Question about RTO PasLode 900420 Impulse Framing Nailer
Model 3250-f16 Paslode I recv'd this nailer without a booklet. I would like to know how to use it. Can you help?
  • RTO Master
  • 43,501 Answers
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Posted on Mar 06, 2011
What size nail does the Plaslode 3250 f16 use
Do you mean the Paslode 3250/65-F16? If so, it takes 16 Gauge straight brads 38-64mm.
Feb 22, 2015 | Tools & Hardware - Others
Paslode F16 finish nailer will not return to start position after firing. Need to pull it back.
You may have to disassemble it BUT it may be that the mechanism and sliding parts are dry and stuck with glue from nails etc so may also work to apply a rust solvent to the sliding parts and let it sit and work the nailer a bit etc.
Sep 21, 2014 | Paslode 1-1/4 In. Straight Finish 18 Gauge...
Manual for 350/90 nail gun
If this is a paslode as it says in the header, you can try going to paslode.com and downloading one. If not I would need the brand and model number to help. If you have a problem still finding one let me know and I will try another source.
Mar 11, 2012 | RTO PasLode 900420 Impulse Framing Nailer
I installed a new o ring on the plunger but my S200-s16 still does not shoot the staples,.
could be a number of reasons check the trigger or best bet it to fully disassemble and check all seals and orings without being able to see for myself what it is doing exactly that the best I can do
Jul 06, 2011 | NRS Paslode T250-f16,s200-s16 Nailer &...
Won't fire
heatman101
Feb 11, 2011 | NRS Paslode T250-f16,s200-s16 Nailer &...
The nailers piston that drives the nails is cracked onley drives nails half way in
im afraid that if the piston is cracked, then you have to replace it ( since you know that it is cracked then ill assume that you know how to remove and replace it) you can buy one at your local nail store or you can try toolpartsdirect.com,,, please rate this ,, tks
Dec 15, 2009 | NRS Paslode T250-f16,s200-s16 Nailer &...
My paslode batteries will not charge. The charger
check your charger for the right power out put. you may have a bad battery. if so find an interstate battery shop thy can rebuld them at half the cost
Oct 12, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode t250 f16 leaks air from the cap difuser
The most common problem with this nailer is the plastic seal that sits on top of the cylinder. This seal (ususlly white, yellow or black in color ) will cause the nailer to leak lots of air out top of gun. Examine seal for cracks and replace as necessary; the part number is 402725 and is available at www.toolpartsdirect.com This should stop the rapid air leak. After installing the new seal, if you have a very small constant leak out top of the gun then remove the screw holding the headvalve in place and check for small scratches where the orings contact headvalve. Use very fine sandpaper (300 to 400 grit) to remove scratches. Clean and re-use the same orings using silicone grease instead of oil and re-assemble. This should stop all leaks. Silicone grease is available at Lowes lumber in the plumbing department. It is used to lube orings in faucets. If you have more questions about this gun please email, Good Luck
Jan 28, 2009 | NRS Paslode T250-f16,s200-s16 Nailer &...
RTO PasLode 900420 Impulse Framing Nailer  Logo
168 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
