Question about Yamaha DSP-A3090 7-Channel Amplifier
I own a Dsp a 3090 yamaha receiver and the center speaker Is not working In all modes although the speaker Itself Is working on the main chanel, Is there any setup to be made? I just installed It
    Brigadier General:
  • 8,546 Answers
No sound on right side speakers on A&B.Sound does work in test mode. Right side Chanel is working, just no sound on right side front in all input modes. I'm a amateur when it comes to stereos.
Go to "menu/Setup/Speaker level" and adjust the balance of L-R.See page 21 of the manual:
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v540/?mode=model
Jan 20, 2013 | Yamaha RX-V540 Receiver
Dear Sir Good morning Is the DSPA-3090 a receiver(integreted tuner )? Thank you ganesh
http://usa.yamaha.com/products/audio-visual/hifi-components/amps/dsp-a3090_black__u/?mode=model
No.
Apr 19, 2011 | Yamaha DSP-A3090 7-Channel Amplifier
My yamaha DSP AX1 amp does not work when audio is connected via optical or coaxial any suggestions how to correct this. no sound comes from any speaker except the subwoofer.
Are all the speakers turned off (set to None) in the speaker menu.(except the sub)?
2 channel direct analog stereo may still work, but any surround modes will use the speaker settings and the full DSP digital section.
Check also the input mode isn't incorrect - although if the sub is wired correctly and gives sound this can't be whats wrong.
Aug 26, 2010 | Yamaha DSP-AX1 10-Channel Amplifier
Amp wont work
Hi I have a Yamaha DSP 3090 Amp my right main Chanel is not working Amp goes off when i try to put the power on i think it goes on protction mode?after trying for 5to10 times it comes on, test mode all chanels work well not sure whats wrong ? can anyone slove my problem
Jan 02, 2010 | Audio Players & Recorders
No sound from center channel
If you have checked the speaker and wiring. Check the setup, the center channel could be off or it's not in a surround mode.
When playing a DVD through the receiver are the voices heard clearly in the front speakers? if so the center channel is turned off.
Oct 21, 2009 | Yamaha DSP-A1 Receiver
Amp turns of after 2 seconds of turning on
It is going into protection mode, and shutting itself off. You have a short somewhere. I would suggest taking it to an authorized service center for assistance. This is not easy to diagnose, as it could be anything causing the short.
Try disconnecting everything from the unit, including the speakers, and turning on again. This will just confirm that the problem is the amp, and nothing external. Also, try connecting it to a different power supply/socket.
- OPTiC
Master Tech
Digital Analog Therapy
Yamaha Parts : Electronics Repair
Aug 29, 2009 | Yamaha DSP-A2 Receiver
Pop from speakers when using dolby digital mode, works fine when not using any processing mode
Over 10 years old? Could be bad capacitors... if you have the expertise, you can try taking it apart and checking them with capacitance and ESR (equivalent series resistance) meters. Otherwise, you can try to see if any capacitors are exhibiting any "bowing" or leaking; if the top of the capacitor is bowed or puffed out - even slightly - or if there is a brown or white residue around the base of the capacitor, you can guarantee the capacitor is bad. Note that not all bad capacitors exhibit these physical attributes... but you can be sure a good capacitor won't.
If all of this sounds too complex, your only recourse will be to take it to a reputable electronics service shop.
May 26, 2009 | Yamaha DSP-A1 Receiver
Yamaha DSP-A3090: All video settings trip unit and it turns off
Hi...
Is the first set "stereo" settings and the 2nd set "surround" settings?
If so that may mean that the surround speakers arent all connected right.
Jan 14, 2009 | Yamaha DSP-A3090 7-Channel Amplifier
No center main volume
Make shure your initial setup on the amp is for center as an active speaker,then to check volume on center at zero. Possible to check speaker and wires for open or short.BIGRED
Sep 16, 2007 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha DSP-A3090 7-Channel Amplifier Logo
364 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
robert landry
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
