Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Power/standby light flashes 7 times and the tv doesn't turn on
Hello! We bought a Sony KDF-60WF655 about 3 years ago and it was new in the box (never used because we were waiting to finish building our home to get married ), and last night we open the box and finally enjoy watching our tv. Then we turn it off and went to sleep. This morning the power/standby light flashes 7 times and the tv doesn't turn on. When we try to turn it on it makes the sound like it will turn on and the screen stays black and then the tv turns off by itself. While we were sleeping there was a power voltage problem and we didn't have the power suppresor installed yet since we were testing the tv. Thanks for your assistance, Wilfredo & Joann
  • JOANN HERRANS Jun 14, 2008
    Is there any way I can fix this by myself of do I need to contact a technician? Thanks, Joann
    Hello again,
    My brother-in-law is an experienced computer/electronic engineer, so I think he can do the job with some advice you can give me.
    Thanks in advance, Joann & Wilfredo
  • Sony Master
  • 8,617 Answers
Audio Protect (7 Flash): When DC voltage is detected at the speaker or
woofer outputs, IC3604/pin128 (TV-micro) goes low and IC3604 turns off
the main power (AC relay turns OFF).
Troubleshooting Tips:
1) Main cause of defective will be located on the KD-board
2) Confi rm KD-board is securely seated on the G2-board
3) Replace KD-board
Posted on Jun 13, 2008
  • Sonny Berry
    Sonny Berry Jun 14, 2008
    Thats a fairly complex Chassis. Unless youre really good at dissassemble and reassembly of small components, I would suggest a Sony authorized reapir tech do the repair.
  • Sonny Berry
    Certainly, I can help you. I would recommend going to the following link and getting the service manual so he can see first hand disassembly instructions and testing proceedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new KD board. heres the link.
    http://servicemanuals.vstore.ca/
I have a sony wega kdf-42a10 its only years old. i already replaced the bulb about a year ago....now when i turn it on the picture comes up then is there for about 4 to 5 sec. then disapears... they...
The tv also have a board that called a Ballast board this board only job are to ignite the tv lamp only.Hear alot of clinking too while the stanby light are blinking.Yes,the Ballast board it is dead and not help to ignite the lamp and helping it stay on.
Aug 25, 2011 | Sony KDF-E42A10 42 in. LCD Television
Sony grand wega
It may be a power supply fault
May 19, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony TV KDF-E42A10 Projection TV Standby light flashes 4 times. TV turns on for 5 seconds and turns off with standby light flashing 4 times. TV will not stay on.
Your power supply board is not yet dead, you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this helpout in solving the problem......
Jan 11, 2011 | Sony KDF-E42A10 42 in. LCD Television
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
hello if the lamp cover is not mounted securely the self diagnostic function works and the power /standby indicator flashes 3 times when you've corrected it power/standby indicator goes out the tv enters standby mode
shaun
Oct 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
I have no picture on my sony KDF-50WE655
check the fan again with a flash light. I had this same problem and changed out the large fan behind the bulb...no more problem. my brother has the same tv and he has had to replace the fan at least three times.
Jun 08, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Kdf-60xbr950 no pic or sound. standby light flashing
Sounds like the lamp is bad. Might be time to replace the TV.
Mar 31, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDF 60WF655 standby/power light blights 10 times then repeat
This is what I found
You may want to have a Tv repair shop look at this .
Standby light flashes 10X
Symptoms / Customer Description
[Primary Symptom Code: 2111 ]
Solution
G1 and G2 boards are ok.
Found Q box was causing loss of DTL MODULE 5v.
Replaced Q box to resolve.
Part #
A1058689A
Feb 09, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
252 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
