Question about EMC CLARiiON AX150
How do you reset a clariion ax150 to factory defaults
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
How to delete former owners wireless data on HP 4500 - G510n wireless printer.
Settings
RESTORING
FACTORY SETTINGS
initialization
Mar 26, 2015 | HP Office Jet 4500 G510n
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
I am looking for the Security Key
Unfortunatly there is no way of accessing the router security key if you have forgotten it however you can reset your router to factory default here is how
" The Reset button is located on the right side of the product label. There are two ways to reset the Router to its factory defaults. Either press and hold the Reset Button for approximately five seconds, or restore the defaults from the Administration > Factory Defaults screen in the Router's browser-based utility The Reset button is located on the rightside of the product label. There are two ways toreset the Router to its factory defaults. Either pressand hold the Reset Button for approximately five seconds, or restore the defaults from the Administration > Factory Defaults screen inthe Router's browser-based utility" was this helpful?
Oct 05, 2010 | Cisco Linksys E1000 WirelessN Broadband...
Console cable
Console cables are usually:
12345678
87654321
basically it's a straight thru but flipped over on one end.
Mar 10, 2010 | EMC CLARiiON AX150 (AXS207500KIT) Network...
How to configure AX 150
EMC offers a great documentation site.
Here is it:
http://www.emc.com/microsites/clariion-support/ax150/install.esp?redirect=true
You can select Install and you can create a great customizes doc for installation steps.
Generally you can configure AX150 from a web based interface.
Enter the ip addess of the storage processor and a java application will appears.
You should do the following:
1. Create raid groups
2. Create LUNs on raid group
3. Register the hosts
4. Add hosts and LUNs to a storage groups
Dec 17, 2008 | EMC CLARiiON AX150
How to reset dell AX150
This is a storage drive from dell.
Dell have quirky systems that are different to the normal run of the mill PC components.
I can only advise you to refer to Dell in this instance.
Sep 15, 2008 | Dell AX150 Single Processor Storage Array
Slow file transfer
What is your connectivity to the SAN? fiber or iSCSI? Have you checked the management tools to see if there are any errors on the data paths? If using iSCSI and the SAN and server are in the same network segment, make sure the default gateway is empty for the iSCSI connection. Look at the routes on the server to make sure the traffic is not leaving the subnet through a router and back to the SAN, and vice versa. If fiber then you'll have to use the tools given to check for errors. Ken
Aug 15, 2007 | EMC CLARiiON AX150 (AXS207500KIT) Network...
Storage Processor A Problem
I'm not an EMC guy, but that error makes me question the connectivity of SP-A to your Management Server. Check the host port status on both controllers to see if they are active. If this is on a SAN, you might check the switch port status going to SP-A.
Aug 11, 2007 | EMC CLARiiON AX150
EMC CLARiiON AX150 Logo
785 people viewed this question
Top EMC Computers & Internet Experts
LP
charlie rodriguez
charlie rodriguez
Michael Harrier
Are you an EMC Computer and Internet Expert? Answer questions, earn points and help others
