Trying to replace agitator dogs. Removed cap and nut, and have whole agitator assembly in hand(one large unit). However I cannot get the dogs out, as the inner assembly won't fall out. How do I disassemble the upper and lower parts of the agitator (auger, cam, and assembly) in order to get the dogs out and replaced. Thanks! Jeremy
    President:
  • 1,937 Answers
See the following illustrated descriptions:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=bb1287f031ea458c3a91d1feb88faaa8
Posted on Nov 03, 2010
Aggitator making a lot of noise/banging sound. How is it removed?
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa!!
Dec 12, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Trying to remove the agitator from a kenmore top loader. took off agitator cap but there is no nut down inside. i see metal but nut drivers and sockets won't fit, down opening. should i just pull up on the...
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 10, 2010 | Kenmore 24972 Top Load Washer
On my stackable kenmore unit my washer everything is working but the agitator and when i tighten the bolt it works for a minute then stops again
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 26, 2010 | Kenmore 98702 Stacked Washer/Dryer
Entering into spin cycle, failed to drain, stopped spinning
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
Aug 01, 2009 | Kenmore 23822 Top Load Washer
Can't remove the tub to change the seal.
May 28, 2009 | Kenmore Washing Machines
Stripped gears
It wasnt necessary to remove the shell. The agitator dogs can be replaced from the top through the lid.
May 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Agitator doesn't spin
May 02, 2009 | Washing Machines
I have a speed queen washing machine for 10 years and i never removed the agitator but now water is leaking from it.can someone tell me how i can remove it
Mar 07, 2009 | Washing Machines
Kenmore model 20722 washing machine
Jan 19, 2009 | Washing Machines
I have a kenmore washer and I am trying to replace the cam dogs. I have removed the dispenser cup and the cap that is beneath it. I can see the edges of the cam dogs, but cannot remove the plastic thing...
Dec 31, 2008 | Washing Machines
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
