM 6400 Matrix Printer
Hello I have an IBM 6400 printer at work. It prints documents, but every now and then it will print the documents with a white streak running down the paper, like it doesn't print in that spot. I tried...
Hi there, I hope you haven't throw away the printer.. :)
i face similar problem.. its solve by tightening the ribbon latch screw that secure the latch to the ribbon motor.
Feb 02, 2011 | IBM 6400 Matrix Printer
092 RBN DRVR Circuit see user's manual 089 RIBBON STALL
CMX doesn't detect ribbon drive motor: either bad motor or a cable to the cmx card is off or defective from the ribbon motor
Jack
Aug 16, 2010 | IBM 6400 Matrix Printer
Need to change the printer ribbon on ibm 6400
BY WWW.IBM.COM/SERVICE
GO ON LINE AND TYPE THE FOLLOWING:
HOW TO CHANGE A PRINTER RIBBON IBM 6400
BEFORE YOU DO ALL THAT FIND THE RIBBON BOX AND SEE IF IT HAS ANY TYPE INSTRUCTION WHAT TO DO?????????
ROD
May 12, 2009 | IBM 6400 Matrix Printer
I need instructions for tractor replacement on IBM 6400 printer
GO ONLINE ASK THE FOLLOWING:
WWW.IBM.COM/SERVICE
IBM 6400 TRACTOR REPLACEMENT INSTRUCTIONS
SERVICE MANAUL IBM 6400 PRINTER
IBM 6400 TRACTOR ASSEMIBLEY/DETAILS
ROD
Apr 02, 2009 | IBM 6400 Matrix Printer
Regards,
Pawan Dahake
( IPS, Nagpur )
INDIA.
Feb 24, 2009 | IBM 6400 Matrix Printer
Cutting letters off in 2 spots down whole report
IF trouble in first row - you ribbon is tracking wrong - replace
You may have junk in the ribbon mask also. No parts needed for that. You need to rotate the hammerbank. Remove ribbon and black cover, the whole shuttle will tipback toward you when you unscrew the allen wrench - watch out for the paper tractors they will hang on the ribbon mask. The ribbon mask is held on by magnetic field - just pop off carefully. clean holes with toothbrush and water - dry. (if the trouble is a bad actuator - 4 allen screws to remove a group of hammers - if using short paper - you can use a group from the end of the printer). reverse to fix
Feb 02, 2009 | IBM 6400 Matrix Printer
IBM 6400-A00 prints normally and stops
GO ON LINE AND TYPE THE FOLLOWING INFORMATION:
IBM 6400-A00 PRINTS NORMALLY AND STOPS ERROR
ENTER
ROD
Dec 16, 2008 | IBM 6400 Matrix Printer
058 shuttle jam
This can happen for a number of reasons.:-
a. The print mechanism needs to be adjusted ( You'll need a technician to do this if yu are not familiar.
b. Something is clogging the print mechanism, eg Old ribbon residue, or sticky labels etc.
c. The paper thickness lever is set to incorrect setting . Try adjusting it out .
Aido
Jan 18, 2008 | IBM 6400 Matrix Printer
IBM 6400 Model i10 Matrix Printer Logo
966 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
