Question about Dehumidifiers
Amcor dehumidifier 850e humidity display shows 35 always even when humidity is 80, any ideas ?
  • 2,299 Answers
The digital humidity sensor is bad internally. This is a common problem on the 850
Posted on Nov 03, 2010
, My KM30 Dehumidifier t'stat will not reognise ambient humidity properly. I placed the unit in my boat-steamy 80% humidity at 50%. it consistently turned itself off. Ok on 35 and Lo.
there is a sensor in the unit much like a temp sensor, (bullet shape) over time these do ware out and need to be replaced this tell the unit the temp so the unit knows humidity. it could also just need cleaning as a build up of damp then dry dust can cover the sensor.
Jul 01, 2017 | Dehumidifiers
Humidity display window always LO
I would go to a box store and get a guage that displays relative humidity and see where it settels at. Your humid may actually be low.
Apr 11, 2014 | Amana 45 Pint Electric Dehumidifier -...
Humidity sensor
It may be right. Are you sure you need dehumidification?
Put a free-standing humidity meter near the unit to check.
If you still want to run the dehum, take the humidity sensor out of the line and control the unit with a timer.
Aug 17, 2017 | Maytag M7DH45B2A Dehumidifier
I acquired used Amcor AHD65 Dehumidifier a couple days ago. I was told that it is just beyond the warranty period. I assume that it is a barely a year old. However, It worked this evening a sort since it...
You may still have some packaging materials left inside the unit. The plastic pan doesn't stay in side the bucket. It's used as a drain pan on the outside. Also, be sure the air intake filter is in place, is clean and there are no packaging materials behind it.
To extract more humidity, after checking all the things mentioned above. Lower the extraction level to 32 to 35%. Lower percentages means extraction of more humidity. (i.e.200% -35% = 5% drop in humidity).
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 11, 2011 | Amcor AHD65 Dehumidifier
Humidity sensor reads to low and does not kick the machine on. The readout seems to always be at 20% and wont kick on till 35% Is there an adjustment i can make to tuen the unit on?
It probably doesn't need adjusting, It's simply a case that 20%, there's not enough humidity for the sensor to read. But, at 35% there is. I'd say, your dehumidifier is working as it should.
FYI - there is no adjustments to change the factory settings.
Hope this helped you, chu.
May 16, 2011 | Fedders 30-Pint Dehumidifier Dehumidifier
My amcor dehumidifier tc120 has started clicking recently and now its out put is poor the unit is used in a cellar just to keep control of humidity it works 24/7 then has few days off when full untill i...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jan 17, 2011 | Amcor DC930 Dehumidifier
Humidity pad doesn't work
You've posted in DEhumidifier section.
Sounds like you have a Humidifier. Please post there.
Although why you want to add humidity to the tropics is beyond me.
Sep 01, 2017 | Kenmore 54501 Dehumidifier
Control panel explanation
80% means the humidity will be at 80%
You probably want a setting of 50 or 60% if you are trying to keep a damp area dry.
When it is 20 degrees outside, it will probably by below 50% humidity inside so you need more humidity, not running a DEhumidifier.
CONT is for continous running - you probably don't need that setting
Jan 03, 2010 | Dehumidifiers
Dehumidifier Present % indicates "Hi"
It is showing high because the present humidity is above 80%. Try turning the humidity setting down and let the dehumidifier run for a while. Once the dehumidifier lowers the humidity in the room this level will go lower. If this persists after running for a while you will need to contact LG for service. They back these models with a 5 year warranty. Here is the number to contact them at:
1 (800) 793-8896
Keep me posted. Thaks - Tech101
Jul 25, 2007 | LG LD65EL Dehumidifier
Dehumidifiers Logo
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Marvin
Marvin
Are you a Dehumidifier Expert? Answer questions, earn points and help others
