Question about Kodak EasyShare M853 Digital Camera
Kodak digital camera
Will not charge when connected to my computer. Do I need to replace the battery, I have only had the camera six months and used only a few times. I thought the battery charged through the computer connection?
  • 579 Answers
Camera will not charge through USB interface, only DC input jack or camera dock.
Posted on Jun 13, 2008
I have a kodak z650, this is "new" machine in the original box but we never used in the past six years. When then i turn on in the LCD showed "Kodak easyshare logo" then turn off by itself... The le
If you really left the batteries alone for 6 years without regularly charging them, they won't work anymore. I still have two KLIC 500 batteries from Kodak, which I bought in 2005, Both are in very good condition, because the both get a charge every 3 months, even in periods I did not use my camera.
You could try. charging the batteries several times, but don't have to high expectations.
Jan 03, 2014 | Kodak Cameras
How do u charge a kodak 7.2 camera, using the usb chord connected to the computer?
Use the USB cord to connect the camera to a powered USB port on a computer. Do not connect it through a USB hub. Be aware that not all computer USB ports put out enough current to charge the batteries.
Dec 15, 2010 | Kodak EASYSHARE M763 Digital Camera
Camera won't turn on
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
4. Upload new firmware:
Connect the camera with the computer.
Turn the camera on.
Click onto the link and follow the instructions.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=11888/11893&product=EKN034495
If successful please give me the feedback as a rating or recommendation. Thank You
Jan 01, 2010 | Kodak Easyshare C813 Digital Camera
Kodak easyshare c530 troubleshooting won't start
Red light indicates that the battery is out of charged., Now if th ebatetry is out of charged there will be no chances for you to connect it using your computer., C530 will not charged using the USB cable., try to charged the batetry or purchase new sets of battery
Nov 17, 2009 | Kodak EasyShare C315 Digital Camera
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Kodak easyshare C182 camera. It is six days old with fresh rechargable batteries inside. It will not turn on at all. HELP PLEASE :)
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
Contact KODAK:
Nov 04, 2009 | Kodak Easyshare C182 12MP Digital Camera
Camara Kodak M1063 not charging
BATTERY MAY BE SHOT. FIRST MAKE SURE
ALL CONNECTIONS ARE TIGHT AND CLEAN.
IF THIS DOES NOT WORK, U WILL NEED A NEW BATTERY
Jun 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
My kodak Easy share digital camera will not turn on
clean the connectors internally to which the battery connects.if they r dirty this can happen.or if that connectors get loose or little bit bent they cannot connect the battery properly and this happens.
Jan 07, 2009 | Kodak EasyShare C743 Digital Camera
Kodak EasyShare M853 Digital Camera Logo
77 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
