Question about Whirlpool Washing Machines
Need door for Whirlpool Duet Washer part from soad door that I need 461970203341
  • 67 Answers
SOURCE: whirlpool duet washer
is there an error code?
Posted on Mar 27, 2007
aborcass
  • 2651 Answers
SOURCE: Door reversal for Whirlpool Duet
there is no reversing the door on the washer. the door on the dryer can be reversed and with the execption of a few of the earlier models no kit is required(even then was just a trim kit). is switching theposition of the 2 appliances an option?? as far as wsher vibrating through house heres a new product receiving great response http://www.keshakeaway.com/servlet/StoreFront
Posted on Mar 13, 2008
  • 4 Answers
SOURCE: Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
Posted on Mar 24, 2009
  • 240 Answers
SOURCE: My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Posted on Jul 19, 2009
  • 4 Answers
SOURCE: My whirlpool duet front load washer door leaks.
YOU NEED A NEW BOOT ON THE INSIDE OF THE DOOR. WHEN YOU OPEN YOUR DOOR THERE SHOULD BE A GRAY RUBBERY RING. AS A MATTER OF FACT, IF YOU MOVE THAT RING AND PUT YOUR FINGERS IN IT YOU WILL PROBABLY FIND A MISSING SOCK OR TWO! THAT RING HAS TORN AND NEEDS TO BE REPLACED.
JB
Posted on Sep 12, 2009
How can I unlock the door to my Whirlpool Duet washing machine?
try this link..Pull down on the bottom panel and pull it away from the washer. Reach through the open panel and up to the door lock. Find the release ring below the locking mechanism. Pull down on the ring to unlock the door.
How to Unlock a Whirlpool Duet Washing Machine ' Home Guides ' SF ...
homeguides.sfgate.com/unlock-whirlpool-duet-washing-machine-68645.html How can unlock the door to my Whirlpool Duet washing machine Google Search
Dec 12, 2016 | Whirlpool Washing Machines
On my whirlpool duet washer the little pin in the door (black) that pushes in when shut broke and now my washer wont kick on
Is this pin on the door or the frame? If the frame then you need a new door lock assembly that you replace by peeling back the rubber tub bellow after removing retainer spring.
Sep 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport washing machine with a leaking door.
You need to check if the door is not loose on the washer, make sure you tighten all the screws on the door
Jan 07, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Have a whirlpool duet front loading washer. Recently bought a new house, only way to access basement is up 5 steps on side of house to landing with railing.cannot turn machine on landing so door is facing...
This may or may not be helpful but please see the following Whirlpool installation and service manual for the Duet Sport washer.
It has a number of sections on accessing components and you may be able to determine how to take the front off.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Following is the Whirlpool service manual for two other models of the Duet washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Oct 20, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Can you adjust the door on the duet washer. I
You need to replace the hinge, sounds like it has worn out bushings.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door lock error whirlpool duet front loader
DO NOT BYPASS A SWITCH UR HOUSE WILL BE FLOODED INS WILL NOT COVER IT. YOU NEED A DOOR LATCH, AN MMC AN PROB A BELLOWS CAUSE YOU WILL RUIN IT PUTTING THE SPRING CLAMP BACK ON. DO URSELF A FAVOR AN CALL A SERVICE TECH
May 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The door on my Whirlpool duet sport won't close / lock ..
its best if you call whirlpool to set up service call. tampering with your washer could void the warranty
Dec 16, 2008 | Whirlpool GHW9400 Duet Washer
Duet Whirlpool Washer
You will need service at this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Sal De
Marvin
Marvin
jimorris77
