Question about Hitachi 65S700 65" Rear Projection HDTV
HELP MY PICTURE IS RED AND SLIGHTLY BLURRY
TV IS SLIGHTLY OVER 4 YEARS OLD WARRANTEE OF COURSE IS EXPIRED. AGAIN PICTURE IS PRETTY RED AND SLIGHTLY BLURRY. COULD IT BE A CIRCUIT BOARD GONE MAD OR COLOR BULBS?
  • Anonymous Feb 24, 2009
    Red in the middle of the picture
    Novelist:
    Champion:
  • 203 Answers
It is probably a convergence problem which would involve solder work to change convergence i.c.s or if there are not colored shadows around everything it could be a problem with tubes. On a few of these I was able to remove the front grill and take off the small door, and with an insulated screwdriver gently tap on the neck of the tubes with the set on. Now if the picture flickers you have some particles on the filaments of the tubes and sometimes the debris will break free when you perform this, allowing your picture to restore full color and brightness without changing any parts whatsoever. Otherwise, the convergence chips are located on a large metal heatsink and have a generic part number printed on the front of each. Sometimes you have to remove a pressure clip to see it. Hope this helps, Russmann.
Posted on Jun 13, 2008
Visuals look like color is displaced and slightly blurry... fix?
Not worth fixing. This has picture tubes that are expensive to replace. To repair this requires way more expertise than can be communicated via fixya. Your money would be better spent on a new TV
Jul 12, 2015 | Mitsubishi Televison & Video
Plasma TV Picture Periodically Blurry/Color is Distorted
This sound more like a cable issue. Also check the leads going from your cable box to the set/ If you are using component cables one of them may be loose.
Apr 28, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Magnaovox rear projection tv has too much red in the picture and it is blurry
Sounds like a coolant issue with the CRTs. Look into the lens of the green and blue CRTs and you should see what looks like bacteria if the coolant nees replacement. Usually the green and blue get contaminated which dims them and makes the red become dominate and the picture will get dim and out of focus.
Jan 22, 2010 | Philips Magnavox 51MP392H Rear Projection...
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
Blue cloud
Problem fixed by reading other post with same problem. Unfortunately Sony is not going to fix this problem.
Apr 18, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KV-36FS120 No Pic/No Sound 4 blinks
You need to have the flyback on the main board replaced (a very comen problem)
This should fix ya!
Dec 12, 2008 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Rca 62" PROJECTION FLATSCREEN - COLOR PROBLEM/FLICKERING SCREEN
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
Oct 06, 2008 | RCA F36645 TV
OVERHEATED?
yes open it up get dust out run small fans in nit see how long it stays on
Sep 15, 2008 | RCA HD52W56 52" Rear Projection HDTV
Hitachi 42PD6600 - Picture Problem when changing AV channel
I Have the same problem but with the EXT6 channel HDMI.
have you solved the problem yet?
Jun 08, 2008 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Blurry picture and arched at bottom
We have a Proscan 50" Projection TV. A T.V. repairman told us it was the HV (Horizontal Vertical) Splitter causing this problem and tried to find the part for us. The part for our TV was too hard to find though and we ended up not having ours fixed. Our T.V. is 8 years old though, and Proscan is discontinued. Maybe you'll have better luck finding an H.V. Splitter for your TV. Of course, you'd need a professional to install it for you. Good luck.
Sep 20, 2007 | RCA P60921 60" Rear Projection Television
Hitachi 65S700 65" Rear Projection HDTV Logo
85 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
