GE Top load clothes washer
When the washer gets to the rinse/spin/drain cycle it will not drain but only hums
    Genius:
  • 1,028 Answers
Using pudy knife prees down on clips holding front on they are on each corner just below top ..after removing front panel ck pump on bottom right some had small fans on end of shft try turning fan if won't turn remove as much water as possible remove pump hoses remove pump and ck for foreign object inside pump
Posted on Jun 14, 2008
My kenmore washer model 110.27802690 will not spin and will not drain the water. the motor will make a humming noise but won't come on. we took all the clothes out and it will now fill up the washer, wash...
Under the lid there should be a small hole with a push down flap and that should be the automatic stop, which can either be a bad switch under the top of the machine or could be a broken trip/ prong on the lid that pushes this button when the lid is dropped. When the machine reaches it's spin cycle time leave it turned on and raise the lid push down on this flap with something careful to keep hands out of the washers tub and see if it works then!
Mar 02, 2018 | Kenmore 24032\24036 Top Load Washer
Washer will not spin at high speed
check for any blockages around pump and air trap area.
Sep 14, 2009 | GE WBSR3140DW Top Load Washer
Washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Mar 21, 2009 | GE Energy Star WCVH6260F Front Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
GE top load washer won't drain or spin
there was something stuck in the water pump. we pulled it out and good to go.
Jun 14, 2008 | Washing Machines
GE Top Load washing machine not draining
  • to me it sound as if waterpump is not working
Apr 09, 2008 | GE WDSR2080D Top Load Washer
Washer
relay switch between timing circuit and spin cycle is faulty
Apr 03, 2008 | GE WDSR2080D Top Load Washer
GE WBSR3140D
I have the same problem. The water drains, but I have no spin leaving the clothes soaked. I get a humming sound and thats it. The rest of the washer works fine. Any help would be great.
Jan 13, 2008 | GE WBSR3140D Top Load Washer
Washing Machines Logo
149 people viewed this question
Top Washing Machines Experts
