I bought a hp G62-363 tu core i5 from www.laptop.lk on 2/11/2010. i have problem with the usb ports. to the left there are two usb ports and to the right side of the laptop there is one. problems are
1. my dongle works only at the left side port next to the headset connection. since the dongle is big i cant use the headset or the adjacent usb port at the same time. nor i can use 2 pen drives on the same side.
2.why the dongle is not working on other 2 ports.
3.even the pendrives work in those usb ports only with holding with a finger to support
Windows should have the USB drivers ready to install now.
Go to Start > Control Panel > Device Manager, after opening Device manager, at the bottom of the list is Universal Serial Bus Controllers> Delete the ones that your having trouble with. Then Restart you computer, when it restarts you'll see a pop up notification. It will say Windows has found new hardware and is installing driver for this hardware. That should be all there is to it. Sounds easy because it is.
The power connectors that are feeding the USB from the inside seem to be ok. The data connections of the USB are bad. Maybe with some very careful professional soldering of the data connectors on the inside of the USB, your problem would be resolved.
if you are looking for a firewire port on the laptop, i believe it does not have one.. your option for connection would be the USB 2.0 and eSata port located at the left and right side of the laptop
I think there is something wrong with your USB cable. Or the printer is faulty. Do not try again to connect it. If you plug something else in your USB port it works ?
dell\'s config: Intel® Core? i5-460M Processor (2.53GHz,
2Core/4Threads, turbo up to 2.8GHz, 3M cache) 1GB NVIDIA®
GeForce® GT 420M graphics with Bluetooth (with WIDI) 4GB
1333MHz DDR3 SDRAM (1 x 4G) (operates at 1066MHZ for Core i5 processors) with increased RAM will work fine
