Question about HP DeskJet 9800 InkJet Printer
Hi, my printer was dropped and the belt that makes the cartridges came off. Can this be fixed?
    Guru:
  • HP Master
  • 2,178 Answers
Yes, as long as the belt is not broken nor the pulleys that hold the belt.
Posted on Nov 03, 2010
Clearing Code 3527 from Kodak Hero 9.1
Hi friends,
I was able to solve this problem (error code 3527 on Kodak hero 9.1) by opening the printer entirely (dis-assembled), Checking the cartridge carriage assembly, i discovered that the belt that drive carriage assembly had a locker that was broken as such, the carriage assembly could not move in the direction as the motor drives the belt on.
I simply inserted the belt in position and drop a little drop of super glue to it, let it dry off.
Assemble my printer, and it was ok and is working.
Aug 01, 2012 | Kodak HERO 9.1 All-in-One Printer with...
When i turn on my Deskjet 1125C printer, the cartridge cannot go to the center, the carriage moves from side then it stops moving, then the resume and power led power blinking. i also cleaned the mechanism...
According to your problem first check and make sure that the ink cartridge of the printer are not blank and not get dry also. Check the belt by which the cartridge moved, if it is getting loose. Tighten the screw of the cartridge moving roller. It will help you.
May 13, 2011 | HP DeskJet 1125c InkJet Printer
I can not locate the HP 940 cartridge o the printer in order to replace it. Can you tell me where to look for the print cartridge?
Hi, no problem. Switch Off
As you look at the front of your printer to the left of the paper tray you will find the black facia is a drop down lid drops towards you revealing four cartridges.
Withdraw the cartridge in question note which way up and pull out at the same angle it is inserted.
Renewing, place the right way up and remembering angle gently insert new cartridge with a firm hand and you will feel a slight click as it locates.
After thought, please remember when ordering replacement to mention/make sure it is the wireless replacement, the 8500 (Non Wireless Printer) cartridge is not compatible.
Peter.
Mar 22, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
On my Epson Stylus DX7450 printer ,underneath the stop button is 2 wee lights 1 with a page beside it and the other with a drop(like an ink drop) beside it.Its an orange light that its on on the 2nd...
Hi, one of your ink cartridges are empty, to check which cartridge needs replacing press the stop button, the carriage will move across to the left and sit below a pointer. This will point to the empty cartridge.
Press the stop button again, the carriage will move across either to display another empty cartridge or to the position to allow you to change the cartridge.
This can also be checked using the Status monitor software on the PC.
Nov 24, 2009 | Epson Stylus CX3200 All-In-One InkJet...
My epson r2400, On power up the printer goes through it start up sequence then after about 2 mins the carridge stops on the left hand side of its track and all the lights go out. the printer haed seem to...
Check that your printer head is not jammed or move freely.
For that put oil in head carrier .
Also clean dust from head contact with carrier .
Let me know if you need more assistance.
Thanks.
Oct 09, 2009 | Epson Stylus Photo R2400 InkJet Printer
Lexmark x 1270 cartridge stall when about to print the cartridge would move to the left of printer and stall there.is there any way to fix the problem please and Thank you to any one who can help
Please follow the steps given below to install the cartridge:
1. Unplug all cables from the back of the printer.
2. Open the front cover and look above the steel rod. You should see a black belt with rubber teeth on it. (On some models, the cartridge access is very small, but the belt should still be visible.)
3. Take the top part of the belt and move it gently to the right. The cartridges should come towards the center.
4. If the cartridges will not move, tilt the printer on its back and try moving the belt again.
5. If it still will not move, try putting your finger inside the area where the cartridges are stuck (with the printer still on its back), and push them firmly against the cartridge carrier holder while you move the belt with your other hand.
6. Once the cartridge carrier is in the middle, please make sure that the cartridges are snapped firmly into the cartridge carrier. Note: Make sure that these cartridges are the correct models for your printer. Once the cartridges are seated properly, they should not become loose inside the carrier.
7. Plug all the connections back in and power the printer up.
8. Open the front cover again to see if the cartridges slide to the center.
Apr 29, 2009 | Office Equipment & Supplies
The thing that pulls the cartridges back n forth has come off.
hi yes it can be fixed, you need to take of a few covers and get it back down the carriage unit and put back on the belt.
its not that bad of a job prob worst is working out how the covers come off.
once they are off its a 5 minute job.
Regards
Canon Tech
Apr 01, 2009 | Canon PIXMA iP1600 Printer
Pixma printer
That black thing is the drive belt for the print cartridges. It man have come off when you were playing with the cartridges, or you may have a broken part that let the belt drop. Unless you are familiar with printer repair you do not want to open the unit and try to fix it. Take it in to a shop for repair...or you may create more problems than you fix.
However if you want to try use this site to get a guide on howto:
http://www.pdfoo.com/pdf-217/printer.html
Jul 14, 2008 | Canon PIXMA MP150 All-In-One InkJet...
HP PSC 2175 Cartridge Belt
Ok, I will try to explain how I fixed mine as best as I can. I took it all apart and realizing that the belt moved the cartridge carriage I thought 'hmmmm' and took the belt, cleaned it and the cartridge carriage and in the channel on the carriage where the belt sits (sort of W shaped) I put some 'Gorilla glue' and put the broken ends down into the glue. I let it set up for about 6 hours and my printer has been back up and running ever since. That fixed the broken cartridge carriage belt for me. Now if the other belt breaks then I guess I will have to break down and buy another printer but after 6 years of service I can't complain. And yes I have been refilling now for over 4 years. I hope this helps.
Kazdagi
Jun 22, 2008 | HP PSC 2175 All-In-One InkJet Printer
Tally Genicom 8008
The Set Belt CG message on the 8008 indicates the printer is not detecting the OPC belt (the green reflective belt located in the top of the printer)
Try removing the Belt Cartridge and relocate this in the pritner, if this fails to fix the problem remove the Belt Cartridge from the printer then look down one side of the belt- (I think the left side of the belt), for black squares (I think there are two) the printer uses these to detect the Belt Cartridge is rotating. Check for damage to the Belt in this area. If the printer does not detect the belt as rotating it will indicate this error.
If the Belt Cartridge looks ok, remove the Belt Cartridge from the printer then look down the hole left in the printer when the belt cartridge is removed. Look for any obstuctions, also look at the black belt which is towards the back of the printer when you look in the top ( the transfer belt, I think) Look to see if there is any damage to this it may cause the Set Belt CG message.
Apr 02, 2008 | TallyGenicom 8008 Laser Printer
HP DeskJet 9800 InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
